Old Feb 18, 2015, 06:52 PM
Lenny970's Avatar
Greeley, Colorado, USA
Joined Feb 2000
For a warmliner setup I'd probably use a 4S battery and maybe downsize the prop a bit if needed.
Lenny
Lenny970 is online now Find More Posts by Lenny970
Old Feb 18, 2015, 11:57 PM
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Why would you test it with a pack that only has a 50% charge? Do you typically fly that way, only charging the pack to 50%?
aeajr is offline Find More Posts by aeajr
Old Feb 19, 2015, 06:57 AM
United States, TX, Canyon
Joined Jan 2011
No, I was trying to see what the average output would be for the flight.
ben_beyer is online now Find More Posts by ben_beyer
Old Feb 19, 2015, 08:47 AM
LI, New York, USA
Joined Mar 2003
Oh, I see. Interesting approach. I would not have thought of that based on how I use my battery packs in e-gliders in competition.
Normally I only get one launch per pack per contest round. After I land the battery comes out, goes on a charger and I put in a fresh one. In a contest I am always launching on a full pack, so that is what I use to measure.
I use about 400 mah per launch and 10 minute flight, so about 30% of a 1300 or 50% of an 850 pack. During those launches my average charge state would be between 75 and 85% full charge status, approximately.
Old Feb 19, 2015, 09:43 AM
Joined Jan 2011
Yeah, I'm not flying competition with the Nike 2. I have thought about getting into F5J but it's typically too windy here to have good thermaling conditions. So my flights will be go up, glide down, repeat.
I also found the 840 kv motor on one of the ecalc's whereas I was only able to find the 1120 kv before and I need to track down where I was. The interesting thing is that it did say I would be stalling the prop at full throttle in a static position so I may be able to get much more power than what I'm measuring. The YEP doesn't have data logging. If I got into F5J, I'd probably look into one of the Castle ESC's to be able to down load the logs and tune my performance.
Old Feb 19, 2015, 11:07 AM
LI, New York, USA
Joined Mar 2003
Thanks Ben. Understood. Since this is the Electric competition forum I expected that everyone posting in the discussion was flying and tuning for competition.
Old Feb 21, 2015, 12:39 PM
Romania, Dolj, Craiova
Joined Sep 2007
Originally Posted by aeajr View Post
These are not part of the Gliderdrive family of motors but it they might fit some similar applications. These are inrunners.
Turnigy 540L V-Spec Inrunner - 36 mm
I had not seen this motor before. Looks like a nice fit for an e-glider.
http://www.hobbyking.com/hobbyking/s...idproduct=9449
Being inrunners they don't need clearance for the spinning can.
I own the 540 and some warnings:
- weight on site is wrong, it is much heavier 186 grams or so
- the shaft is not round, but beveled, most collet spinners can't grip
- the most horrible cogging I seen... very hard to control RPM under 25% throttle. Works fine on a switch, though.
renatoa is online now Find More Posts by renatoa
Old Feb 21, 2015, 12:42 PM
LI, New York, USA
Joined Mar 2003
Good to know. I was not aware of any of that. Really appreciate the info.
I presume you could file a flat spot on the shaft so a set screw spinner could hold.
Mini-Review New Turnigy Sk3 Series Outrunners, Turnigy's "High end" Outrunner daign Multirotor Talk 22 Sep 12, 2014 05:42 AM
Discussion Turnigy Aerodrive SK3 OR NTM Prop Drive Series OR easy match series sebbe Power Systems 10 Dec 23, 2012 03:33 PM
Discussion Turnigy D or SK3 series? jtaylor996 Power Systems 2 Nov 29, 2012 10:25 PM
For Sale Turnigy Helidrive SK3 Competition Series 4 NIB blawren Aircraft - Electric - Helis (FS/W) 0 Nov 21, 2012 11:51 AM
For Sale Turnigy G60 and Turnigy SK3 4250 fnlrun Aircraft - Electric - Power Systems (FS/W) 3 May 21, 2012 01:20 PM
