Old Mar 14, 2013, 01:10 PM
Pelle57 is offline
Find More Posts by Pelle57
Joined Sep 2010
Length of main shaft UH-1
Hi!!
I want to know how to get the right length of main shaft on a Uh-1 (800)
I try to look at pics of real helis and try to figure out the question but it's not easy.
If someone have a good idea, data or a good pic so please help me.
I try to look at pics and if compare with centerpoint of the tail rotor and draw a line which meet the 90 degrees angle of the main shaft, where are the level of the main blades then?????
So the answer not need to be in millimeters, just want to know the level of main rotor blades compared to tail rotors centerpoint.
Does anyone understand how I think???
I am going to have the shaft produced for me so I want it to be correct.
Best regards
Pelle57 is offline Find More Posts by Pelle57
Old Mar 14, 2013, 01:41 PM
madphil is offline
Find More Posts by madphil
Lets get the HUEY up
madphil's Avatar
bolton england
Joined Jan 2009
I think you will need to get your fuselage , side mounting frames then offer everything up and see where it fits and looks right the main shaft can then be worked out from there
madphil is offline Find More Posts by madphil
Help! Carson "black phantom" shaft length Ace192 Off-road Cars 0 Feb 26, 2013 07:36 AM
Help! Walkera df 5#5 : how much for main carbon shaft length and diameter ? barney 69 Coaxial Helicopters 3 Mar 17, 2008 07:02 PM
Wanted Swift tail shaft,main blade grips, main gear and 3bearing main shaft Matthew Cotten Aircraft - Electric - Helis (FS/W) 0 Mar 01, 2008 03:10 PM
Discussion HB CP2/Blade CP Main Shaft length Stryker Ace Micro Helis 0 May 08, 2006 03:41 PM
MAIN Shafts Lengths ?? helione Micro Helis 1 Dec 24, 2002 04:17 PM
