Old Nov 26, 2010, 08:48 PM
RcPiLoT101 is offline
Find More Posts by RcPiLoT101
Joined Aug 2010
Hawk Sky Motor
Is this a good choice for a motor with this esc on my hawk sky?
http://www.nitroplanes.com/al4003brmo.html
http://www.nitroplanes.com/30aelbrescsp.html
RcPiLoT101 is offline Find More Posts by RcPiLoT101
Old Nov 26, 2010, 09:48 PM
Dakrat is offline
Find More Posts by Dakrat
Sky good, Earth bad!
Dakrat's Avatar
Anchorage
Joined Dec 2005
I was going to say yes because that was in the replacement parts but looking into it that motor does look like it fits so this would be a better replacement in my opinion...
http://www.hobbyking.com/hobbyking/s...idProduct=5453 and if your going to order from there there then you should get this ESC http://www.hobbyking.com/hobbyking/s...idProduct=6458
Why do you need to replace them?
Dak
Dakrat is offline Find More Posts by Dakrat
Old Nov 26, 2010, 10:00 PM
Joined Aug 2010
The screws came loose on the motor mount. The motor flew off hits the plane (only a little mark) the fell to the ground. Now it goes to half throttle and cuts off.
Old Nov 26, 2010, 10:08 PM
Dakrat is offline
Dakrat's Avatar
Anchorage
Joined Dec 2005
Well I don't own one but this looks like a perfect match to the old one but I guess there are different versions so I'm not sure how your motor mounts in the plane. Maybe a picture and the size of the prop would help? As for the broken motor it sounds like you broke a lead wire, what happens when you hook up a meter to it?
Old Nov 26, 2010, 10:21 PM
Joined Aug 2010
Remember. This motor has to push almost 2 pounds. That's one little motor. I had an Eflite on like that and it was about the same size and the plane wouldn't even move. What type of meter? A watt meter?
Old Nov 26, 2010, 10:27 PM
fly Frontier is offline
Find More Posts by fly Frontier
Electric foamy flyer
fly Frontier's Avatar
Chandler, Arizona
Joined Apr 2010
http://www.graysonhobby.com/catalog/...teb-p-980.html <------------- Best motor for Hawk sky
fly Frontier is offline Find More Posts by fly Frontier
Old Nov 26, 2010, 10:31 PM
Joined Aug 2010
I'd rather not order from them. I've had bad experiences with them.
Old Nov 26, 2010, 10:48 PM
Chandler, Arizona
Joined Apr 2010
find it else where
Old Nov 26, 2010, 10:50 PM
Joined Aug 2010
Yeah. I've been looking, but couldn't find a thing.
Old Nov 27, 2010, 01:54 AM
Dakrat is offline
Dakrat's Avatar
Anchorage
Joined Dec 2005
Are you talking the park 180? This is not the same motor... The meter I'm talking about is a multimeter it measures volts, ohms, etc...
Old Nov 27, 2010, 08:45 AM
Joined Aug 2010
What size is this motor and where can I get that meter?
Old Nov 27, 2010, 05:03 PM
Dakrat is offline
Dakrat's Avatar
Anchorage
Joined Dec 2005
For a meter look here, http://shop.ebay.com/i.html?_nkw=dig...=p3286.c0.m359
As for the motor, I'll leave it like this, for a 2 lb you need something that pulls between 200-300 watts. The usual rule is 100 watts per lb for leisurely flying 150-175 per lb for sport flying so get a motor that mounts with that in mind. Also you will need a higher kv motor to fly on a short prop.2000-3000kv, you should concider a wattmeter to help you decide motor/prop setups.
Dak
Old Nov 27, 2010, 06:45 PM
Joined Aug 2010
Is this alright? http://hobbyking.com/hobbycity/store...idproduct=5203
Old Nov 27, 2010, 09:25 PM
rcjetflyer2 is offline
Find More Posts by rcjetflyer2
Joined Nov 2009
You said the motor cuts out at half throttle? That happened to me but it wasn't the motor, it was the esc. Maybe when the motor flew off it pulled a wire out of the esc? If you have a spare motor, I recommend hooking it up to the esc and see what happens...
rcjetflyer2 is offline Find More Posts by rcjetflyer2
Discussion Sky Surfer/Hawk Sky. Skribbles Foamies (Kits) 12 Jan 18, 2012 05:49 AM
Discussion Hawk sky motor problem - see videolink daugaard Power Systems 3 Jun 11, 2011 03:16 PM
Discussion Dynam Hawk Sky battery upgrade ravenv12 Beginner Training Area (Aircraft-Electric) 1 Nov 16, 2010 05:23 AM
Video my Dynam Hawk Sky ravenv12 Electric Plane Talk 0 Nov 15, 2010 01:32 AM
Discussion Dynam Hawk Sky replacement parts?? and crash :( ravenv12 Beginner Training Area (Aircraft-Electric) 4 Oct 31, 2010 05:13 AM
