Old Jul 22, 2016, 01:31 AM
Benovitch is offline
Find More Posts by Benovitch
BelgiŽ, Vlaams Gewest, Temse
Joined Dec 2004
Opening HET 700-68 motor
Hi, anyone knows how to open the can from the HET 700 motors. I think I have a broken bearing or worse a broken rotor.
Ben
Benovitch is offline Find More Posts by Benovitch
Old Yesterday, 12:38 AM
juanjulian is offline
Find More Posts by juanjulian
juanjulian's Avatar
Guatemala, Guate
Joined Jul 2007
I have done the 28mm and should be similar.
The end caps have a tight fit plus glue.
Procedure
Heat the out side of can of end cap with a torch. Carefull not to melt motor!
The idea is to thermal expand can and melt or soften glue.
Hold motor by the can and with a blow in a wood surface press shaft. With the blow in shaft back end cap should release. Remove rotor and shaft and do the same with front end cap.
Search my user name since have some pictures here.
Cheers
Juan
juanjulian is offline Find More Posts by juanjulian
Old Yesterday, 12:44 AM
juanjulian's Avatar
Guatemala, Guate
Joined Jul 2007
http://www.rcgroups.com/forums/showthread.php?t=1752218
Sold HET 700-68-1500 motor jlorenco Aircraft - Electric - Jets (FS/W) 2 May 11, 2016 07:55 AM
Sold HET 700-68-1500 Motor jlorenco Aircraft - Electric - Power Systems (FS/W) 1 May 06, 2016 12:48 AM
Sold HET 700-68-1680 w/tamjets 90mm motor housing metal jaybay7484 Aircraft - Electric - Jets (FS/W) 0 Apr 11, 2016 11:35 AM
Wanted HET 700-68 1400kv brushless motor Concordefan2 Aircraft - Electric - Jets (FS/W) 1 Nov 21, 2015 10:14 PM
Sold JETFAN 90mm & 700-68-1400 HET MOTOR duke2275 Aircraft - Electric - Jets (FS/W) 4 Nov 05, 2015 02:20 PM
