Old Jul 25, 2014, 03:16 PM
Tmark65 is offline
Find More Posts by Tmark65
Tmark65's Avatar
Greece, Central Macedonia, Thessalonika
Joined Mar 2006
Originally Posted by sailjester2811 View Post
Hey Tmark,
My comment on an X3 was kind of a joke. The updates to the old airframe are nice but it is still an X2.
Jody
It's OK !!!
Does anybody has the new electric fuse already set up ?
I'm interested to see how people has done, and a question
Servos in front and aft of motor and ESC or at the back of motor, ESC and battery ?
For the time being I started building the wings since I'm done with the wire harness
Tmark65 is offline Find More Posts by Tmark65
Old Jul 25, 2014, 04:34 PM
beach1 is offline
Find More Posts by beach1
Setup
I have the e fuse for the X2. My setup from front to back is Neu 1107 1.5 motor with Esc behind on side with 3 cell 1300 ma lipo on opposite side with Cam and receiver back behind under wing saddle. Mount servos as far back as you can get them in fuse under servo cutout. Good luck
beach1 is offline Find More Posts by beach1
Old Jul 26, 2014, 12:38 AM
snoze88 is offline
Find More Posts by snoze88
Marco Generali - italsoaring
snoze88's Avatar
Cremona, Italy
Joined Nov 2010
Originally Posted by Neil Jones View Post
The new tail has a huge elevator surface. At the root the elevator measures 60mm and the fixed portion of the stab 70mm.
It has almost the same area as the classic 3.8m xplorer elevator
snoze88 is offline Find More Posts by snoze88
Old Jul 26, 2014, 03:28 AM
Neil Jones is offline
Find More Posts by Neil Jones
Joined Jul 2012
Yes Marco I have compared it as well. Fin/rudder area also very similar to previous models although rudder area bigger than X1.
I like it. It's clever.
Pink foam cores with spread tow skins I think. Stab weighs 46g
Neil Jones is offline Find More Posts by Neil Jones
Old Jul 26, 2014, 03:40 AM
dutchsoarer is offline
Find More Posts by dutchsoarer
Joined Oct 2006
Originally Posted by Tmark65 View Post
It's OK !!!
For the time being I started building the wings sins I'm done with the wire harness
In my second build I wanted room for plenty of ballast, so no receiver under the wings as I did in my first build. Difficult acces to only 1 ballast pipe lying on the bottom of the fuse.
I managed it by making a new servoplate for rudder and elevator servo and lying the elevator servo Futaba 3150 flat with a mounting from servo-rahmen.de.
Small rudder futaba 3156 cross mounted in front of the elevator servo. Receiver is now under the elevator servo. Leaving enough empty space for 2 ballast pipes ( # 1 kg) and easy changes.
PeggyPeper 2221/8; Castle light 75A as close as posible behind the engine mounted with velcro to the side of the fuse, a SLS 1000 45/90 sideways as close as posible behind the PP. The space you need for easy change of the battery gives you the position of the servoplate.
Flying CG now at 115, stillair 118 mm, changing it by moving the battery ( velcro at battom of fuse). No nose weight needed.
I use foam stabs and a 80gr engine in my first Xplorer. Weight saving 40 gr.
Hope I made it clear. Succes, it is easy
Jan
dutchsoarer is offline Find More Posts by dutchsoarer
Old Jul 26, 2014, 02:48 PM
Tuomo is offline
Find More Posts by Tuomo
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
Increase is stability is surprising. Really big change -> totally different trim.
Tuomo is offline Find More Posts by Tuomo
Old Jul 28, 2014, 11:52 PM
Tmark65 is offline
Tmark65's Avatar
Joined Mar 2006
Jan
Jan thank you very much !!!
My thinking is to go with your setup.
I have the new fuse, 160 grms aqll carbon Vtail.
I'm not intending to use ballast tube.
My servos are MKS, for Vtail and AIL 6100's, 6125minis for flaps.
I'm flying with Vtails .,, and a little heavier batteries. I am using the TP1300-3SPF70 that are long .... but light with some extra mAh for my long flights. ESC is a Koby 55LV and a Peggy Pepper 2221/8, prop 14x10. My receiver is a Multiplex RX-7 Compact and my plan is to be installed along with the ALTimeter in between wing and servos on a velcro stick.
I am wondering with your layout if I can have the CG to 120 without extra weight.
I wish I could see a photo of yours
Best Regards
Tasos
Old Jul 29, 2014, 01:34 PM
Joined Oct 2006
Best Regards
Tasos
Hello Tasos,
I am flying + tail, so no comparison for me and I was very keen to use ballast. I live in a windy country.
When your intention is not to use ballast, why make it yourself difficult? Then you have plenty of space to play with the lay-out and reach sp 120mm .
With my lay-out you will probably be a little nose-heave because of the V-tail. So leave enough space to the servoplate to play with the battery.
Maybe for your comparison, the foam stabs weights 41 gr including pins.
Because of the max "weight" I am driving the peggy with RF 16 * 8.5 small. Starting when empty with no more than 50% of available motorpower.
Or didn't I get your question right
Jan
Old Jul 30, 2014, 03:50 PM
Tmark65 is offline
Tmark65's Avatar
Joined Mar 2006
Hello Tasos,
Jan
Jan,
Everything is clear enough now ... !!!
I got the idea and I'm ready to go for the fuse setup !!!
Thank you Jan !
Old Aug 19, 2014, 10:47 AM
Bernd Brunner is online now
Find More Posts by Bernd Brunner
dare to thermal
Mannheim, Germany
Joined May 2004
4mX2 : ballast or not to ballast, thatīs the question?
When do you start to ballast your 4m Xplorer MkII? Depending of windspeed or other criteria?
Today we had appr. 8-12m/s wind. How much ballast would you use?
Bernd
Bernd Brunner is online now Find More Posts by Bernd Brunner
Old Aug 19, 2014, 12:30 PM
webbsolution is online now
Find More Posts by webbsolution
Win=span\massXpractice+lu ck
webbsolution's Avatar
Joined Jul 2007
Thats harder to answer -
Wind is only one factor - lift is the main factor for me examples:
12 MPH in no lift --- lowest ballast I can get and still move forward avoid sailplane reverse transmission.... The X2 is pretty good in wind. In low lift you dont want to crush your mind sink performance...
12MPH in high lift - big cycles (big lift big sink) - more ballast because you have to keep more energy in the model to survive the sink invariably hitting you on the way home...
Its all about the lift for me.
Also the starting weight of your model is a factor - If you have a 72 oz X2 4.0 you are fine without ballast to 12 MPH in most situations. If you started at sub 60 - well thats different right t?
webbsolution is online now Find More Posts by webbsolution
Old Aug 19, 2014, 06:01 PM
Hostage-46 is offline
Find More Posts by Hostage-46
Hit my smoke....
Hostage-46's Avatar
United States, TX, Highland Village
Joined Jan 2003
That's 17 to 26 MPH... a good blow indeed. I'd load it ALL up in those conditions.
Hostage-46 is offline Find More Posts by Hostage-46
Old Aug 21, 2014, 09:18 PM
stefanoc2 is offline
Find More Posts by stefanoc2
stefanoc2's Avatar
United States, TX, Houston
Joined Aug 2006
25 mph on an X2 will need 24 to 30 oz. Mine start at 71 oz. empty. INMO.
Stefano
stefanoc2 is offline Find More Posts by stefanoc2
Old Aug 21, 2014, 09:23 PM
Joined Jul 2007
28 MPH = 12.5 m/s ??
Yea I was at 99 oz in SA - thats pretty close - I misread the original post thining 12 mph - not meters -
Old Aug 24, 2014, 08:30 PM
schrederman is offline
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
Well, today I flew my 4M X2 and I'm getting better with it. That being said, today was almost an idiot-proof day. (No Dan... not Marine-proof, either...) The lapse rate was a little long so the thermals were spaced out a bit, but I had some climbs that were pretty amazing. Still like my 3.7M X1 a bit better. I might need to work a touch more on my setup... but all in all... I'm gettin' there.
schrederman is offline Find More Posts by schrederman
New Product 0.9g Retracts Mk.II *NOW LASER CUT* Yellow Baron Scratchbuilt Indoor and Micro Models 2 May 29, 2012 04:38 AM
Wanted Hangar 9 Spitfire MK II 60 Parts cessnajfb Aircraft - Fuel - Airplanes (FS/W) 2 Mar 11, 2012 08:47 PM
Sold *Price Reduced* Saito FA-45 MK II sscherin Aircraft - Fuel - Engines and Accessories (FS/W) 1 Mar 11, 2012 12:06 PM
For Sale: Carl Goldberg Classic Falcon 56 mk II and Skylark 56 mk II kasra Aircraft - Fuel - Airplanes (FS/W) 2 Nov 22, 2004 03:35 AM
