Old Today, 02:43 AM
Joined Jan 2014
Originally Posted by dankar04 View Post
Well as soon as I get some abition going #2 MCP will be bl. Over 200 fights on heli and still flying fine on original motors. So for those who say lube is waste of time and using Tri-flow..phooie ! I have has bl unit for close to a year and tired of looking at it in parts bin.
I have read your posts on using tri-flow and the the model train lube and think it is a great idea. Did you break in your motor B4 you started or just take it easy for the first half a dozen flights?
helircguy99 is offline Find More Posts by helircguy99
Old Today, 06:00 AM
Owner1
United States, WA, Seattle
Joined Mar 2011
Just another data point to assist your decisions on heli maintenance. I have a Master CP with well over four hundred flights on it. The first 120 flights were with the original main motor, and the remainder are with a single Walkera replacement. The tail motor is still original. I don't use any lube as I don't like the dirt it attracts, and I always fly between 3-6 batteries back to back, with no cool down. I don't even re-bind the heli, as I swap them in less than 30 seconds and keep on flying. There is no temperature difference between the first and the last battery run.
Good luck, and enjoy your MCP.
Owner1 is offline Find More Posts by Owner1
Old Today, 06:51 AM
Tucson, Az
Joined Feb 2007
I run motor and few times just under flight speed for a minute or two. Let cool and do this a few times. Then fly it easy several times and then good to go. I use heat sink from Bang good. I do not endorse back to back packs with out cool down. Both my Masters have over 200+ flights on original motors. Some wing nuts say just go back to back and all is well. Maybe for them but not the way i roll.
dankar04 is online now Find More Posts by dankar04
Discussion Blade Mcpx v1 v2 vs Walkera Mini Cp vs Genius Cp vs solo pro 100 3d f.a.r.m.e.r Micro Helis 118 Jan 22, 2015 02:51 AM
Sold Walkera Genius CP with Devo 6 King.7200 Aircraft - Electric - Helis (FS/W) 2 Feb 02, 2012 11:52 AM
Sold Walkera Genius CP Brushless version 3D with 6-axis gyro Devo stretch1100 Aircraft - Electric - Helis (FS/W) 3 Jan 25, 2012 09:37 AM
For Sale Walkera Genius CP with DEVO 6 bymannan Aircraft - Electric - Helis (FS/W) 0 Nov 07, 2011 08:57 AM
New Product Walkera 6-Axis gyro UFO5# (new version with Camera~) DLY Micro Helis 6 Oct 29, 2011 02:48 PM
