Old Jul 28, 2015, 04:35 PM
djdobbins is offline
Find More Posts by djdobbins
Joined Jul 2015
Electric Motor Recommendation
I have a small glider that I want to convert to a motor glider. The wing span is 58", ~348 square inches. The estimated total weight with motor, battery and everything should be 18 ounces. The max motor diameter should be 7/8". I am looking for suggestions to select a motor, ESC, battery and folding prop combination to power this glider.
Dan
djdobbins is offline Find More Posts by djdobbins
Old Jul 28, 2015, 08:09 PM
scirocco is online now
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
I used to fly an EasyStar with a Keda 20-40-31L inrunner (20mm OD). A 6x3 prop, 3s 850 pack and a 10-12A ESC will give you adequate climb.
scirocco is online now Find More Posts by scirocco
Discussion I need a recommendation for electric motors Warthog_Fan Dock Talk 4 Jun 18, 2015 08:09 AM
Discussion SB/XC electric conversion recommendations dbeach Cross Country Soaring 16 May 30, 2015 06:29 PM
Discussion 1/4 cub airplane electric motor recommendation wanasea Glow to Electric Conversions 3 Feb 17, 2015 08:21 PM
Discussion Sig Somethin Extra Electric Conversion- Motor Recommendation Flyrc67 Glow to Electric Conversions 2 Nov 03, 2014 10:19 AM
Question Electric Motor/ESC recommendation Nigel Watson Power Systems 1 Feb 05, 2014 01:56 AM
