Old Nov 04, 2005, 06:21 PM
klank is offline
Find More Posts by klank
Ottery St. Mary, Devon
Joined Nov 2005
A cheap submarine motor/ballast pump from an odd source
I came across this rather odd solution to a scratch build problem recently.
A friend of mine wanted a small, low powered motor and pump to use in a motorised conversion of a new scale plastic U boat kit - to make it a displacement diver as well as RC/motorised. (He is a bit of a submarine nutter)
Given that the hull size is small to say the least - he looked on the project as "only a bit of a challenge".
He needed a ballast pump/motor - using low amps and of small dimensions to fit the hull cross section.
The answer was found in a "Home Medical Supplies" store - a battery powered, electric blood pressure monitor (the sort with an inflatable rubber cuff) - when stripped down provided an ideal low voltage battery powered motor/pump assembly to fit in the hull.
Cost about 12 !!
I suspect this could be used in other areas of modelling too - ?home made smoke unit?
Would it be possible to control the speed of the motor via the esc circuitry - and thus blow more or less smoke using the pump as an air blower across the smoke maker as revs change?
I was wondering also if the motor/impeller from a cordless hand held vacuum cleaner (?Dust Buster type) whose batteries are past it might have a use?
Has anyone else come across odd solutions?
klank is offline Find More Posts by klank
Old Nov 04, 2005, 09:27 PM
CG Bob is offline
Find More Posts by CG Bob
KC8WPF
CG Bob's Avatar
Euclid, Ohio, United States
Joined Sep 2004
Some people have been using the small BP cuff and motor for years in subs, it's known as the RCABS.
CG Bob is offline Find More Posts by CG Bob
Old Nov 05, 2005, 07:16 AM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
The Dustbuster blowers tend to be be low pressure, high volume fans that pull lots of amps on low volts (3.6v iirc).
Veering slightly off the subject to LARGE water pumps... Jeff Churill has been using inexpensive bilge pumps for 1:1 pleasure craft, < $20 each and run on 12v, to pump ballast water in his big freighters.
And I've recently noticed some 12v electric coolant circulation pumps used in some automobiles, usually to maintain heater water flow in certain conditions... Lincoln LS used one, Ford Escape Hybrid uses a couple... probably $$$ at the dealer, but maybe in the junkyard someday?
Pat M
patmat2350 is offline Find More Posts by patmat2350
Old Aug 20, 2006, 09:50 PM
willin is offline
Find More Posts by willin
willin's Avatar
In my Blu heaven! near Lincoln NE
Joined Mar 2003
For price it is pretty hard to beat a universal washer pump for autos. They will pump a very decent amount of water in a very decent amount of time.
I realise this is a sort of aged thread and I don't have much interest in boats, bilges, impellers and such but I had a silly dream last night that had me using a motorised toy water gun to propell a very small kayak anong softly and stealthily. Now what I had was quiet but did not have anything for speed. I began to think that I have the knowledge to wind my own CDrom motors and that if I were to replace the motor in the water gun I could actually get some speed out of this thing. I thought further ( stupid dream ) that instead of hopping up the water gun I should instead build a propulsion sytem for the boat. That would be even more efficient!
Since I had that dream I thought I would just poke around a bit and see about what modelers are doing with jet drives. Not that I want to actually want to build what was in my dream but see what really is going on.
I did a search for impeller and that lead me to this particular thread.
Can anyone enlighten me or should I have looked in racing?
Robert
willin is offline Find More Posts by willin
Old Aug 20, 2006, 11:30 PM
LtDoc is offline
Find More Posts by LtDoc
McAlester
Joined Nov 2004
Robert,
A 'jet' is more or less just a 'ducted-fan' type impeller with a very long 'duct', sort of. A typical prop sort of re-shaped to fit in a properly sized 'duct' ought to give you some push. Whether or not it would be enough is a different story, I have no idea. The 'biggy' would be the clearance tolerances blade/duct. A drive shaft long enough to reach through the 'curve's of the duct to the prop ought to be a nice challange! lol
- 'Doc
LtDoc is offline Find More Posts by LtDoc
Wanted Wanted: Radio/motor/battery setup from an el-cheap-O "RTF" R/C plane. Cheesehead Aircraft - General - Miscellaneous (FS/W) 1 Aug 01, 2006 11:05 PM
Question Removing Gearbox from an Aveox Motor Neil Stainton Power Systems 1 Apr 05, 2006 09:07 PM
Run an alternator from an electric motor ? digsy DIY Electronics 17 Jun 13, 2005 05:29 PM
Question Ultra cheap micro motor from your village shop? vintage1 Power Systems 1 Jun 04, 2004 11:37 PM
?source of cheap brushless motor? bpu6999 Electric Plane Talk 2 Dec 21, 2001 08:18 AM
