Old May 28, 2015, 06:08 AM
alderaan is offline
Find More Posts by alderaan
Joined Oct 2011
Help!
Gold wing Extra 300 LP 20cc
Hi, i've bought by a friend a used goldwing extra 300LP 20cc size. Only plane without engine, servos.
plane size is about 1650mm (wingspan) x1500mm (fuselage).
Expert people at fly area suggested me to use a mintor 22 cc or a dle 20cc but this will be my first acro plane and i'd like to know if this size of engine will be useful to learn with first acro plane or i need a downsize engine like os .95v or a 1.20 4 stroke.
Any helps?
Gianluca
alderaan is offline Find More Posts by alderaan
Old May 28, 2015, 12:35 PM
los36 is online now
Find More Posts by los36
los36's Avatar
United States, TX, The Colony
Joined Nov 2012
When you say, "first acro plane," do you mean that you've only flown a trainer? If so, there is a large difference in how quickly this plane will respond to input and the speed that it will fly. However, the plane itself should not be inherently difficult to fly,
Greatly reducing the throws of the control surfaces will make your chances of success much greater. Have an experienced pilot test fly and adjust the control throws down to a good level for you.
Regarding engine, a 1.20 four stroke would slow it down a little yet still provide enough thrust for good flight.
los36 is online now Find More Posts by los36
Old May 28, 2015, 12:39 PM
los36 is online now
los36's Avatar
Joined Nov 2012
Ah yes, you were asking about the Calmato.
Well, this plane is a great bit more advanced than the planes we had been discussing. Again, these types of planes fly very well but are much more responsive and have zero self-righting properties compared to the planes you had previously been considering. Always have a flight plan before taking off.
Old May 28, 2015, 06:20 PM
alderaan is offline
Joined Oct 2011
Thanks for answer. Yes I opened a discussion first for calmato. After some web searches and forum discussion I met a person who works for Mintor engines. He used plane in object to test engines and will sell it to me.
The idea is to prepare the plane and make it test to my teacher before use it alone....till now I've flown alone only two time.....
The thought for the choice was: why buy all new, so plane, engine, servos and buy a calmato that I will use for more or less one year ? I mean with the used extra in object, which is clearly not an entry level I would learn with a plane less trainer then calmato and I think that with right servo exp and response and teacher in fly area I should learn much more.
Is this idea wrong?
Old May 29, 2015, 02:02 AM
whiskykid is offline
Find More Posts by whiskykid
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
I went from a 3 channel Sig Kadet, too a full on 4 channel Sterling Olympic Challenger!
although I was doing stuff with that Kadet, I am sure it wasn't meant ta do! and my reflexes, were only 20 something!
your thinking is sound! no use in buying all new till your skills get ta the point you fly more then you crash! and you will crash!
whiskykid is offline Find More Posts by whiskykid
Old May 29, 2015, 04:39 AM
alderaan is offline
Joined Oct 2011
"no use in buying all new till your skills get ta the point you fly more then you crash! and you will crash!"
These words sound absolutely true and real!
Help! Need GP extra 300 w/dle 20cc prop help James Viola Fuel Plane Talk 3 Oct 06, 2013 10:37 PM
Wanted 20cc gas extra 260 or 300 jlewis99 Aircraft - Fuel - Airplanes (FS/W) 0 Sep 06, 2012 11:22 PM
Sold Aeroworks Extra 300 DLE 20cc $380 LPU igorp Aircraft - Fuel - Airplanes (FS/W) 3 Aug 23, 2012 07:35 AM
Sold Aeroworks extra 300 60-90 or 20cc Eboyles Aircraft - Fuel - Airplanes (FS/W) 2 May 15, 2012 02:09 AM
Sold 30cc Extra 300 Gold WIng $200 mmclaug858 Aircraft - Fuel - Airplanes (FS/W) 1 Aug 15, 2011 07:15 PM
