Old Jan 15, 2013, 09:04 AM
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
Question
Multi 4 - Storage Charge
Will the Multi 4 run in "LiPo All Brands Storage Charge" mode bring a fully charged lipo down to storage level?
Rob
robj is offline Find More Posts by robj
Old Jan 15, 2013, 10:26 AM
CPII HD & PL8 beta tester
Jack Doherty's Avatar
Aubrey, Texas
Joined May 2009
Rob
Hi Rob,
No the Multi 4 is designed to storage charge a discharged battery up
to 3.86v per cell. . Quote from manual below.
6 LiPo All Brands Storage Charge. Special LiPo preset designed to storage charge a discharged battery up
to 3.86v per cell. This preset will only work if the battery is below the storage charge voltage when
connected. Manual charge rate setting is required when using this preset and ranges from 0.25A to
4.00A. Default setting is 2.0A
Jack Doherty is offline Find More Posts by Jack Doherty
Old Jan 15, 2013, 12:39 PM
USA
Joined Jan 2002
Rob
Simply put, the Multi4 has no discharge capability.
Ohmic is offline Find More Posts by Ohmic
Old Jan 15, 2013, 01:41 PM
robj's Avatar
Joined Nov 2008
Thanks!
Discussion When do you leave a battery charged and when do you storage charge it? Fly2High Batteries and Chargers 18 Dec 08, 2012 01:52 PM
Discussion Multi-4 and Fromeco Li-ion pack charging radman_w156 FMA Direct 5 Sep 04, 2012 09:01 AM
Discussion Cellpro Multi-4 charge rate question raycalvino Batteries and Chargers 3 Jun 26, 2012 12:29 AM
Discussion CellPro Multi-4 Balance Charge Observations FlyingW Batteries and Chargers 0 May 04, 2012 11:23 PM
Discussion Multi 4 Parallel Charging swimmer FMA Direct 2 Apr 22, 2012 08:43 PM
