Old Jan 31, 2016, 09:24 PM
rectifier is offline
Find More Posts by rectifier
Canada, SK, Division No. 7
Joined Aug 2014
Fixing EPP "road rash" on underside of fuselage
Had to put my unlaminated EPP plane (Bormatec Maja) down on a very rough ice surface at ~60kph.
The landing was as good as I could have hoped but the ice worked like a rasp on the bottom of the nose. There are little pieces of EPP strewn for 50 yards, no gluing them back on.
I've injected Gorilla glue into torn areas and pressed those back together, but obviously there is material missing. I'm thinking just to fill with Gorilla, probably in a couple stages, sand it down and paint black to match the plane. Then put a coroplast skid plate over the area!
Any better ideas?
rectifier is offline Find More Posts by rectifier
Old Jan 31, 2016, 10:23 PM
rocketsled666 is offline
Find More Posts by rocketsled666
If it flies, I can crash it.
rocketsled666's Avatar
Joined May 2012
There's a product designed specifically to be used by us hobbyists to fill foam that's got chunks missing. But I'll be damned if I can remember what it is called. Only that the demo video showed it being applied to the damaged nose of the purple Horizon Bearcat foamy.
But as an alternative, I've used the expanding foam insulation filler you can buy at Home Depot (or similar). Makes a mess going on, but sticks to the old foam like nothing else will, and is relatively sandable once cured out... but it's yellow/brown, so you need to repaint or it looks ugly as hell...
rocketsled666 is offline Find More Posts by rocketsled666
Old Feb 01, 2016, 09:54 PM
Glacier Girl is offline
Find More Posts by Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
Light weight Spackle mixed into some water based polyurethane works wonders. Sands super easy. Light weigh Spackle feels like the container is empty when you pick it up, so it adds next to no weight. I use Minwax WATER BASED polyurethane.
Mix the stuff together so you have a thick milk shake consistency. Use what ever is handy to smear it into the gouges, you can even brush it on if the damage is small. Use several coats to build up an area. It dries quickly that way.
Glacier Girl is offline Find More Posts by Glacier Girl
Old Feb 05, 2016, 05:27 PM
Joined Aug 2014
I ended up using a mix of regular polyurethane (gorilla) and water based pva wood glue. Heard it recommended somewhere. 20-30% PVA and remainder polyurethane.
This is a neat mixture producing a large volume of sticky, fine bubbled foam. It sets quickly but is flexible before it finally sets, so it can be shaped or pressed down.
It worked so well I decided to use it to also try to repair a foam rudder that went through a pusher prop. 3 pieces and 20% missing, otherwise garbage, and it now looks as new other than the colour of the fill. Very impressed!
Old Feb 07, 2016, 07:03 PM
rcrich is offline
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
I had this happen to my seaplane on ice and snow!
Beacon foam finish worked great to fix the rough spots.
rcrich is offline Find More Posts by rcrich
Old Feb 10, 2016, 05:56 PM
Mr.Runster is online now
Find More Posts by Mr.Runster
It's Cody Reed!
Mr.Runster's Avatar
United States, AZ, Flagstaff
Joined Jan 2015
I am working on a few builds that will need some smoothing out with something like lightweight spackle. I am wondering what the consistency of it is when it dries, is it brittle and chips off or is it able to give a little? What about some of the mixes you have made, like the wbpu and spackle, is that able to give a bit? I think I have heard of white gorilla glue and lightweight spackle, how does that act? I want something to cover the inaccuracies on a wing, but also be able to move and give with the foam of the wing, so it doesn't flake off.
Mr.Runster is online now Find More Posts by Mr.Runster
Discussion fixing motor on epp yak55 Marcus33 Foamies (Scratchbuilt) 13 Apr 01, 2014 04:22 PM
Discussion Tips for reducing hangar rash on smaller foamies iceburg47 Foamies (Scratchbuilt) 9 Oct 20, 2013 04:14 PM
Discussion hanger rash - how do YOU fix small dents? webbsolution Multi Task F3X 18 Oct 08, 2013 12:06 AM
Discussion Let,s see some road rash swheels Motorcycles 10 Mar 26, 2006 05:58 PM
