Old Jan 21, 2015, 09:00 PM
Joined Aug 2014
Question
best foam for cutting and best way to wire cut wings
I just gave a go at cutting my first pieces of foam with a home made foam cutter and that fancy foam cutter wire. one thing I noticed is you cant go to hot and you have to move steady and even.
I found a sheet of foam in an alley left for garbage and it turns out its very sandable . it sands to a smooth finish I wanted to make 20 " wing extentions for my radian so I was going to glue two layers together so I can cut a half round groove in each layer for a carbon fiber tube, I also bought a pack of foam sheets from home defect and the foam density does not seem appropriate for the job, Its to flexible. so I thought this looked like a good section of the forum to ask for help. when I cut these wings I would like to wind up with smooth surfaces and no need for sanding bit if need be I can cut my airfoil slightly thicker to alow for material to sand.
Any info on whrer to get good quality foam would be great .
thanks
flying ferret is offline Find More Posts by flying ferret
Old Jan 22, 2015, 03:54 AM
Staffs, UK
Joined Nov 2003
It would help if you said where you are. I know where I get foam but unless you live near me that's not likely to help.
BTW I've never managed to cut foam wings that didn't need at least a little sanding to get rid of bumps and whiskers.
Steve
slipstick is online now Find More Posts by slipstick
Discussion Hot wire cut foam wing services Airbrushjake Giant Scale Airplanes 6 Oct 23, 2014 04:30 PM
Question Best wire for foam wing cutting? MattyB Slope 17 Feb 18, 2013 09:34 PM
For Sale White Spyder Foam - the best hot wire cutting foam there is for DLG wings Sled Driver Aircraft - General - Miscellaneous (FS/W) 3 Mar 16, 2009 09:13 PM
For Sale White Spyder Foam - the best hot wire cutting foam there is for DLG wings Sled Driver Aircraft - Sailplanes (FS/W) 2 Mar 15, 2009 08:09 PM
