Old Jun 28, 2016, 03:22 PM
crawf56 is online now
Find More Posts by crawf56
"Ain't no Fortunate Son..."
United States, AR, Paragould
Joined Dec 2015
Build Log
Klingon D7 from Arkansas [ Cyberplanes kit ] - Star Trek
Sometimes, you feel the Call of the Warrior......
I will be constructing a "Klingon D7" from Cyberplanes:
http://www.cyberplanes.com/index.php?productID=158
This is an electric, EPP foam model. It is a kit, but certainly not an ARF. Took about 10 days to get to me.
Wingspan: 34 inches
Length: 39 inches
And here is what you get:
crawf56 is online now Find More Posts by crawf56
Old Jun 28, 2016, 03:37 PM
Joined Dec 2015
Background
The Klingons are a fictional race from the Star Trek universe. They have appeared in several movies, and in all the series.
The D7 is their main starship in the original Star Trek series. It is also referred to as a "K't'inga" class cruiser in the opening scene of Star Trek: The Motion Picture.
Even though there are a few differences, the Cyberplanes model seems to fairly well represent the D7 look, with some allowances made for aerodynamics.
The aircraft is designed to be built using hot glue (my first experience with the stuff).
Rather than written instructions, it comes with an instruction video, which is well done.
Old Jul 03, 2016, 09:55 AM
Joined Dec 2015
Main Hull
Starting out with the Main Hull: two big hunks of EPP foam that you glue together.
I glued the longer section first, using the hot glue. After applying glue, held them together on a flat surface: my workbench.
NOTE: There is a TOP and a BOTTOM to the Hull. It is defined by the bevel at the back of the two pieces, where the ailerons attack. The flat surface is the top of the hull. The beveled surface is the bottom.
Old Jul 03, 2016, 09:57 AM
Joined Dec 2015
Hot Glue
Here is the hot glue I am using. Got it at Wal-mart.
Old Jul 03, 2016, 10:02 AM
Joined Dec 2015
Once you get the Hull haves together, you attach the carbon rods, which are included with the kit.
I originally thought I could just use an Xacto hobby knife, but that did not work.
Again, I had to make a "bevel", which is an angled section cut out of the foam. What seemed to work best was a razor saw (red handle).
Old Jul 03, 2016, 10:10 AM
Joined Dec 2015
Forgot to show: I marked the location of the rods with a silver Sharpe.
To place the rods, I ran a line of hot glue in the bevel. Then I IMMEDIATELY placed the rod in position, and pressed it in a little. (Yeah, you get glue on your hands. But it comes off easy.)
I installed the rods one at a time; you MUST act quickly before the glue dries.
Once all rods were installed and dry, I went back and added glue over the top of the rods/foam.
Old Jul 03, 2016, 10:20 AM
Joined Dec 2015
Hull Support
I am been impressed with the thought that went into the design of the D7 by Cyberplanes.
The model has a 'hull support' for you to land on, so you aren't tearing up the boom/bridge and the warp nacelles. (If you don't know what that means, just keep following the build.)
There is a 'ridge' that turns out to be a landing skid. I made Sharpe marks at front and back so I could align it.
Per the video instructions, I added gussets of hot glue.
Old Jul 03, 2016, 09:20 PM
Joined Dec 2015
Assembling/attaching the boom is next.
The battery (11.1v, 2200 mAh) attaches to the boom, just under the hull. But the place on the boom had to be widened for my 2200 mAh battery.
NOTE: The boom section has a reinforcing wood piece. Very good idea.
Old Jul 03, 2016, 09:22 PM
Joined Dec 2015
The boom is attached to the hull. Measured, marked w/ a silver Sharpe.
Also used T-pins to hold boom in location while marking contact area.
Old Jul 03, 2016, 09:26 PM
Joined Dec 2015
Added main boom section. Really helped to strengthen.
Old Jul 03, 2016, 09:30 PM
Joined Dec 2015
More boom work.
Added 1/8th plywood to help hold battery. Used hot glue to secure it.
Old Jul 03, 2016, 09:31 PM
Joined Dec 2015
Added warp nacelles (wing tips).
Old Jul 03, 2016, 09:33 PM
Joined Dec 2015
Here is the assembly so far. There is a yard stick [36 inches] for scale. (A little less than a meter.)
Old Jul 03, 2016, 09:36 PM
Joined Dec 2015
By the way, here is half a sphere, that is the "chin" of the boom.
It was originally white, but I painted it black so it will show a similar color when the overall paint job comes.
There is also a small amount of fiberglass cloth epoxied to the chin to help protect it.
Old Jul 03, 2016, 09:37 PM
Joined Dec 2015
Oops - here's the pic of the chin:
Build Log Star Trek Enterprise D from Arkansas [SG-Ideas kit] crawf56 Foamies (Kits) 20 Yesterday 08:41 PM
Cool Klingon D7 - By Special Request of the Klingon Clans of Ohio SGTalon Foamies (Scratchbuilt) 76 Jan 05, 2016 10:58 PM
Sold kit rae star trek klingon knife on ebay ending soon riechsoldier1 Non R/C Items (FS/W) 0 Jul 18, 2014 01:30 AM
Sold R/C Star Trek Enterprise & Klingon ships NIB bruff Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Dec 28, 2010 06:43 PM
Discussion Star Trek RC from TycoRC Phenom Micro Ready-to-Fly 87 Aug 31, 2009 11:21 PM
