Old Nov 09, 2014, 05:48 PM
341
Joined Nov 2014
Help!
Hexacopter looses power after 30 sec. take off.
Hello,
I have a problem here, with an hexacopter after taking off(30 seconds), the voltage drops(around 14.8V) dramatically and it looses power forcing me to land.
After that, the batteries are almost full.
I used ecalc for checking the selection of the components and it justs says: For minimal maneuverability you need Throttle of less than 80%.
But has a flight time of 6.8 min.
This are the components that I used:
- Type, Hexa
- Batteries, 5200Ma 35c 4S2P
- ESC, 40A, 60A max.
- Prorps, 14-8
- Motors, T-motor NM4014(400Kv)
- Total weight, around 7Kg
As a FC I use the Naza, with the protection switch off.
At this point I have no clue why is behaving like that, I would really appreciate any idea.
Thanks.
341
341 is offline Find More Posts by 341
Old Nov 09, 2014, 06:49 PM
Team WarpSquad
United States, PA, Doylestown
Joined Jan 2014
Vibrations!
waltr is offline Find More Posts by waltr
Old Nov 09, 2014, 06:57 PM
Joined Nov 2014
Did you measure how much amps you are pulling? 7kg is a lot.
Blackjack160 is offline Find More Posts by Blackjack160
Old Nov 09, 2014, 08:59 PM
Design and fly
skycam4's Avatar
IL
Joined Dec 2008
Amp pull will be massive on 4 cells with those motors. Bump to 6 or 8 cells and you will see good flight times along with the ability to lower gains for better FC control. . Running voltage on the lower end will always have horrible performance. Voltage is HP in the multi world.
skycam4 is offline Find More Posts by skycam4
Old Nov 10, 2014, 05:24 AM
341
Joined Nov 2014
Hi,
thanks for the replies,
Skycam4 actually that makes sense I'm wondering why the Ecalc
didn't adviced anything about.
I'll go for higher volt. batteries, probably 6S
Old Nov 10, 2014, 04:18 PM
Joined Apr 2013
"For minimal maneuverability you need Throttle of less than 80%. " was an indication that you would need 80% or more throttle just to hover. That was the warning.
jeffjblack is offline Find More Posts by jeffjblack
Discussion Help, Hexacopter wont take off Multipilot Multirotor Electronics 8 Aug 16, 2014 03:08 PM
Help! DJI phantom - Battery low warning just after take off M277HEW Multirotor Talk 6 Oct 18, 2013 04:49 AM
Discussion hexacopter flip while take-off atulgupta181 Multirotor Talk 1 Sep 30, 2013 01:19 AM
Help! Lose control of tricopter after 30 secs of flight. laserj Scratchbuilt Multirotors 21 Feb 10, 2013 10:24 AM
Discussion Lost power after take off... Band1086 Power Systems 1 Dec 17, 2009 06:59 AM
