Old Jun 18, 2012, 02:34 AM
doo is online now
doo
Find More Posts by doo
doo
doo's Avatar
United States, WA, Raymond
Joined Dec 2002
Help!
Motor / Prop recommendation for e-Bird of Time Conversion
Looking for recommendations on what motor/prop to use on a BoT e-Conversion.
Thinking that an e-BoT with spoilers would make for a good addition to the fleet.
Likely would go with the ARF and mod as needed. Spoilers should be easy to add. Not sure of what motor/prop and spinner combo to use.
I would like a combo that will provide a "good" climb. Don't need a 90 degree climb, but don't want to have an anemic climb either!
looking for a combo that will balance the BoT well. I don't like additional weight just to get the CG!
Let me know what motor/prop combos have worked well for you!
doo is online now Find More Posts by doo
Old Jun 18, 2012, 06:53 AM
raed5 is offline
Find More Posts by raed5
raed5's Avatar
Orlando "Buzzards" FL
Joined May 2002
Currently using a Turnigy 35-42 with a Aeronaut Cam 11X8 with a 20C 3000 mah 3 cell. Put both fuse servos under the canopy with a bellcrank driving the full flying stab (The ARF has you put the elevator sero in the tail)
Still had to add a few ounces of nose weight!
The motor/prop combo gives it a good climb, barley enough for 150 meter within 30 seconds. I am switching to their 35-48 motor, Aeronaut cam 12X6.5 and 45C 2650 battery in hopes I can get a better climb rate, I will report back when I fly it.
Raed
raed5 is offline Find More Posts by raed5
Old Jun 18, 2012, 04:13 PM
olythom is offline
Find More Posts by olythom
United States, WA, Olympia
Joined Oct 2009
Eflite power 25 (870kv version) with a 14x8 or 14x10 on a minimum 75a ESC. Works awesome.
olythom is offline Find More Posts by olythom
Old Jun 18, 2012, 04:38 PM
Leadchucker is offline
Find More Posts by Leadchucker
AMA7224 LSF1832
Leadchucker's Avatar
United States, DE, Seaford
Joined Sep 2008
I used an older Rimfire 35-48-1300 with a 11 x 7 Aeronaut folder, a 2250 maH 45C 3S and a Castle ESC. Servos were in the forward part of the wing bay with bell crank setup for horizontal stab. Needed about 1 1/2 oz. of in nose to get CG. It was the same weight as the advertised for the string launch job.
Leadchucker is offline Find More Posts by Leadchucker
Old Jun 19, 2012, 02:34 PM
WallsRoofing71 is offline
Find More Posts by WallsRoofing71
United States, NC, Raleigh
Joined May 2010
add a 5000 4s 45c battery to this and it will go. I have a R2 Hobbies Gliderman 3m bird I have the above in it and a 13/7 prop the Gliderman is heavy but it will go up fast at a 70-80% angle
http://www.r2hobbies.com/rc-aircraft...sailplane.html
WallsRoofing71 is offline Find More Posts by WallsRoofing71
Old Jun 20, 2012, 08:30 AM
Mark Anderson is offline
Find More Posts by Mark Anderson
Mark Anderson's Avatar
United States, WA, Tumwater
Joined May 2010
I am running the set up that OLYTHOM suggested. I normally range out level for 15 seconds then pull up to about 80 degrees and hit 200m in 25-27 seconds with a 14-8. 14-10 is really fast and will draw around 75 amps, the 8 pitch is around 60 amps. It has more then enough power. A 15 would be adequate but will require weight. I have modified 5 ARF Birds for club members. All have added spoilers. I modified the fuses so they would be round at the spinner location. It is a simple mod, does require a small amount of glass work.
Mark
Mark Anderson is offline Find More Posts by Mark Anderson
Old Jun 21, 2012, 01:58 PM
doo is online now
doo
doo
doo's Avatar
Joined Dec 2002
Thanks everyone for the replies. Very helpful.
I think I will go with the eflite 25, rather than balance out with lead.
Mark, would you have any pics of the nose mods? I would be interested in some pics, and maybe a description of how it was done.
Mark
Old Jun 22, 2012, 08:35 AM
Joined May 2010
I did take some pictures and plan to write up a how to, Just no time lately. I will try to put something together in the morning.
Mark
Old Jun 22, 2012, 09:18 AM
Joined May 2010
One would think that the maker of the BOT would have got an E version with flaps out on this great bird by now Just sayin LOL. I know that Esprit has this out but it would be so cool if the BOT was out like this.
http://www.espritmodel.com/albatros-3s-e-arf.aspx
Old Jun 23, 2012, 09:49 AM
Joined May 2010
I posted pictures and a description of the mod I did. http://www.rcgroups.com/forums/showthread.php?t=1677576
Wanted The pair of dihedral braces for a Bird of Time wing MuscleCBT Aircraft - Sailplanes (FS/W) 8 May 11, 2012 06:14 AM
Question E-flite Ultimate 20-300 Prop Recommendations flyingflipper Parkflyers 4 Mar 28, 2012 06:43 PM
Help! E-Bird of Time - Canopy attachment? Generic Member Sailplane Talk 5 Dec 15, 2011 06:39 AM
Question what size motor to convers speed 400 e-plane to glo Thermalin Fuel Plane Talk 4 Aug 01, 2007 11:53 AM
can anyone recommend a moter for my shogun with Good power hihptsi Mini Helis 9 Sep 27, 2005 03:19 PM
