Old Jul 10, 2015, 09:43 AM
villapilote is offline
Find More Posts by villapilote
Wilson, NC
Joined Aug 2009
Flying Wing with Landing Gear
Flying Wing with Landing Gear.
Every flying wing I have seen has not had landing gear, and just about everyone has crashed on the first launch. Mine has never crashed, yet.
villapilote is offline Find More Posts by villapilote
Old Jul 10, 2015, 10:32 AM
nuteman is online now
Find More Posts by nuteman
Joined Apr 2013
Good job!
Others have done landing gear (Example: see http://www.rcgroups.com/forums/showt...=horten&page=2, post 29, for video) and it doesn't laways work out so well.
On a windy day, I perfer to hand launch. If the gear is halfway decent, it tends to be heavy and the added drag is definitely noticeable - but it is so cool/satisfying to do proper take-off rolls when the wind permits
nuteman is online now Find More Posts by nuteman
Old Jul 11, 2015, 03:23 AM
jofro is offline
Find More Posts by jofro
Joined Jan 2010
This is my latest design.
jofro is offline Find More Posts by jofro
Old Jul 11, 2015, 08:59 AM
Number_6 is offline
Find More Posts by Number_6
Ft Lauderdale
Number_6's Avatar
Joined Sep 2012
My research into tricycle landing gear for a scratchbuilt
flying wing has found:
1. The front wheel should be far as possible forward.
And a steerable front wheel is needed to taxi with
elevons only.
2. The two rear wheels mounted just behind center
of gravity of the wing....want to position them so when
you push down slightly on the back of the wing with a force
of only about 3 to 4 ounces the front wheel lifts off the
ground.
3. The height of gear is very important...must be sized so the plane
has an Angle Of Attack of 4 to 6 degrees setting on the runway.
I am scratchbuilding EPP 'Simitar' style wings that Bill Evans
created way back in the 90's...source of the info.
Edit:.... mention props. Obviously this setup works better
with tractor motors and props sized to fly good but still clear
the ground. Or twin tractor motors...check out CrashTestHobby
with their twin Hercules which uses rudders and landing pads
not wheels.
Simitars use a fuse which helps.
Anyway...not all 'wings are landing gear friendly' and
Youtube has some of those crashes...
Research is much cheaper...
Number_6 is offline Find More Posts by Number_6
Old Jul 11, 2015, 09:46 AM
Wilson, NC
Joined Aug 2009
I have been flying RC since 1972 and in that time have broken many front wheel steering arms. I no longer use those weak steering arms. I make an arm from 1/4" cutting board plastic that I screw into the front steering coil. In addition I use a 1/16" music wire shock relieve rod to connect the steering servo to the front wheel. You can see the steering rod coils if you blow up the photo.
Old Jul 11, 2015, 11:58 AM
Number_6 is offline
Ft Lauderdale
Number_6's Avatar
Joined Sep 2012
Nice setup you have made...and on a pusher motor wing.
Thanks for the details.
I prefer pusher motor wings and will try
that for sure.
Just finished a 'simitar looking' EPP 55" FS wing
but put the motor as a pusher and close to the centerline
for least thrust angle issues.
Next project is a 'Nurf' style FS pusher wing with fuse.
Flying Foam has been cutting many EPP cores for me and
I will use your landing gear arrangement, Flying Foam cores and
style the fuse like their Nurf except pusher motor to be on lower thrust
angle more through the CG, center of lift of the wing.
Thanks again for the pic...learned a little more today!
Old Jul 11, 2015, 04:37 PM
Wilson, NC
Joined Aug 2009
Hi NUMBER_6
I have been surprised at how well protected the prop is in a pusher configuration. In hundreds of flights I do not believe I have ever broken a prop.
Discussion FZ3 build: Flying wing with landing gear vincent123 Nurflügel 120 Mar 09, 2014 08:58 AM
Discussion Flying wing with landing gear vincent123 Flying Wings 24 Feb 04, 2013 02:18 AM
Discussion 47" WS Flying Wing with Landing Gear villapilote Flying Wings 10 Oct 20, 2012 04:28 PM
Discussion Scratch build flying wing with landing gear vincent123 Flying Wings 3 Aug 22, 2012 12:27 PM
