Old Sep 25, 2014, 12:58 PM
kinetisist's Avatar
United States, CA, Burney
Joined Jan 2013
thanks for the help
kinetisist is offline Find More Posts by kinetisist
Old Sep 29, 2014, 03:53 AM
United States, AZ, Tucson
Joined Apr 2012
I built a new fuse after it broke last time.
boa2110 is online now Find More Posts by boa2110
Old Feb 11, 2015, 01:11 PM
Joined Apr 2012
Maiden flight
Glide testing today. After many throws it was still in good shape. I will try a bungee launch next.
$Tree Glider (1 min 17 sec)
Old Feb 11, 2015, 10:02 PM
sailplane nut
Herminie, PA 15637
Joined Apr 2007
Hi from RCbobcat55 Very impressive design! I have built a bunch of foam board models in the past including flat 3D designs, mini edf jets, and disposable slope ships. To get a nice smooth profile on the foam board edges I glue balsa or spruce strips to the raw edges then carve and sand them round. I also have been experimenting with laminated depron with a layer of 1/2 or 3/4 oz glass cloth between the two layers then sanded to an airfoil shape-very strong and even stronger if covered with silkspan and polycrylic satin water based varnish. I also use cf rods for tail booms and carved pink foam pods covered with 2 layers of glass cloth then cut out the canopy opening and dissolve out the foam. Very light and strong. keep up the good work-we need some innovative and cost-effective forms of construction. Bob M..
rcbobcat55 is offline Find More Posts by rcbobcat55
Old Feb 11, 2015, 11:15 PM
Joined Apr 2012
I was thinking of making a pod next.
Old Feb 12, 2015, 09:06 PM
sailplane nut
Herminie, PA 15637
Joined Apr 2007
Give it a try-it really isn't too hard to do. Also, I have a modified feather cut machine and can cut some very thin cores if you would like to try that idea out. I produce a whole line of arf pitcheron designs and several retro repro kits as well as cutting custom cores. Thanks for the reply. Bob M.. If you have any questions about making the pod feel free to pm me at RCbobcat55@yahoo.com Bob M..
Old Feb 13, 2015, 06:37 AM
Adam Gibson
xStatiCa's Avatar
United States, FL, New Port Richey
Joined Jul 2006
If you create a kit I would buy it.
xStatiCa is offline Find More Posts by xStatiCa
Old Feb 18, 2015, 01:50 PM
Joined Apr 2012
Bungee launch
It launched nice. I was afraid the wings would not stay level without ailerons. HobbyKing 6mm Bungee and some 6 lb fishing line.
Foam HLG (1 min 4 sec)
Discussion Dollar Tree Foam Piper Cub roger5005 Foamies (Scratchbuilt) 1 Apr 09, 2013 05:43 PM
Question Dollar Store Foam? How well does it work? cessna20122013 Foamies (Scratchbuilt) 5 Feb 17, 2013 10:33 AM
Discussion Dollar Tree Foam paint and tape. Pyrofan Electric Plane Talk 4 Jan 24, 2013 11:00 PM
Help! dollar tree foam trainer plans needed microairman1 Foamies (Scratchbuilt) 15 Jan 22, 2013 04:30 PM
Discussion My first attempt with dollar tree foam board f.a.r.m.e.r Foamies (Scratchbuilt) 5 Jan 20, 2013 12:00 PM
