Old Oct 07, 2015, 01:15 AM
jtur is offline
Find More Posts by jtur
Joined Oct 2015
Compatable Battery/ESC/Motor/Prop Combo?
Last night I began testing my first quadcopter motors and ran into some trouble when ramping them up.
General rundown of my quadcopter:
I am using an arduino writeMicroseconds() function to send the pwm signal to my escs.
  • RioRand XXD A2212 1000KV Brushless Outrunner Motors
  • 30A Brushless ESCs
  • 1045 Propellars
  • Venom 20C 3S 2100mAh 11.1 LiPO Battery
My problem:
As I ramp up my motors, one-by-one, they stop working at increasing throttle steps. For instance, as I increase throttle, one motor stops spinning at around 10% throttle, then another stops spinning when I get to 30%, then another at 50%. I believe this has something to do with incompatable Battery/ESCs/Motors/props but I'm not sure where to start in determining how to get compatable components.
I tried using, however, most of my parts aren't on that website.
Any advice would be much appreciated!
Full product descriptions:
Max Efficiency: 80%
Max Efficiency Current: 4-10A (>75%)
Current Capacity: 12A/60s
No Load Current @ 10V: 0.5A
No. Of Cells: 2-3 Li-Poly
Motor Dimensions: φ27.5 x 27mm
Shaft Diameter: φ3.17mm
Weight: 48g
30A Brushless ESC
1.1 Output: Continuous 30A, Burst 40A up to 10 Secs.
1.2 Input Voltage: 2-4 cells lithium battery or 5-12 cells NiCd/NIMh battery.
1.3 BEC: 2A / 5V (Linear mode).
1.4 Max Speed: 210,000rpm for 2 Poles BLM, 70,000rpm for 6 poles BLM, 35,000rpm for 12 poles BLM.
(BLM: BrushLess Motor)
1.5 Size: 45mm (L) * 24mm (W) * 11mm (H).
1.6 Weight: 25g.
4pairs 1045L/R Propeller (BLACK)
jtur is offline Find More Posts by jtur
Discussion Motor/ESC/prop combo for disco clone ccchevyz Multirotor Power Systems 2 Jul 03, 2015 01:45 AM
Sold DUALSKY 390KV Motors Combo / 4x ZTW 40a Opto SimonK Esc's/ 4x 15x5 Xoar Wood Props BajaSky619 Aircraft - Electric - Multirotor (FS/W) 1 May 09, 2015 06:27 PM
Sold Motors, Props, ESC's and Battery Combo M3Roc Aircraft - Electric - Multirotor (FS/W) 1 Mar 07, 2015 10:58 AM
Question What is the best motor/esc/battery/prop combo for a 24 inch wing? gobigdale Flying Wings 5 Sep 10, 2010 11:07 AM
Motor/ESC/Prop/battery Combo for Foam Hydro joystix Foamies (Kits) 6 Jul 26, 2005 11:55 PM
