Old Feb 07, 2013, 05:02 AM
rccsofla is offline
Find More Posts by rccsofla
Joined Dec 2011
rx battery
I have a Great Planes Escapade that was put together with parts from another plane.They are a futaba receiver and futaba servos#s3004.I noticed the receiver battery pack is not holding a charge as long as it should.I would like to replace it.The present one is a 4.8 volt.Should I replace it with another 4.8 volt or up to a 6 volt?Thanks for any replies.
rccsofla is offline Find More Posts by rccsofla
Old Feb 07, 2013, 05:28 AM
Lifer is offline
Find More Posts by Lifer
Kansas City
Joined Apr 2010
The first time you lose a plane because of a weak battery will be the last time you ask this question. Never be loyal to a battery. Compared to the cost of the plane with all the equipment on board, plus your time, the cost of a battery is minor. Get a new one!
Lifer is offline Find More Posts by Lifer
Old Feb 07, 2013, 05:42 AM
whiskykid is offline
Find More Posts by whiskykid
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
6v's is great and all, but not needed!
if you like ta tear it up, then by all means, step-up ta a 1600ma 6v!
you will have alot of poeple tell ya ta go A123's which I spose would be fine, but if you don't have the chargers, not needed!
whiskykid is offline Find More Posts by whiskykid
Old Feb 07, 2013, 05:44 AM
rccsofla is offline
Joined Dec 2011
I know that it needs to be replaced.Just wanting opinions on the servos voltage.Will a 6 volt battery pack burn them out earlier than a 4.8 volt or will the 6 volt be fine?
Old Feb 07, 2013, 05:45 AM
rccsofla is offline
Joined Dec 2011
If I go with the 4.8 volt,what mah do you recommend?
Old Feb 07, 2013, 05:55 AM
team sleprock
whiskykid's Avatar
Joined Dec 2009
1400 ta 1600 would be plenty for all day flying!
and them futabas are just fine with 6v.s I run 6v on most of my planes, with everything from s148's too 3004's never had a problem!
Old Feb 07, 2013, 06:07 AM
cliffh is offline
Find More Posts by cliffh
Gustavus, OH
Joined Oct 2007
I've been using 6v with my Futaba and 3004's with no problems at all.
Cliff
cliffh is offline Find More Posts by cliffh
Old Feb 07, 2013, 07:18 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
I assume that you guys are talking about 6V nicads or nimhs, right ?
If so, do you use a regulator ?
I may have been in this hobby since the Ice Ages, but I've been reluctant to make the move from 4.8 nicads, let alone jump to 6 volts. LOL
TomCrump is offline Find More Posts by TomCrump
Old Feb 07, 2013, 08:08 AM
Pixar is offline
Find More Posts by Pixar
United States, IA, Iowa City
Joined Oct 2011
LiFe
Pixar is offline Find More Posts by Pixar
Old Feb 07, 2013, 08:23 AM
team sleprock
whiskykid's Avatar
Joined Dec 2009
in my case Tom, I am using 5 cell ni-cads! use the same chargers been charging with since the 80's , as far as I know futaba recievers and servo's have been 6v compatible since then! and as all I have ever used is futaba till this last go around in the hobby, I have been upgrading all my old batt's to 1600ma 6v ni-cads!
and no regulators!
Old Feb 07, 2013, 08:35 AM
Lumpy05 is offline
Find More Posts by Lumpy05
Lumpy05's Avatar
United States, IN, Bloomington
Joined Jan 2012
I have been using these LiFe Rx batteries and have been very happy. Unlike lipos that can be stored at full charge. Picture on hobbyking is wrong the last batch I received came with two jr connectors and one balance plug. They are lightweight and easy to place in most models. And best of all the price is great, I have only lost one out of 6 because I left my Rx turned on over night and killed the battery. Otherwise they are great, I use no voltage regulator just straight into the switch to the Rx.
http://hobbyking.com/hobbyking/store...ver_Pack_.html
Lumpy05 is offline Find More Posts by Lumpy05
Old Feb 07, 2013, 08:54 AM
Pixar is offline
Joined Oct 2011
LiFe = Awsome
Old Feb 07, 2013, 09:02 AM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
Thanks.
I think that I will gradually replace my batteries to 6 volt. My 4.8 packs are dying, so it's time to update.
The Hawkeye and the Hoosier seem to like the LiFe batteries, but, for now, I'll stick with the more traditional batteries, as does Whisky.
Old Feb 07, 2013, 01:03 PM
tacx is offline
Find More Posts by tacx
tacx's Avatar
United States, MI, Romeo
Joined Apr 2009
Your servos are safe. I have six planes with Futaba s3004s and s148s servos. They all are running on A123 6.6 volt (7.2 volts fully charged) batteries. I use 1100mah in my 60 to 90 size planes and 2300 mah in my 150 size planes.
Since I changed to A123s I have never charged a battery at the field.
tacx is offline Find More Posts by tacx
Old Feb 07, 2013, 02:25 PM
FloridaFlyBob is offline
Find More Posts by FloridaFlyBob
FloridaFlyBob's Avatar
United States, FL, Fort Myers
Joined Nov 2011
I've got life batteries on a H9 hellcat and li-on batteries in my 1/5 wayco. Life batteries are nice you won't need a regulator but when they are discharged, they drop fast so you need to monitor how much mah you use each flight so they don't get too low
FloridaFlyBob is offline Find More Posts by FloridaFlyBob
Sold Hitec Optic 6 72MHz w/Spectra, 4 Rx, 3 batteries - $85 OBO shipped abusleme Aircraft - General - Radio Equipment (FS/W) 5 Feb 14, 2013 12:44 AM
Question Opto ESC with 2s lipo RX battery GTOEric Power Systems 4 Jan 26, 2013 03:41 PM
For Sale Associated Reedy LiPo Rx Battery 7.4V 2100mAh ATCH Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jan 07, 2013 08:38 AM
For Sale Rx and TX batteries GeetarJoe Aircraft - General - Radio Equipment (FS/W) 0 Jan 02, 2013 08:10 PM
Sold Plug-N-Play FPV Setup: Cam/TX/RX/OSD/Battery/Cables All Included DJO FPV Equipment (FS/W) 6 Jan 02, 2013 01:39 PM
