Old Jun 10, 2016, 06:50 AM
Olgidos is offline
Find More Posts by Olgidos
Joined May 2016
Plane EPP surface
Hello there
I own a BORMATEC NINOX flying wing. It's made of EPP. So the surface is very rough with many pores.
Do you think laminating the wing would improve the flying performance?
Olgidos
Olgidos is offline Find More Posts by Olgidos
Old Jun 10, 2016, 12:35 PM
mtgtopdeck is offline
Find More Posts by mtgtopdeck
United States, CA, Cupertino
Joined Feb 2009
It looks like the epp was formed in a wing shaped mold. It will probably have a higher density and a better surface finish than wire cut epp.
Because of this higher density I would first apply some Scotch Extreme Tape to the leading edge to prevent the epp from tearing if you ever have to land softly into a tree/bush. and then cover the wing with thin laminate.
mtgtopdeck is offline Find More Posts by mtgtopdeck
Old Jun 11, 2016, 06:15 PM
Olgidos is offline
Joined May 2016
Sadly it isnt molded like the ritewing drak =\
And tape dont really hold on this rough Surface ...
Old Jun 11, 2016, 06:42 PM
hard line is offline
Find More Posts by hard line
pull up -- PULL UP!!!
Joined May 2012
Many tapes don't stick well to raw EPP. Scotch Extreme is an exception, so don't give up on tape unless you've tried that exact tape. Not knowing where you live, perhaps that's not an option.
As to your original question, I wouldn't expect the typical flying wing to perform notably better just because of covering. But they survive impacts a great deal better. However, I'm not familiar with your model.
hard line is offline Find More Posts by hard line
Old Jun 12, 2016, 06:06 AM
Olgidos is offline
Joined May 2016
I am from Germany =)
But i noticed that raw EPP is extremely resistent again impact you can crash again and again and again and you won't even notice a scratch.
My hope was to get some extra speed out of this plane my max was around 80 kmh full throttle downwards =\ but then it starts to bump around in the air
Old Jun 12, 2016, 10:27 AM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Laminating the wing will keep the EPP clean and smooth out the surface.
You need to use Ultracoat or other low temp laminate
Most laminate won't stick to EPP without a spray adhesive like 3M77.
Laminate and spray adhesive does add some weight so make sure it doesn't change your CG.
Spray the wing and let it dry before ironing on the laminate.
There is some clear laminate that will stick without a spray adhesive available on the market.
Lee is offline Find More Posts by Lee
Sold Great Planes CG Machine and Robart Surface Deflection Gauge Stone1295 Aircraft - General - Miscellaneous (FS/W) 0 Apr 11, 2016 11:59 PM
Discussion EPP plane... solarfilm and New Stuff and paint? cityevader Slope 5 Nov 05, 2015 09:20 PM
Sold NIB – Aerobeez 48" Extra 330 EPP Full Fuse Electric Plane JimG_AZ Aircraft - Electric - Airplanes (FS/W) 3 Oct 21, 2015 10:31 AM
Discussion Where can i buy EPP Arrow V3 4D plane? RogerCL 3D Foamies 5 Sep 13, 2015 09:29 PM
New Product Winner's Model 48in Extra 330LX SEPP - stiff EPP plane with airfoiled tail surfaces groovejet 3D Foamies 643 Sep 08, 2015 05:05 PM
