Old Jul 02, 2014, 09:22 AM
David Forbes is offline
Find More Posts by David Forbes
David Forbes's Avatar
United States, FL, Gainesville
Joined Dec 2005
e-Sail plane ID?
I just inherited this thang. Any ideas as to what it is? It obviously pre-dates 2.4g. Nicely made, but with no glide path control it will probably just be a sport model. Also need some guidance on a motor/batt/speed control combo, and since this won't be a competition model I want to go cheap.
Dave
PS, forgot to say, it's 2m wingspan
David Forbes is offline Find More Posts by David Forbes
Old Jul 02, 2014, 10:14 AM
Windependence is offline
Find More Posts by Windependence
Quando Omni Flunkus Moritati
Windependence's Avatar
USA, MN, Rochester
Joined Mar 2008
Looks like an Omega. They came in a number of sizes and control configurations. That one reminds me of the Omega 1.8. I believe it was also sold under the name Magellan.
Wayne
Windependence is offline Find More Posts by Windependence
Old Jul 02, 2014, 10:39 AM
martinh is offline
Find More Posts by martinh
martinh's Avatar
United Kingdom, England, Fleet
Joined Aug 2002
Yup, its an Omega.
I have the 1.5m version and it flies very nicely indeed.
Martin
martinh is offline Find More Posts by martinh
Old Jul 02, 2014, 10:45 AM
Joined Dec 2005
Thanks Wayne, I just went out and actually measured the wingspan instead of eyeballing it, and bingo, 1.8m
Dave
Old Jul 02, 2014, 10:56 AM
szastoupil is online now
Find More Posts by szastoupil
Scott Zastoupil
szastoupil's Avatar
USA, WI, Waupaca
Joined Aug 2002
Hi Dave. There used to be quite a few of the Omega's in our club when Dymond Modelsport used to be in Oshkosh, WI (15 miles down the road). There is still at least one in our club that is flown on a regular basis with NiMH batteries. I do recall seeing the landing zone being quite variable without flaps. I believe they made it with a traditional rudder/elevator tail too.
Scott
szastoupil is online now Find More Posts by szastoupil
Old Jul 02, 2014, 11:45 AM
martinh is offline
martinh's Avatar
Joined Aug 2002
I've got a small.hacker outrunner and 1000mah Lipo I mine. Around 100watts will go nicely.
Martin
Old Jul 02, 2014, 11:54 AM
Joined Dec 2005
Now that we know what it is, any reccomendations for a cheap power plant for it?
It looks like up to a 28mm outrunner would fit. I'm not looking for vertical climb, just something to get it in the air without adding too much weight.
Dave
Old Jul 02, 2014, 12:10 PM
peterlngh is offline
Find More Posts by peterlngh
Joined Apr 2012
Hi, Dave.
I have three HobbyKing 2834, 1250 kv, motors and just love them. 66 grams and will put out 300watts on three cells with an 11X6 prop. My 900 gram Specter 1800 will climb straight up as high as I want it in 10-15 seconds. Alas. I just noticed that they are out of stock. So? we would be looking at comparable motors. One of the Turnigy SK3 motors should fit your needs and I've read goo things about them. Something like this, with a 9X5 or 10X4 prop, perhaps?
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Cheers!
peterlngh is offline Find More Posts by peterlngh
Old Jul 02, 2014, 12:13 PM
martinh is offline
martinh's Avatar
Joined Aug 2002
I have the hacker a20 22L with Aeronaut 9x5 folder and 3S 1000mAh lipo.
BTW the wing is incredibly strong carbon D-box, which can take almost anything that you throw at it.
You are lucky to have inherited it, because they are very nice planes indeed.
Hope this helps,
Martin
Ps my hacker is similar to the Hobbyking motor listed above.
Old Jul 02, 2014, 01:07 PM
martinh is offline
martinh's Avatar
Joined Aug 2002
The speed version with ailerons is still available here:
http://www.hyperflight.co.uk/product...kylite-speed-e
Loads of information here about motors too...
Martin
Old Jul 02, 2014, 01:24 PM
Joined Dec 2005
I've got a Torque22T/930 (similar to the Hacker) in a 2m Wind Dancer and it's got plenty of go. Been looking at this one http://www.headsuphobby.com/Firepowe...otor-E-625.htm
Headsup RC is local and I've had good results with their stuff.
Dave
Old Jul 02, 2014, 01:27 PM
martinh is offline
martinh's Avatar
Joined Aug 2002
Dave
Looks spot on Dave.
Martin
Old Jul 02, 2014, 05:28 PM
Joined Apr 2012
That looks perfect, Dave. Hmmm. I might have to try one of them myself!
Old Jul 11, 2014, 02:07 PM
Joined Dec 2005
Maiden flight report:
Flew the Omega today. First powered flight was interesting, had the motor running backwards Fixed that and flew a bit with the battery forward of the bulkhead at the LE of the wing. Decided it was nose heavy so moved the battery back under the wing and boy did that plane wake up!
Installed the Firepower with a 22A speed control and an 800mA 3s. Drew just under 10 amps with a 10x6. I'll try it again Sunday with an 11x8 as the climb was pretty ho-hum with the 10x6, maybe a little worse than a stock Radian. All up weight is 18.3oz, and I think this bird will stay up until I'm ready to come down
Thanks all for the help IDing this little gem.
Dave
Help! fitting e-flight to an existing sail plane the welshman Sailplane Talk 10 Apr 20, 2011 02:36 PM
For Sale Hobbico Ventura E.P. Electric Sail Plane mredzadventure Aircraft - Electric - Airplanes (FS/W) 7 Jun 27, 2010 09:48 PM
Sold E-P Sailor motorized Sail Plane FREE !!!! butch4u Aircraft - Electric - Airplanes (FS/W) 12 Dec 28, 2007 10:19 AM
Id sail plane cfischer505 Sailplane Talk 0 Aug 24, 2003 12:27 PM
Did anyone see "The Lost Battalion" ON A&E ?ID the plane please Dandi6065 Electric Plane Talk 4 May 24, 2002 08:00 AM
