Old Mar 18, 2014, 10:39 PM
Scratch builder
Bixler13's Avatar
United States, CO, Colorado Springs
Joined Jul 2011
Build Log
The Easy Twin!
The Easy Twin (4 min 42 sec)
The Easy Twin is a super simple twin motor plane capable of fpv. It is constructed from super cheap foam board that can be purchased at the dollar tree.
Dimensions:
Wingspan- 60”
Root-7.5”
Length-30”
Cg-2.5” back from leading edge
Electronics:
Motors –Turnigy 2822 1450kv (goes vertical)
Props – 8x4.5 and 8x4.5r
Battery- 3s 2200-4000mah
Servos- 9 gram
Esc- 2 30amp (overkill)
Without any fpv gear and a single 2650mah lipo I could get around 20 minute runtimes and with all the extra weight of the fpv gear the runtimes dropped down to 15 minutes. I plan on putting a 4000mah lipo in there to see what kind of runtimes I can get.
The goals when building this plane were to keep it as aerodynamic as possible to reduce drag. I taped the wings with packing tape in hopes of getting a smoother airflow over them. Also it provided better visibility and water resistance. The wing has a root chord of 7.5 inches and was constructed using the Armin Wing technique. It has a thickness of 3 pieces of foam board. The wing has a wooden spar. I made the wing in two pieces and then joined them together with tape and hot glue.
As seen in the picture bellow, the aileron servos are entirely inside of the wing to reduce drag.
The elevator servo is inside of the fuselage. The pushrod comes out of the rear of the plane.
The gopro is held in with a Velcro strap. The canopy was then cut to fit over the camera. I was surprised how well it all fit together in the end. Make sure when building this place to make the fuse completely and then cut the canopy off. This way it will sit flush. I use magnets and a rubber band to secure the canopy.
For fpv I use a 1280mhz 800mw transmitter. It is attached to the side of the aircraft as seen bellow. I didn’t put it inside of the fuse because it gets hot and needed the airflow.
The fpv battery and range link receiver are located behind the wing. I made a hatch so I could access them.
The rangelink antenna is attached to the vertical stabilizer as seen in this picture.
As said above, the motors are Turnigy 2822 1450kv. The mount is a piece of sheet metal bent at 90 degrees. Make sure you remove the tape before gluing the mount on. Hot glue doesn’t stick well to tape. (I learned the hard way)
The width of the fuse is 3 inches. This provides plenty of room for a camera and batteries.
I taped two credit cards to the bottom of the fuse to act as skids. Without these the foam board gets pretty ripped up from landings.
The wing is removable and attached using rubber bands. I used some chloroplast under the rubber bands so that they don’t put too much stress on the wing.
The plans are attached to this post. As of now, 3/18/14, the plans have not been tested yet. I have printed and cut them out but have not built a plane from them. As you can see, I have added notches in the plans so that the pieces will fit together a little nicer. The current plane I am flying does not have these notches. If somebody uses the plans to build this plane, let me know how well they work so I can make any adjustments.
Bixler13 is offline Find More Posts by Bixler13
Old Apr 23, 2014, 08:08 AM
Joined Jan 2013
Awesome, love the airfoil design. NICE WORK =]
Maraos is offline Find More Posts by Maraos
Old Apr 23, 2014, 03:16 PM
Warsaw, Poland
Joined Sep 2010
Looks great
Could you upload non-tiled templates?
mkrawcz1 is offline Find More Posts by mkrawcz1
Old Apr 24, 2014, 12:48 AM
Marty Petri Sr.
mbpetri's Avatar
Thailand, Uttaradit, Bo Thong
Joined Jun 2007
Originally Posted by mkrawcz1 View Post
Looks great
What CAD program did you use?
A DXF file would be even better,
Looks like a stable platform, would like to build one.
Marty
mbpetri is offline Find More Posts by mbpetri
Old Apr 24, 2014, 09:07 AM
FPV Proximity is FUN!
fOaMmaSh87's Avatar
Australia, WA, York
Joined May 2012
This looks awesome! Looks like I'm making this instead of the FT cruiser for sure!
-Ben
fOaMmaSh87 is offline Find More Posts by fOaMmaSh87
Old Apr 24, 2014, 09:43 AM
Joined Apr 2014
yes,This looks awesome! Looks like I'm making this instead of the FT cruiser for sure!thanks
caseforcalle is offline Find More Posts by caseforcalle
Old Apr 25, 2014, 09:57 PM
Scratch builder
Bixler13's Avatar
Joined Jul 2011
Thanks for the feedback guys! I added the full sheet plans to the first post.
Old Apr 25, 2014, 11:54 PM
fOaMmaSh87's Avatar
Australia, WA, York
Joined May 2012
Hows it fly? Can it flat spin ?
-Ben
Old Apr 26, 2014, 01:52 AM
Marty Petri Sr.
mbpetri's Avatar
Joined Jun 2007
It wouldn't let me upload the autocad file so I uploaded it to 4shared.com so you can download it from there if you would like. The link is : http://www.4shared.com/photo/SV07Kt9...UTCAD_DXF.html
Trying to download it now, FYI, you can just upload the DXF file, just change the extension from .DXF to .ZIP and note it in your comments.
Thanks much,
Marty
Old Apr 26, 2014, 02:07 AM
Marty Petri Sr.
mbpetri's Avatar
Joined Jun 2007
Too bad, It won't let me download without downloading one of their virus infested download programs, I tried them all, but EST NOD32, flags them all.
Marty
Old Apr 26, 2014, 03:22 AM
Warsaw, Poland
Joined Sep 2010
Thank you, Bixler
Same here...
Old Apr 26, 2014, 08:27 AM
Scratch builder
Bixler13's Avatar
Joined Jul 2011
Ok sorry about that guys. I will put it in a zip file later tonight and upload it.
Old Apr 26, 2014, 08:48 AM
Scratch builder
Bixler13's Avatar
Joined Jul 2011
I added the .zip file with the DXF file to the first post. Let me know if it works.
Old Apr 29, 2014, 02:06 AM
Marty Petri Sr.
mbpetri's Avatar
Joined Jun 2007
Thanks for the files, Still having a problem with the DXF file, I can unzip it, but Sketchup and Illustrator both say it is an invalid file type.
Marty
Old Apr 29, 2014, 03:29 PM
Warsaw, Poland
Joined Sep 2010
Same with CorelDRAW, PDFs are OK.
For Sale Multiplex Permax Motor: Easy Star, Twin Jet, Twin Star, Mini Jet, Mini Mag ssautter Aircraft - Electric - Airplanes (FS/W) 0 Jul 25, 2012 02:15 PM
Discussion Twin boom Easy Star with Easy Glider wing. Tarro FPV Talk 13 Jan 10, 2010 02:52 PM
Discussion Easy glider Vs. Easy Star Vs. Twin star (pros, cons) jgvdl FPV Talk 0 Mar 29, 2009 09:19 PM
Easy Jet with twin edf hansen Electric Ducted Fan Jet Talk 6 Jul 21, 2003 11:55 AM
