Old Jul 23, 2014, 10:22 AM
Eindhoven
Joined Jul 2007
Looks good DUP!
Did you narrow the root? very nice blade shape now.
GregG, if you make the 3D model for the mould it sure is al lot less work for me
My 3D modeling skills are very limited, I can not do it ( yet).
also the prop blade needs manual work to smoothen the hub -blade tranfer region.
I am not able to do that in 3D modelling.
and you pay the printed parts per volume, a 1.5 gram prop is about 10 euro.
A mould is possible but also costly.
and then you still have to finish the surface, much more difficult in negative.
So for the moment positive seems the way to go.
Tjarko
tjarko is online now Find More Posts by tjarko
Old Jul 23, 2014, 04:57 PM
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
Yes printing definitely goes up in price with larger parts!
I have not modified the root Tjarko, just profiled the blade to blend into it. And added the fillet of course.
DownUnderPilot is online now Find More Posts by DownUnderPilot
Old Jul 24, 2014, 04:10 PM
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
The High Performance Props of RCG
A suggestion: regarding the mini Hotliners (X-plane etc.) I have found that there might be a prop size that could perform better than the ones on the market today. I do believe that putting a 16x17 or even a 14.5x15 will create an excess of thrust at the expense of flight time and pitch speed in the typical setups used, while the 12x17 does not cut the mustard because of poorly designed (thick) blades.
In my X-plane I have found that a chopped RFM 15x16 gives me the best combo of thrust, pitch speed and battery economy. The prop measures about 13x16 and mounted to a 36mm RFM center piece it is 333mm wide.
Here's my X with this prop at 1700W:
X-plane climbs (1 min 24 sec)
X plane rippin' (4 min 16 sec)
Arcteryxxx is offline Find More Posts by Arcteryxxx
Discussion 4S 8" props vs 3S 10" props Performance & Flight Times GuerillaFilm Multirotor Talk 12 Sep 16, 2012 06:50 PM
Discussion Prop Balancer for High Performance TheBlood+ High Performance 27 Apr 04, 2012 03:58 PM
Sold NIB Aquacraft GrimRacer High Performance Prop L42x66 sgil2001 Boats (FS/W) 2 Jul 26, 2010 11:12 PM
Sold 2 Graupner CAM high performance props new in original packages -- $7 shipped for both SPasierb Aircraft - Electric - Power Systems (FS/W) 2 Jan 14, 2009 05:09 PM
For Sale High Performance Prodigy wing kits ,with or w/o motor/prop sylair Aircraft - Electric - Airplanes (FS/W) 2 Aug 20, 2008 01:44 PM
