Old Dec 10, 2001, 03:03 PM
f2racer's Avatar
MA
Joined Sep 2001
Which replacement prop to get for my Soarstar?
I finished the repairs to my Soarstar after a tree incident. Unfortunately, my LHS only had a Top Flite wood prop in the "8x4" size that the Soarstar uses. Testing this weekend proved that this prop is considerably down on power compared to the plastic (nylon?) stock prop. Does anybody know of a replacement prop that works good with this plane?
Thanks!
f2racer is offline Find More Posts by f2racer
Old Dec 10, 2001, 04:39 PM
Registered Snoozer
Neil Morse's Avatar
San Francisco, CA, USA
Joined Jul 1999
Either an APC slowflyer 8X3.8 (Hobby Lobby P08038) or a Graupner SLIM Electric 8X4 (Hobby Lobby GPS0804) will do fine. Just make sure you've got it mounted right (with lettering towards the front of the plane).
Neil
Neil Morse is offline Find More Posts by Neil Morse
Old Dec 11, 2001, 04:04 PM
f2racer's Avatar
MA
Joined Sep 2001
Would moving to a larger prop or one with more pitch make more sense?
Thanks!
Old Dec 11, 2001, 04:24 PM
Tell that to George Zipp!
mikeb33's Avatar
United States, IL, Inverness
Joined Oct 2000
Props are cheap and you can buy a number of them to try and decide yourself, but I think you have the right one for that plane. The only other change you could do prop wise, is to go direct drive like a Wingo. I'm not sure what prop they use, but the Wingo seems to fly good as well. I prefer geared usually.
MIKE
mikeb33 is offline Find More Posts by mikeb33
Old Jan 10, 2002, 02:15 AM
f2racer's Avatar
MA
Joined Sep 2001
Seems like the props for my little electric are $1-2 more than those I get for my glows (9x6, 10x5, 10x6, 10x7, 11x5, 11x6)... I went with an OEM prop for the Soarstar. I read that it's one of the most efficient props available for the motor/gearbox pusher configuration that comes with this plane.
Old Jan 10, 2002, 06:09 AM
USA, FL, Apopka
Joined Dec 2000
You can get replacement SoarStar parts including the prop from Horizon Hobbies.
http://www.horizonhobby.com/products...at=APZ#listing
Hope that helps.
Brad
bradpaul is offline Find More Posts by bradpaul
Reply With Quote  (Disabled)
Old Jan 10, 2002, 01:36 PM
f2racer's Avatar
MA
Joined Sep 2001
Horizon Hobby
Up that's where I ordered mine from. Most LHS can also order it also, but I needed some extra stuff as well.
Which plane should I get for my second plane? LS427 Beginner Training Area (Aircraft-Electric) 5 Sep 18, 2010 05:44 PM
Discussion Which motor should i get for my scale swift? aces_high Electric Heli Talk 17 Oct 04, 2006 02:17 PM
Which Prop Adapter For my Mega Powered XE2? Joe Elston Foamies (Kits) 11 Jul 01, 2003 09:09 AM
which motor and gearbox to get for my slowtick someone special Parkflyers 0 Jan 13, 2003 02:53 PM
What type of connectors should I get for my Soarstar? f2racer Electric Plane Talk 2 Nov 14, 2001 07:45 PM
