Old Jul 29, 2014, 05:20 PM
IFHELI's Avatar
United States, RI, Woonsocket
Joined Apr 2010
Spartan VX1E Esprit
Check this out............ $149.99
http://www.experiencerc.com/store/pr...t-p-17305.html
IFHELI is offline Find More Posts by IFHELI
Old Jul 29, 2014, 07:10 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Interesting. I wonder if it will stay at that price (the VX1n was close to that price when released (introductory $169, I think, but also needed the datapod)). They'll do very well if it does, and may see others having to think about lowering their price.
The only negative I can see is the USB out the opposite end to the servo leads, which can limit installation possibilities, like the fu-bar did. Tends to force you to mount the gyro in the lower frame, which is not a bad thing. It also works for helis, that have a front top gyro mount.
I'd like to try one, and probably would if it was $99, but currently I'm more than happy with the gold K-Bar's...
beenflying is offline Find More Posts by beenflying
Old Aug 03, 2014, 04:21 AM
Joined Dec 2012
The Esprit has lower performance sensor(s) than their more expensive models.
TheKingPhisher is offline Find More Posts by TheKingPhisher
Reply With Quote  (Disabled)
Old Aug 03, 2014, 03:00 PM
IFHELI's Avatar
Joined Apr 2010
You are right. I notice that in the add I read before I made a post about it.
Old Aug 03, 2014, 03:18 PM
Joined Dec 2012
Yeah it's probably still a good FBL controller, but there's usually a catch that goes with the low price.
Old Aug 04, 2014, 01:46 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I don't think the average pilot would notice the difference. It's still a very good MEMS, better than mini VBar uses.
Old Aug 07, 2014, 04:01 PM
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Angelos (the owner of Spartan) said the following on RcHeliadict (UK heli forum) ...
"The VX1e uses MPU-6000 sensor (same as most FBL systems and multirotor controllers) instead of the PinPoint awesomeness of the VX1n. Nevertheless both have their own merits and there is certainly a big demand for a low cost Vortex system."
"Without a doubt the PinPoint sensors are on a league of their own but it is difficult to quantify this against the MPU-6000. However, I can tell you what to expect from the VX1e... It will be no worst than a brain/ikon since it also uses the exact same sensor. Also Mini Vbar, Blue Vbar, Demon, BeastX, and most other FBL systems use the exact same sensor or one from the same manufacturer that operates with the same principles."
"I have not worked out what the final price will be as we first need to complete the batch and cost all of our production operations. The launch price certainly offers exceptional value for the performance you will get out of this unit."
MikeHRC is offline Find More Posts by MikeHRC
Old Aug 08, 2014, 02:33 AM
Joined Aug 2011
I love Spartan uses high performance mem sensor and price at lower than those big brand name.
I do not want to mention those big brand name gyro previously used for the fly bar but price double than Spartan quark gyro.
Price at double but I'm doubt are those performance double than Spartan?
Tovin is offline Find More Posts by Tovin
Old Yesterday, 07:47 AM
Joined Aug 2011
Got hands on the new VX1e, wiring up the setup configuration quite similar as Vbar alike only slight differences.
What I like the most is the software setup 8 on the cyclic throw on both parallel & perpendicular of main blade against the tail boom direction.
The cyclic feels more balance during flight in Aileron & Elevator control.
Setting up with Data pod is easy and very handy especially at the field test flight.
However I had some problems in tuning the cyclic for stable pitch pump, , it is due to some mechanical issues on Tarot DFC split head and also the servo is developing more slop than before.
Also finally get to correct the tail performance to get rid of kick back in CW piro stop, it takes me total of 20batteries pack to get it right. It takes lot of time to figure the advance tail setup in combination of stop gain, I gain ratio, and mechanical adjustment to correct the bounce on fast piro stop.
After everything was set correctly as expected it feels more balance than Vbar, I would not rule Vbar as second to Vx1e just that my personal feels of Vx1e is more balance than Vbar.
Help! Esprit electric spoilers Tom Smith Sailplane Talk 2 Oct 13, 2013 03:30 PM
New Product ARC models from Esprit Models. peterlngh Electric Sailplanes 0 Sep 26, 2013 02:43 PM
Sold Bunch of stuff for sale-Pike Surperior, Esprit, 9303, etc belouder Aircraft - Sailplanes (FS/W) 3 Sep 18, 2013 09:24 PM
Discussion esprit vs. grand esprit.....? dirtybirdy Thermal 6 Apr 20, 2010 09:55 PM
ESPRIT plane from esprit.com info. needed? speedo Sport Planes 5 Aug 26, 2002 03:45 PM
