Old Oct 08, 2014, 01:07 AM
3d and other
kevbeer's Avatar
los angeles
Joined Jan 2004
3D foamie plans--39.5" WS for 6mm depron
Hey Guys,
Long time poster, been away for a while. I have designed in CAD, hand cut, and built several 3d foamie bipes and mono planes using 3mm and 6mm depron. I recently did a save as of a previous design and tweaked it bit and bumped it up in size to arrive at the attached design (PDF 1:1 scale template.) I have built mine but have not flown it yet. The design suggests 6mm depron, but use whatever you fancy.
Cheers!
kevbeer is offline Find More Posts by kevbeer
Old Oct 08, 2014, 03:27 AM
Joined Jun 2014
Kev this is the 3D section, you will get a better response in the correct section (scratchbuilds).
Truthfully, i don't see how you can publish a design (having published many) without test flying it first?
Harlem is offline Find More Posts by Harlem
Old Oct 08, 2014, 08:57 PM
3d and other
kevbeer's Avatar
los angeles
Joined Jan 2004
look at my join date and look at yours. that is how.
Old Oct 09, 2014, 02:51 AM
3d and other
kevbeer's Avatar
los angeles
Joined Jan 2004
sorry Harlem, that was rude of me. Even though I haven't flown it yet, I feel confident this airframe will perform 3D well because I have cut several before and I think by this time I know what to expect.
Old Oct 09, 2014, 03:53 AM
Joined Jun 2014
It doesn't work like that, blowing up or shrinking down a 'known' good flyer doesn't mean it will fly the same. In my experience, quite often they need fuselage and control surfaces tweaking as...
size changes everything.
Yes you were rude, VERY rude, i have been kicked off this site for a lot less!
Old Dec 27, 2014, 08:41 PM
You sabotaged my plane.
eliworm's Avatar
Arizona
Joined Jun 2002
Looks like a reasonable design to me. Should fly well.
eliworm is offline Find More Posts by eliworm
Discussion 9.5 inch ws, dr1 fokker triplane : Peterakes plans rogenstein1983 Scratchbuilt Indoor and Micro Models 14 Oct 05, 2014 11:40 AM
Question Looking for plans for a flat out 3d foamy tanner331 3D Foamies 2 Mar 12, 2014 06:15 PM
Discussion Hi! Need plans for a 3d Depron foamie sql204 Foamies (Scratchbuilt) 5 Dec 16, 2012 07:03 PM
Build Log Bede BD-5, 6mm Depron, plans vleisie Pusher Prop Jet Models 2 Nov 13, 2009 08:45 PM
Discussion custom 6mm depron bipe, 39.5 WS kevbeer 3D Flying 4 Jun 04, 2008 07:02 PM
