Old Dec 17, 2015, 02:26 PM
Juergen S. is offline
Find More Posts by Juergen S.
Joined Oct 2015
UMX Bf109 G6
Hi!
Now i start with the buildingthread for my second Version.
My first version was this one.
It flies with 2s, 6 Servos and weights with battery 58gramm.
That is too heavy at 45cm wingspan.
So now i build a complete new one and i hope the new one weights with the same funktions ( retracts, flaps und cooler) < 30gramm
Juergen S. is offline Find More Posts by Juergen S.
Old Dec 17, 2015, 02:29 PM
Joined Oct 2015
I started with the Motor.
in the old one was the Motor from the UMX Beast ( 8gramm and a GWS 5x3x3 2,5gramm)
The new one is a modifide AP02 with a selfmade Gearbox like from Vladimir here in this forum.
Motor with Ballbearing Gearbox weight 2,8gramm.
With Prop Microinvent 5x4 3,5gramm and with ESC 4gramm
Old Dec 17, 2015, 06:56 PM
Ruffin Ready is offline
Find More Posts by Ruffin Ready
already ruff, trying for ready
Joined Apr 2011
Juergen I saw your videos of your foam DR I and your larger 109G. Your skills sort of make a mockery of the title of this forum, in a good way, in that you are able to build both large and small indoor models from foam. You're clearly a very talented builder and have picked a fascinating subject in the 109; I will follow your thread with interest.
Ruffin Ready is offline Find More Posts by Ruffin Ready
Old Dec 19, 2015, 12:40 AM
chulian1819 is offline
Find More Posts by chulian1819
chulian1819's Avatar
Medellín, Colombia
Joined Apr 2010
hope to see her soon!
chulian1819 is offline Find More Posts by chulian1819
Old Dec 22, 2015, 03:44 AM
Joined Oct 2015
Thank you guys!
At the moment i build the retracts.
At first testbuilding with different materials.
Outside diameters are the same!
Old Dec 22, 2015, 03:47 AM
Joined Oct 2015
The second version win
It is gonig on....
With paint it looks better.....
Old Dec 22, 2015, 11:55 AM
Joined Oct 2015
mechanic is ready
Old Dec 24, 2015, 07:23 PM
Joined Oct 2015
still going on
Old Dec 25, 2015, 04:28 PM
4 Scale is offline
Find More Posts by 4 Scale
Trampling out the vintage
Joined Feb 2002
Juergen can you describe what material you used for the landing gear, and how you cut and formed the wing parts? You are off to a very nice start.
4 Scale is offline Find More Posts by 4 Scale
Old Dec 25, 2015, 05:37 PM
AJWoods is offline
Find More Posts by AJWoods
Aircraft Designer Guy
AJWoods's Avatar
United States, CA, Santa Clara
Joined Jul 2005
Very well done!
-A
AJWoods is offline Find More Posts by AJWoods
Old Dec 26, 2015, 02:10 AM
Joined Oct 2015
Thank´s guys!
the heavy version with 0,25gramm was a polysterol push rod tube with 2mm outside diameter.
The lightversion with 0,15gramm is from a Q-tip. The red tubes are outside push rod tubes 3mm outside diamater. The mechanic is 0,15mm GFK and 0,8mm diameter carbon.
The Depronparts are Thermoformed with hot wire cutted 0,6mm Depron.
Old Dec 26, 2015, 08:58 PM
Joined Apr 2011
Looks good! When you say "thermo formed" can you say what your process is? I'm thinking about a micro Yak-1 but have not built a model out of foam.
Old Dec 27, 2015, 11:22 AM
Joined Oct 2015
Here can you see how it works.
My friend Thorsten ( in the clip) makes the Bf109 parts too.
Depron tiefziehen... (1 min 33 sec)
Old Dec 27, 2015, 12:08 PM
Joined Apr 2011
Thank you for posting that video. I have a vacuum form machine and look forward to attempting to form depron parts on it.
It looks like he heated the depron on a hot plate, separate from the forming machine?
I am greatly looking forward to seeing your progress given your impressive ability/access to form depron!
Old Jan 03, 2016, 07:46 AM
mtflyr is offline
Find More Posts by mtflyr
Centreville,VA,USA
Joined Apr 2001
RR, Looks great I have a few questions.
What is the hot plate temperature?
What is the foam thickness and is it Depron?
What is the distance between the hot plate and the foam when heating?
Did the foam sag any before pressing it to the mold?
Can you show how the foam is held in it's frame?
Thanks for the video.
Pete
mtflyr is offline Find More Posts by mtflyr
For Sale FMS P51 spares set, FMS P47 spares, FMS BF109 spares and 64mm x 20mm wheels viperviper Aircraft - Electric - Airplanes (FS/W) 1 Jan 22, 2016 07:12 AM
For Sale Meister Scale Bf109 84 inch demire Aircraft - Fuel - Airplanes (FS/W) 0 Aug 07, 2015 04:21 AM
Found FMS 750mm BF109 or FW190 TechSlave71 Aircraft - Electric - Airplanes (FS/W) 0 Jun 08, 2015 02:21 PM
For Sale pt19.sa5a.bf109.p51.pilatus NCHOUKER Aircraft - Electric - Airplanes (FS/W) 0 Apr 27, 2015 05:38 AM
For Sale Real Flight Package (G4 With G6 Update Goes To G6.5 For Free) Aurora9 Aircraft - General - Miscellaneous (FS/W) 1 Mar 26, 2013 01:09 PM
