Old Jun 29, 2014, 09:07 PM
Tim Lampe; Hobbico R&D
KRProton's Avatar
Champaign, IL
Joined Dec 2009
Hi André
This stuff;
http://www.mcmaster.com/#heat-shrink-tubing/=smjaj5
When you get to the page, it's under the Abrasion-Resistant Fabric Heat-Shrink Tubing heading.
Tim
KRProton is offline Find More Posts by KRProton
Old Jun 29, 2014, 09:16 PM
Jebera's Avatar
Brazil, MG, Belo Horizonte
Joined Oct 2006
Originally Posted by KRProton View Post
Hi André
This stuff;
Tim
Thank you Tim!
Jebera is online now Find More Posts by Jebera
Old Jun 30, 2014, 01:25 PM
savneo's Avatar
Cyprus
Joined Mar 2012
Originally Posted by pednor View Post
New Lipocells did wonders for the performance
This time I kept the Aluplate . Im starting to have an theory that the aluplates prevents the cells from swelling so much. I wrapped the cells HARD with kapton tape just to press them hard together=the plates inside cant delaminate. Now after 4 flights no swelling at all...... 26+krpm really makes the DOP prop scream. Unfortunately no speed readings, but atleast the variometer showed over 80m/s at best )))
Your thoughts on the ali plates are correct i have also noted this with other brand of batteries. It help hold down the puffing. Your plane must now be really moving @ 26000 prop rpm.
What size W x L x H are your lipos. From the specs on the internet i see that the W is 42mm and H 35. If that is correct how are getting them in their?
savneo is offline Find More Posts by savneo
Old Jun 30, 2014, 06:31 PM
pednor's Avatar
Sweden, Piteĺ
Joined Aug 2008
Just Squeeeeze them in. They are about 40x34 for a 5s with plates. Had to rebuild two 3s packs http://www.rcflight.se/visaprodukt.aspx?id=1589
pednor is offline Find More Posts by pednor
Old Jul 01, 2014, 07:34 PM
Battery Puffer
Orange, California, United States
Joined Nov 2001
Be carefull of lipos with Alu. plates. If the packs can't puff up they will split out the ends instead.
Mark
MarkF is offline Find More Posts by MarkF
Old Jul 03, 2014, 10:40 AM
Joined Jun 2014
Nice work. Skillfully Tim.
Ferah Jr. is offline Find More Posts by Ferah Jr.
Old Jul 03, 2014, 02:16 PM
KRProton's Avatar
Champaign, IL
Joined Dec 2009
I received an inquiry about the control horns I made for my Avioniks, so I had my AutoCAD drawings converted to a PDF for printing and attached them below.
I made mine out of 1mm carbon fiber, but I'm sure FRP would also be fine. One will need precision drills to drill them the correct size for whatever pushrods they are using - test drill holes in scrap pieces first before cutting and drilling the horns.
Use spray adhesive to glue the paper templates to the horn material, then cut out. When drilling the holes, a drill press is almost mandatory as carbon fiber is very difficult to drill through - especially drill straight if you don't have a drill press.
When printing the pattern, be certain to set your printer to 100% or actual size. Measure the square to make sure you printed to the correct scale.
Tim
Old Jul 03, 2014, 02:37 PM
Joined Jun 2014
Thank you Tim. Excellent!
Old Jul 27, 2014, 08:46 PM
KRProton's Avatar
Champaign, IL
Joined Dec 2009
Needed to shorten one of the battery wires coming from the ESC in my Avionik, so pulled the motor. Had a look a the insulation on the terminal wires exiting the motor case and no sign of any wear after about 50 flights.
Everything going swell.
Tim
Old Jul 28, 2014, 02:06 PM
KRProton's Avatar
Champaign, IL
Joined Dec 2009
CF horns...
Old Jul 28, 2014, 02:30 PM
Joined Jun 2014
Thank you Tim.
I'm grateful for this excellent horn. Great work. everybody must have to know you are a big and so successful man.
Thanks to you too will be a professional.
Thank you very much for your support. I could not success on without you. I'm already looking forward to.
Old Aug 08, 2014, 02:56 PM
Joined Jun 2014
Hi Tim;
Which do you use elevator servo? From the pictures I could not understand.
Old Aug 08, 2014, 03:28 PM
KRProton's Avatar
Champaign, IL
Joined Dec 2009
Hi Fatih.
In one of my Avioniks (and both of my Vipers) I use Hitec HS-65HB on the elevator:
http://www3.towerhobbies.com/cgi-bin...&I=LXKYL4&P=ML
In my two other Avioniks (one deceased now ) I am using Hitec HS-5065MG. I don't care about the metal gears, but I wanted digital:
http://www3.towerhobbies.com/cgi-bin...?&I=LXSDA9&P=7
In the Avioniks I am running 2S LiFe, but I have this regulator in-line for the servos:
http://www.soaringusa.com/Servo-Regu...-A-Inline.html
http://www.espritmodel.com/mks-volta...c-5-8v-2a.aspx
At first I didn't use the regulator - for probably 50 flights on the Avionik, but later I decided to use the regulator. No problems before the regulator or after the regulator, but I thought it would be best to be safe.
In the Vipers I use 2S LiPo, but with Castle Creations regulator.
Tim
Old Aug 08, 2014, 03:40 PM
The Prop is Where its At!
blitzu's Avatar
New Zealand, Bay Of Plenty, Omokoroa
Joined Dec 2012
Hi FerahJr-what plane and motor system did you do 400+kmh with?
blitzu is online now Find More Posts by blitzu
Old Aug 08, 2014, 03:51 PM
Joined Jun 2014
Tim, thank you for your information. I took note.
I was thinking of Hitec HS-65HB servo for elevator use.
Thanks.
Discussion avionik d05 servos+d05 fotos kris64 High Performance 12 Nov 18, 2009 05:21 PM
Discussion Avionik D05 SlowBarless High Performance 62 Nov 11, 2008 06:24 PM
Discussion Avionik D05 first flight samuelx High Performance 59 Nov 11, 2008 04:45 PM
Discussion Fastest avionik d05 setup tf1156 High Performance 8 Sep 16, 2008 08:06 AM
Discussion 2 Avionik D05:s and stuff for sale! Tuomas P. High Performance 4 Feb 20, 2008 01:28 PM
