Old Dec 21, 2014, 10:05 PM
Joined Dec 2014
Question
Hovercraft steering options.
Slowly beginning to make plans for my first foray into diy RC and i'm wondering which of the following configurations would result in the best steering for a hovercraft.
1. Fixed motor/propeller with a rudder behind it.
2. Motor/propellor on a servo.
3. 2 fixed motor/propeller on either side of the hovercraft.
4. a combination of the ones above ?
I'm looking to build a relativity fast and responsive hovercraft.
I havent decided yet on size and shape the hovercraft but i'm leaning towards a round hovercraft with a diameter of +- 60-70 cm simply because of the looks and the fact that u don't see them often.
Any ideas what would be best in my situation ?
Scroo is offline Find More Posts by Scroo
Old Dec 22, 2014, 12:43 PM
United Kingdom, Scotland, Edinburgh
Joined Jun 2014
Welcome.
It's a rather tricky question depending on what you mean by 'best' steering, given you don't want it to be fragile or difficult to build/tune.
You can't go wrong with a fixed prop and rudder, definitely use at least two or even three rudders linked together to catch most of the propwash for maximum turn authority.
Turning the entire prop and motor is possible but it introduces a lot of complexity. Also, rudders still work even when the motor is off when the craft is coasting, whereas with a moving motor/prop you'll always need to apply thrust to get any turning at all (unless you put a rudder fixed relative to the motor and prop, on the same pivot as them).
An issue with rudders is weathervaning - if you put them at the 'back' of the craft they will line up with the airflow and stabilise the craft to always point in that direction. This is good for high speed stability but can also be a major pain in winds or when you want to have the nose pointing in a different direction to where the craft is going. Depending on how much skirt drag you have this might not be a problem.
2 fixed motors is mechanically very simple (no pivots or linkages) and gives excellent turn authority if you get the differential throttle mixing right. It's possible with this set up to have too much control and end up with the craft spinning out if there's not enough skirt drag to damp the turns.
I mention skirt drag as my own hovercraft is skirtless so there isn't any at all, so it's very sensitive to steering. A small ducted fan and rudder is enough.
If you go for the round hull you could try having a fixed prop at each side for thrust and differential steering, plus a single rudder at the back that will help out at high speeds and give a little bit more stability.
FiftySlicks is online now Find More Posts by FiftySlicks
Old Dec 22, 2014, 06:36 PM
Australia, VIC, Bass
Joined Jan 2013
Another big factor to consider is the type of surface you are operating over, whether you have a skirt or not there will be some ground contact unless its just going on a perfectly smooth dry surface. -If you craft has a round planshape or is fairly wide, when it contacs the surface the drag will spin the craft making control very difficult. This becomes even more of a problem over water or wet surfaces where the drag is much higher. The longer the craft relative to width the more directional it should be.
If only operating on a smooth dry surface then a circular plan shape should be ok. - fitting a gyro unit also works well if set up properly. Have a look at my blog for some examples of different layouts I've used.
windnsea is online now Find More Posts by windnsea
Old Dec 25, 2014, 03:42 PM
Joined Dec 2014
Thank you for the replies.
After mulling it over for a few days I think I'm going to abandon the circular design for maybe a future hovercraft and stick with a more conventional shape for this one.
High speed together with a wide design could indeed spell trouble with handling when friction with the ground increases.
And for steering I think I'll stick with the tried-and-true design with fixed motor + rudders.
I am having a bit of trouble deciding on motors for lift and thrust since that all depends on the weight of the craft and since I don't have any real world comparison that's kinda tricky to figure out.
But that's maybe a question for another thread
Old Dec 26, 2014, 02:21 PM
Germany, BY, Gräfelfing
Joined Jan 2003
Hi,
have a look at this German forum , http://www.rc-network.de/forum/showt...-indoor-Rennen .
there are some video ,doing indoor Hovercraftracing . Tought about some helicopter rear propeller that can counter flyforce in corners ,like ading grip with superglue tires . i have a iceglider that has only springsteel wire that give no direction . i steer it with a small propeller in the front that push the front inside the corner.
Christian Lucas is offline Find More Posts by Christian Lucas
Old Dec 28, 2014, 07:10 AM
Rapidly aging user
raw89's Avatar
United States, PA, Lancaster
Joined May 2012
Hi - I'm +1 w/ FiftySlicks; " try having a fixed prop at each side for thrust and differential steering, plus a single rudder at the back that will help out at high speeds and give a little bit more stability."
Why take your valuable thrust energy & slam it into a rudder when you can trim power to one of the motors & save battery?
I think vectored thrust is simpler & lighter....
My 350mm vectored thrust mini...
RC Hovercraft from quadcopter (1 min 46 sec)
Early test photo...Ralph
raw89 is offline Find More Posts by raw89
Old Dec 28, 2014, 07:36 AM
Staffs, UK
Joined Nov 2003
Do you mean vectored thrust or just differential thrust ? They're very different. I've never seen a vectored thrust system that's either simple or particularly light . And of course the problem with differential thrust is that you have no steering unless you're under power, unlike a simple rudder.
Steve
slipstick is offline Find More Posts by slipstick
Old Dec 28, 2014, 06:36 PM
Rapidly aging user
raw89's Avatar
Joined May 2012
Steve
Hi Steve - Guess I mean either one....in 25+ yrs of design/building/flying full size & RC hovers I don't think I ever heard the term "differential thrust"....but I like it
Pic's below are my "old school" 700mm vectored thrust craft that's about 15 yrs old......motor pylon is a pair of tubes...inner mounted to frame & outer can rotate. Since I got hooked on Quadcopters I've been neglecting these things...2 of my planned projects over the winter are to re-do the small one & convert the 700mm to 2.4 TX/brushless/lipo/etc.
One of my objectives is to keep the profiles to a minimum to lessen wind effects
Good to see some discussion on this forum............Ralph
Discussion Hovercraft Quadcopter combo - HoverQuad Nightstone Scratchbuilt Multirotors 4 Sep 25, 2014 04:09 PM
Gallery SSSH ( Simple Skirtless Single(engine) Hovercraft) (My first hovercraft) addictedtoplanes RC Hovercraft 1 Apr 06, 2014 10:24 PM
Discussion Optional steering shock Jeremy1976 Motorcycles 2 Feb 26, 2008 03:16 PM
Poll Steering options Akura2 Motorcycles 18 Jul 17, 2007 07:15 AM
Question Options to control a Hovercraft lift fan? nbrophy Power Systems 1 Jun 06, 2006 12:02 AM
