Old Jan 13, 2015, 06:24 AM
Senior Moment Member
babblefish's Avatar
SF Bay Area, CA
Joined Jul 2002
Planking material used in Billing Boats
I'm building a St. Canute as my first true planked hull model and might run out of the kit supplied planking due to my mistakes. Just wondering if anyone knows what type of wood Billing uses in their planked hull kits because I may have to cut more, but need to know what to use. I plan to paint the hull so color and grain doesn't have to match the kit material. I'm learning a lot though and even with my boo boo's, it's coming along nicely. There's a Dumas Typhoon that has been sitting on the shelf for many years awaiting my attention, but I want to make most of my learning mistakes on something simpler first.
- Wes
Edit: I just realized that it might be Obeche, if so, I don't know where to buy it so is there another good wood to use that is more readily available? Guess it needs to be flexible or at least made that way with a good ammonia soak.
babblefish is offline Find More Posts by babblefish
Old Jan 13, 2015, 09:31 AM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
I'd have no qualms using basswood.
patmat2350 is offline Find More Posts by patmat2350
Old Jan 13, 2015, 03:55 PM
babblefish's Avatar
SF Bay Area, CA
Joined Jul 2002
Thanks, I was thinking the same. Basswood is cheap and easy to get.
Old Jan 14, 2015, 06:52 PM
NW NW Washington
Joined Aug 2007
I am building a Dumas kit (CG36500), with a balsa planked hull. I found their balsa to be too soft and easy to break, so I bought replacement balsa planks on the Midwest website. I had used their balsa on a previous build with good results. And the Midwest balsa worked well on the Dumas kit.
CGAux26 is offline Find More Posts by CGAux26
Old Jan 14, 2015, 07:56 PM
babblefish's Avatar
SF Bay Area, CA
Joined Jul 2002
That sounds good. From my experience, Midwest balsa is usually mostly medium density so should be good for planking. I'm leaning towards using basswood because it's a bit stronger and I'm a bit rough on my boats.
Wanted Billing Boats Smit Rotterdam Plan Sheet wrasse5 Boats (FS/W) 0 Jan 04, 2015 05:29 PM
Question What are the materials used in this mold? edulago Composites Fabrication 10 Aug 19, 2014 11:23 PM
Sold Billing Boats WSP 10 Police/Patrol Boat Kit Tollytime Boats (FS/W) 0 Jul 22, 2014 09:41 AM
Question Anyone have a Bill of Materials for Taurus? SixDeuces Classic Pattern Flying 0 Mar 03, 2014 08:08 AM
Discussion Planking 42inch plank-on-rib Jonesport Lobster Boat DaveMainzone Scale Boats 16 Oct 05, 2008 10:24 AM
