Old Jan 07, 2015, 12:08 AM
ufoDziner's Avatar
United States, CA, Anaheim
Joined Mar 2002
Help!
Tekin T8i rewind (looking for service)
Hello,
I have a Tekin T8i inrunner (http://www.teamtekin.com/t8i.html) that I would like to have rewound in a 2.5Y configuration. Is there somewhere/someone reputable that I can contact to do this? Thanks in advance!
ufoDziner is offline Find More Posts by ufoDziner
Old Jan 07, 2015, 11:13 AM
ufoDziner's Avatar
Joined Mar 2002
Okay... After browsing the forums, I think I'd like to try this myself. Most of the threads are for outrunners though. This is a 12 slot 4-pole motor. Can someone please point me to some inrunner winding guidance for this type of motor? Thanks in advance!
Old Jan 07, 2015, 12:29 PM
homo ludens modellisticus
Ron van Sommeren's Avatar
The Netherlands, GE, Nijmegen
Joined Feb 2001
Why do you want to rewind it? Higher rpm?
What is the current configurtion?
Figure out whether star or delta hookup
Figure out number of winds per (couple of) teeth. Wires wound in parallel count as one wind.
Figure out number of teeth per coil
Figure out wich winds or CW and which or CCW.
Figure out wire diameter.
Pictures of winds, coils, hookup?
Vriendelijk groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Jan 07, 2015, 01:14 PM
ufoDziner's Avatar
Joined Mar 2002
Thanks for the reply Ron!
I want to lower the Kv.
It is currently a 1600 Kv 3D. The company offers a 1350 2Y, but I'd like a little lower than that, which is why I would like a 2.5Y.
I will disassemble and take many photos this evening.
Old Jan 07, 2015, 03:03 PM
ufoDziner's Avatar
Joined Mar 2002
Dis-assembly pics:
It looks like it is going to be challenging to get the wire in and out as the stator is glued into the can. There is also a lip on one end.
Old Jan 10, 2015, 11:40 AM
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
FWIW, almost no one rewinds inrunners.....it's not easy.
A glued outrunner is bad enough.
flydiver is offline Find More Posts by flydiver
Old Jan 10, 2015, 11:49 AM
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
United States, AK, Fairbanks
Joined Aug 2009
If it's terminated delta, you may be able to separate the ends out and re-terminate to Y without needing to rewind the whole thing.
Attempting a full rewind on your motor is most likely a good way to destroy it.
C₄H₁₀ is offline Find More Posts by C₄H₁₀
Old Jan 10, 2015, 05:28 PM
Joined Feb 2001
That would lower Kv by factor 1.7.
Vriendelijke groeten Ron
Old Jan 14, 2015, 11:24 PM
ufoDziner's Avatar
Joined Mar 2002
I de-soldered the tabs which revealed 3 bundles of wires. The middle bundle can be separated into to groups that look like they belong together. The other 2 have roughly 24 wires each. Separating them individually is possible, but would be pretty time consuming. How would I ring them out from that point?
Old Jan 16, 2015, 05:56 PM
C₄H₁₀'s Avatar
Joined Aug 2009
The only surefire way to do it would be to test for continuity between the two middle bundles and each of the individual strands. Group them together and mark them so you don't forget which goes where. It may certainly take awhile, but you don't exactly have many other options
From there, it would just be a matter of adding leads or solder tabs to one end of each of the three phases, then soldering the other three ends all together. This is a Y termination and will lower Kv by a factor of about 1.7 like Ron said.
Old Jan 16, 2015, 07:23 PM
Joined Feb 2001
How do you exactly wind an slotted inrunner? - RCG
wave winding - RCG
Similar Dutch thread, long, method and winding diagram drawings, pictures
translate... www.modelbouwforum.nl/forums/model-elektronica/212803-hulp-advies-nodig-voor-herwikkelen-binnenloper.html
Removing old windings, in pictures, soften glue with heat/oven (without the magnets!)
www.eschmidt.onlineelektro.de/scripts/show.aspx?content=/shop/home/leistung/motoren/drehstrom
Prettig weekend Ron
Wanted Looking for Tekin RX8 Gen1 or Gen2 Independentjrc Cars - Accessories (FS/W) 1 Oct 29, 2014 05:55 AM
Announce Dji is looking for service & support specialists Tahoe Ed DJI-Innovations 0 Jul 08, 2014 11:03 PM
For Sale Looking for advice on vinyl graphics service to you all GravyBones Aircraft - General - Miscellaneous (FS/W) 3 Oct 09, 2013 11:47 AM
Wanted Looking for used tekin fxr or novak rooster chirogid Cars - Trucks and Parts (FS/W) 0 Jun 22, 2010 12:21 AM
Discussion Looking for info regarding rewinding a BP-21 JAM Power Systems 2 Mar 09, 2006 06:53 PM
