Old Yesterday, 02:01 PM
Joined Mar 2014
Originally Posted by Dave Pitman View Post
Mac,
You can use the Mobius as the flight camera and record video.
http://www.rcgroups.com/forums/showthread.php?t=1951912
You have to define your expectations of a "high quality video displayed on a monitor".
Hello Dave ! I would be happy with a transmitted video of my display as good as Mobius recorded , or nearly .
maccardiolog is offline Find More Posts by maccardiolog
Old Yesterday, 02:54 PM
Dave Pitman's Avatar
Joined Nov 2013
The Mobius records HD, but the live video out is Standard Definition (SD). All of the regular vtx's only transmit SD anyway. To get an HD (or anything close) downlink video means bumping up to something like LightBridge, heavy and expensive. You could also investigate switching over to the Phantom Vision platform which will get you a much higher quality downlink video. Or, you could lower your expectations a little. There are lots of videos out there that show you a recording from the typical downlinked video for you to look at. Again, it is quite a bit less quality than what the Mobius records, unfortunately.
Edit:
Here is an example of the difference. (Any SD board camera used for the live downlink video will be close to the Mobius live video and not the recorded video)
http://www.rcgroups.com/forums/showp...&postcount=431
Dave Pitman is online now Find More Posts by Dave Pitman
Old Yesterday, 03:40 PM
Joined Sep 2013
I think the Vision series cameras output SD analog video as well.
ElGuano is online now Find More Posts by ElGuano
Joined Sep 2013
I'm pretty sure the Vision series cameras output SD analog (composite) video as well, so it should be comparable with what gets transmitted from a GoPro or Mobius.
Old Yesterday, 03:55 PM
Joined Nov 2013
My mistake. I thought that the downlinked video over wifi was better quality than the video of "traditional" vtx systems.
Old Yesterday, 03:57 PM
Joined Mar 2014
Edit:
Thank you Dave and ElGuano ! Very good said : I will lower my expectation ! But is your opinion if I would use an apart cam ( Sony CCV...) for this purpose ( how will be the video quality ? )
Old Yesterday, 04:01 PM
Joined Sep 2013
I did as well, for the embarrassingly longest time, especially with those 320x240 and 640x480 settings in the app
But then I saw those Dronexpert guys patching video into the App from GoPro and Sony cameras, and had the most "duhhh" moment....
Old Yesterday, 04:05 PM
Quad Pilot
Jumanoc's Avatar
Joined Jan 2013
2 tips around your requirements:
I use both, 540 TVL Sony CCV cam and the mobius for filming.
With enough daylight, the Mobius is far better, but at noon or night the CCV is better. In addition you have to wire for CCV and sometime is a PITA to involve an OSD with it. Altough with Mobius to adding a simple OSD is near to "plug and play".
With CCV camera your right sure not to loose FPV in midflight (scary situation with 2 Mobius issues loosing power and let me blind at 800 mts)
Jumanoc is offline Find More Posts by Jumanoc
Old Yesterday, 04:28 PM
Joined Mar 2014
Hello Humanoc . How did you loose the power from Mobius ? Did the Power of Mobius supply from its battery or from the other source ?
Old Yesterday, 04:53 PM
muscleflex's Avatar
Leeds, UK
Joined Nov 2004
Thanks for this info
Correct, the LEDs on the Phantom 1 are part of the ESCs, and cannot be switched on and off (or otherwise controlled by the user in any way). A lot of people who film at night and get glare from the red lights wrap the front arms with electrical tape to blackout the lights.
What I did was replace all my ESCs with E300s and added new orientation lights; the new ones are wired into a microcontroller plugged into the Naza so a free channel can change animation patterns, adjust brightness or blackout the lights completely. That's a fairly involved mod though.
muscleflex is offline Find More Posts by muscleflex
Old Yesterday, 11:25 PM
Quad Pilot
Jumanoc's Avatar
Joined Jan 2013
I use the Mobius powered with it s own battery, but it suddendly showed low battery alarm and around 10 seconds after that the camera turned off. I verified the battery and it was dead. I recharged it and no failure detected. Many flights after that the issue repeated one more time. No explanation found. After that, now i use the FPV wired with charge Mobius from main battery.
Discussion DJI Quadcopter Frame BUILD Thread Quad_Addict Multirotor Talk 78 Mar 17, 2014 11:20 PM
Mini-HowTo POSTING VIDEO: How to Upgrade a Gaui 330x quadcopter with a DJI NAZA Lucidity47 Multirotor Talk 5 Jun 07, 2012 01:31 AM
Video Multiwii Quadcopter Dji F-450 frame Updated Video Anda Inc. Electric Heli Talk 1 May 23, 2012 03:51 PM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 02:27 PM
