Old Dec 13, 2013, 09:18 PM
Zachb657's Avatar
United States, PA, Middleburg
Joined Jan 2013
Bell X-1
Hi all,
My friend and i are going to build a remote controlled Bell X-1 1-20th scale with an 11inch wingspan and was wandering if a C6-5 rocket engine will supply enough power to move the Bell a good distance.
Thanks Zachb657
Zachb657 is offline Find More Posts by Zachb657
Old Dec 14, 2013, 09:39 PM
X30PILOT's Avatar
Joined Aug 2007
A C6 would be plenty. Built light an A3 would probably be adequate.
X30
X30PILOT is offline Find More Posts by X30PILOT
Old Dec 14, 2013, 09:48 PM
Zachb657's Avatar
Joined Jan 2013
Keep in mind this will be R\C with a receiver, 3 mini servos, and a small battery pack plus it will be made out of balsa.
Old Dec 19, 2013, 05:33 PM
X-15 Jockey
burkefj's Avatar
Joined Oct 2006
It depends on weight as well, you can choose lighter materials than wood and keep weight light and make it bigger which will help wing loading and visibility, and reduce the CG shift %.
Frank
burkefj is offline Find More Posts by burkefj
Latest blog entry: Natter
Old Dec 19, 2013, 06:29 PM
Zachb657's Avatar
Joined Jan 2013
You could use foam but the rocket would probably melt it
Old Dec 19, 2013, 07:00 PM
X-15 Jockey
burkefj's Avatar
Joined Oct 2006
Nope, I do all the time, you just need a motor mount tube for insulation
I've never had a motor melt foam around a motor tube from d through g motors in my gliders.
frank
Old Dec 20, 2013, 12:54 PM
United States, NJ, Frenchtown
Joined Mar 2003
Called designing.
cyclops2 is online now Find More Posts by cyclops2
Old Dec 20, 2013, 10:22 PM
Joined Jul 2004
Hey check out my build thread here, it appears we are like-minded.
http://www.rcgroups.com/forums/showt...8#post26958325
soaringtuna is offline Find More Posts by soaringtuna
Old Dec 21, 2013, 12:36 PM
Zachb657's Avatar
Joined Jan 2013
I like your idea we just might use your plans as a reference for our Bell X-1. I think we will scale it down a little so it has a smaller wingspan of about 11 inches to launch it off of a plane. We dont know if we want to use a C engine or a D.
Old Dec 21, 2013, 01:51 PM
X-15 Jockey
burkefj's Avatar
Joined Oct 2006
Imho the cg shift with a d motor in that small of a model will be too large to trim out after burn unless you eject nose weight ir use a composite d.
Old Aug 10, 2014, 07:55 AM
Joined Sep 2010
BELL-X1 test fire (0 min 25 sec)
I use a "D" rocket and it goes up about 300-350 ft. Wild, trying to control it as you can see. When I get around to it , will launch from a transport, let it glide down and then fire. Did a "shuttle" 2 years ago. Estimate it will do over 400 ft.
Accounted for CG shift with burning D rocket.
aero1960 is offline Find More Posts by aero1960
Sold Bell RS-1 Cataclysm Blue Helmet XL XXL Price reduced to $150 shipped sdstick Non R/C Items (FS/W) 2 Dec 16, 2013 08:06 PM
Gallery Bell X-1 Captain Dunsel Scale Drawings and Three Views 0 Oct 25, 2013 06:14 PM
What if.... Bell X-1 (1st supersonic aircraft) sukhoi26mx Parkflyers 30 Jan 25, 2003 12:08 PM
Where would i find that vidoe of the X-1 Bell? kushal_22 Electric Plane Talk 7 Dec 27, 2002 01:23 PM
Bell X-1 Foxtrot Scale Kit/Scratch Built 7 Jun 15, 2001 12:43 AM
