Old May 21, 2015, 08:54 PM
scharlach is offline
Find More Posts by scharlach
Joined Jan 2005
Mini Vapor Improved Power & Performance
A fairly simple way to turn your Mini Vapor into a great performer that can do
loops and fly nearly straight up.
1. Change propeller to PKZ3901 100 x 60 mm Propeller
2. Change battery to HK Zippy50S-20C 1S/50mah/20C
The Mini Vapor will still fly real slow and has plenty of reserve power when
you need it.
scharlach is offline Find More Posts by scharlach
Old May 22, 2015, 06:14 AM
RNAF is offline
Find More Posts by RNAF
Κάτω Χώρες
RNAF's Avatar
The Netherlands
Joined Dec 2003
I've a MCF 5030s carbon prop. It weighs 0.5 grams. Got more thrust but I think it's not the right pitch. At full throttle you can clearly hear a lower rpm at low speeds than level, higher, speeds - it unloads. Still on stock motor and battery, hovers at full throttle.
RNAF is offline Find More Posts by RNAF
Wanted Vapor or Mini Vapor HenryRC923 Aircraft - Electric - Airplanes (FS/W) 1 Mar 08, 2015 06:54 PM
Help! Ideas for improving DJI Phantom (1.1.1) performance at altitude (2000m/6800') err_ok Multirotor Talk 0 Nov 06, 2014 05:03 AM
Wanted Vapor/ Mini Vapor punkrockd Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Jan 01, 2014 06:24 PM
Mini-Flash power system.....improvements ? Al P Parkflyers 11 Nov 30, 2005 08:43 PM
