Turnigy Mobius 2-Axis Gimbal
Finally a gimbal for the Mobius Camera
Stabilize Your Mobius Footage
Finally there is a Mobius camera gimbal, the Turnigy Mobius 2-Axis Gimbal. This compact gimbal design allows you to mount your Mobius camera to it and will provide roll and tilt stabilization. It's a great way to take your footage to the next level. It uses custom wound AX 2206 brushless motors and the Tarot 2 axis BGC board to control it all. The frame size is 76x67x100mm and weighs in at 160g.
Check out the Turnigy Mobius 2-Axis Gimbal at HobbyKing.
Old Sep 17, 2014, 07:32 PM
Quad fun for everyone!
RC2211's Avatar
United States, WI
Joined Oct 2013
I think HobbyKing went in the right direction with this gimbal. Although, they could make some changes.
1) There is no space for the AV out cable (I do not use it but others want the live gimbal video ability).
2) Make it somewhat lighter. I don't think the gimbal really needs that size of a motor, so HK could custom manufacture a smaller gimbal motor to reduce weight.
3) possibly make a forward-facing version for certain types of FPV quads.
Nothing stands out beyond that yet. Price is also good. We will have to wait and see what others say about it when they actually fly with it.
RC2211 is online now Find More Posts by RC2211
Old Sep 18, 2014, 10:31 AM
Joined May 2014
Looks interesting.
wilcamach is offline Find More Posts by wilcamach
Old Sep 18, 2014, 11:25 AM
Joined Nov 2013
They answered to the first point in the comments on their product page, but I do not understand it fully. Please have a look because I'm interested in this product for my WL TOYS V303 (hope that it fits (?) ).
newtoon is offline Find More Posts by newtoon
Old Sep 18, 2014, 04:59 PM
resistgravity's Avatar
United States, TN, Johnson City
Joined Feb 2011
It looks like this is the cable they're saying to use with it. It looks to be a tight fit, but I guess it will work if they're recommending it.
http://hobbyking.com/hobbyking/store...ch=258000120-0
resistgravity is offline Find More Posts by resistgravity
Old Sep 21, 2014, 03:26 PM
The Valkman's Avatar
Joined Nov 2011
In regards to 3 I would say you could just mount it in the forward position and recalibrate it if needed. Lots of FPV quads use "clean frames" these days anyway so you could probable hard mount it if your rig is smooth. I would buy it in a heart beat if I was in this area.
The Valkman is offline Find More Posts by The Valkman
Old Oct 01, 2014, 01:02 AM
just4funxwing's Avatar
United States, CA, Salinas
Joined Nov 2013
Live feed problem solved...
Works great!
I wanted to mount this on the front of my discovery but the imu does not like to be mounted horizontal. Maybe another firmware option?
For now I will have to mount it as designed I guess.
just4funxwing is online now Find More Posts by just4funxwing
Old Oct 01, 2014, 01:15 AM
Shut up and fly
papabatman's Avatar
United States, CO, Firestone
Joined Jun 2008
how did you place gyro board.
papabatman is offline Find More Posts by papabatman
Latest blog entry: Fpv summit
Old Oct 01, 2014, 08:07 AM
United States, WI, Schofield
Joined May 2011
Stability Issues
Just got my gimbal assembled and have the jitters mostly on the tilt axis. Board came with no firmware installed took me all afternoon on the Tarot website to get the firmware installed and the HK config. files loaded. Numerous software crashes on my Windows7 desktop. Hardware quality seems ok. Played around with gains on the software to try and stop the jitters but no joy so far. Anyone else with these issues?
Tscience is offline Find More Posts by Tscience
Old Oct 01, 2014, 08:15 AM
Joined Nov 2013
Placed so that the power lead is on top.
The gimbal is very smooth...
I can get it to jitter if I really throw it around, but one smooth movement and the gimbal recovers and is smooth again. For the price, I am very pleased.
Old Oct 01, 2014, 09:44 AM
Joined Nov 2013
I stand corrected, the imu mounting orientation is irrelevant and can be mounted in any orientation. Even moved around while the gimbal is powered up with out any effect.
So this gimbal can be mounted forward facing, as soon as make a mount for it!
I am happier now than before!
Old Oct 01, 2014, 09:27 PM
Shut up and fly
papabatman's Avatar
Joined Jun 2008
HELP
need a link to the install drivers the one's i found don't work
Old Oct 02, 2014, 12:40 AM
Shut up and fly
papabatman's Avatar
Joined Jun 2008
magic video
Mobius Brushless Gimbal Product Profile - HobbyKingLive (12 min 19 sec)
Old Oct 02, 2014, 10:11 AM
_Milo_'s Avatar
United States, ID, Pocatello
Joined Apr 2013
Change the motor settings on the tilt motor, its easiest done when the gimbal motors are powered up, hit write and see how the motor reacts to new settings. Keep lowering until it stops buzzing and runs smoothly. Change the polar and power settings, Polar (motor poles?) makes a bigger change, Power less so, for me I think I ended up with Polar=6 Power=30 (not sure on power maybe a tad higher.
If you go too low on the motor setting if you move fast the tilt motor will not perform right, to high and micro vibrations, even higher and buzzing and horrible jittering.
The roll motor worked find with HK settings.
Also had numerous crashes with software. Good luck.
_Milo_ is online now Find More Posts by _Milo_
Old Oct 02, 2014, 08:24 PM
_Milo_'s Avatar
Joined Apr 2013
Mounted upside down for now, eventually will set it up forward facing but I want to have a quick detach, because I don't always want it on. The way I have it mounted I can take it on and off with ease.
Just a quick look at the hobbyking mobius gimbal mounted upside down, easy on, easy off. (2 min 42 sec)
For Sale New Tarot 2-Axis Brushless Gimbal w/ Mobius Adapter ricknoon FPV Equipment (FS/W) 5 Nov 03, 2014 01:49 PM
Sold 2 Axis Mobius Gimbal irun4fundotca FPV Equipment (FS/W) 4 Aug 10, 2014 10:50 PM
Sold 2 Axis Mobius Gimbal silver2 FPV Equipment (FS/W) 3 May 24, 2014 11:37 AM
Discussion can i add another 2 axis gimbal stabilizer to my MK 2.2 servo ports? RogerCL Multirotor Talk 1 Sep 19, 2013 04:15 PM
