Old Feb 05, 2015, 05:13 PM
400fe is offline
Find More Posts by 400fe
United States, OH, Toledo
Joined Jul 2007
How about a list of plans that utilize Ace foam wings ?
I have several sets of replica Ace foam wings coming from a guy on ebay that is making them.
I would assume that there are a lot of plans out there that use ace wings (from the '70-'90's)
I'll be building one called "Eyelash"
Make a list if you know of others.
400fe is offline Find More Posts by 400fe
Old Feb 05, 2015, 07:58 PM
vkmet is offline
Find More Posts by vkmet
Joined Jul 2009
Schoolyard Special RCM 7-77
Simple Cub RCM 8-85
Simple Citabria RCM11-84
I built a Schoolyard Special with a Cox Black Widow, flew great.
vkmet is offline Find More Posts by vkmet
Old Feb 05, 2015, 08:17 PM
400fe is offline
Joined Jul 2007
eyelash
Old Feb 05, 2015, 09:31 PM
aspeed is offline
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
Cricket, Cessna 150, Simple 400. They are all pretty much the same layout.
aspeed is offline Find More Posts by aspeed
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Cast or hot wired Cores?
ACE ones were cast...making for a BIG difference, structurally.
Bare is offline Find More Posts by Bare
Old Feb 06, 2015, 10:47 AM
Jennifer Curtis is offline
Find More Posts by Jennifer Curtis
Joined Jan 2015
All Star
Ace Whizard
RCM B-25 Mitchell
Ace Simple series:
corsair
p-51
others?
Jennifer Curtis is offline Find More Posts by Jennifer Curtis
Old Feb 06, 2015, 10:50 AM
400fe is offline
Joined Jul 2007
Looking for links to plans....not just names of planes
Old Feb 06, 2015, 12:26 PM
hlsat is online now
Find More Posts by hlsat
hlsat's Avatar
Ελλάδα, Ανατολική Μακεδονία Θράκη, Βιστωνίδα
Joined Jul 2006
Originally Posted by 400fe View Post
eyelash
Will be your design wooden wings to this plane ??
Elijah Greece.
hlsat is online now Find More Posts by hlsat
Old Feb 06, 2015, 03:05 PM
Condor84 is offline
Find More Posts by Condor84
Condor84's Avatar
United States, FL, Hastings
Joined May 2013
Ok, big question is, do you have tapered Ace wings, or the constant chord ones coming in, or both? There's some very cool airplanes for either.
Condor84 is offline Find More Posts by Condor84
Old Feb 06, 2015, 03:15 PM
Condor84 is offline
Condor84's Avatar
Joined May 2013
One of my all time favorites for the constant chord that can be built using the Ace wing as a core is the Hobby Shack 1/2a SST. Very nimble and fast little airplane when set up correctly. These are the RCM plans, but they are identical. If they're actual ACE wings you have, you may not even need to sheet the wings as called for in the plans, but the benefit is that if you do you can really over motor the airplane and make a super hot rod out of it, as the sheeting will add a lot of rigidity either way. I still have mine that I built from the kit 20 years ago when I was 10, and just flew it at the beach today. It's electric now however.
Old Feb 06, 2015, 03:20 PM
400fe is offline
Joined Jul 2007
Elijah Greece.
No, Ace tapered foam wings per the plan. Sheeted with balsa.
Old Feb 06, 2015, 03:21 PM
400fe is offline
Joined Jul 2007
Both are coming :}
Lets see those cool planes!
Old Feb 06, 2015, 03:23 PM
400fe is offline
Joined Jul 2007
Unfortunately no one is making the original cast as far as I know, so I will be balsa sheeting the hot wired/cnc ones.
Old Feb 06, 2015, 03:27 PM
400fe is offline
Joined Jul 2007
I had 2 original SST's many moons ago. One of the best and most fun. Wouldn't tip stall no matter how slow you got it, super stable fast and aerobatic. Plus easy engine access for tuning and trying different engines.
Old Feb 06, 2015, 04:38 PM
madsci_guy is offline
Find More Posts by madsci_guy
Figure Nine Champ
madsci_guy's Avatar
North Texas
Joined Nov 2002
The original 1/2A SST had cut foam cores, which are a lot flimsier than the Ace foam wings. That's why the balsa strips in the plans. I would not sheet Ace wings, they end up way too heavy. Strapping tape under the Solarfilm or Econocote covering works just fine, you might bend them into a U shape with a ton of g's, but no way they will break.
Also the 1/2A SST had a sharper leading edge and the max chord thickness happened a lot farther back than the Ace wings.
madsci_guy is offline Find More Posts by madsci_guy
Question How would you go about this? Plastic on Foam - Help! mjgravina Beginner Training Area (Aircraft-Electric) 7 Dec 24, 2014 05:09 PM
Sold Vintage Ace R/C Ace High MkII Glider Foam Wing Kit Ricomon Aircraft - Sailplanes (FS/W) 5 Dec 05, 2014 08:55 PM
Sold (2) hot wire cut "Ace Tapered" foam wings,and New "Min-E-Taurus plans. phoneguy Aircraft - General - Miscellaneous (FS/W) 3 Mar 25, 2014 07:26 AM
For Sale ACE Foam Wing Cores in Blu Dow Foam MWCores Aircraft - Sailplanes (FS/W) 4 Mar 05, 2014 03:53 PM
Discussion Ace foam wings are available! Who has plans? singlestick 1/2A Planes 16 Apr 28, 2006 01:17 PM
