Old Jan 21, 2015, 08:43 PM
Tsunami33 is offline
Find More Posts by Tsunami33
Tsunami33's Avatar
Singapore, Singapore
Joined Jan 2009
Build Log
OK Models / Pilot Piper J-3 Cub
Starting back on building and wanted something that is actually have the guts to build and fly. Most of the other kits are on display at the LHS. This particular manufacturer is my favorite given the design. Would like to see if there are other kits out there with such precision laser cut parts. I think I've seen a few but haven't had the opportunity to experience building them. And I'm one of those kit hoarders that won't touch the older kits.
Tsunami33 is offline Find More Posts by Tsunami33
Old Jan 21, 2015, 08:51 PM
Tsunami33's Avatar
Joined Jan 2009
Got the fuselage started and tried to figure how best to 'jig' the structures give it is laser cut and already fits well. Just a matter of where to apply pressure while the PVA glue dried. Decided on PVA instead of CA.
Old Jan 22, 2015, 12:32 AM
Tsunami33's Avatar
Joined Jan 2009
Here's the rest of the fuselage with the remaining formers.
Old Jan 22, 2015, 12:37 AM
Tsunami33's Avatar
Joined Jan 2009
Rear stringers and tail feathers.
Old Jan 22, 2015, 12:43 AM
Tsunami33's Avatar
Joined Jan 2009
Sheeting for the top and bottom. This reall comes together quite simple as you decipher the plan in Japanese and English. My experience with these kits are that, the wing is its so tight a fit , you can lift it without glue.
Old Jan 22, 2015, 09:59 AM
Tsunami33's Avatar
Joined Jan 2009
Here's the landing gear and test fitting of the tail feathers.
Old Jan 22, 2015, 08:16 PM
Tsunami33's Avatar
Joined Jan 2009
Getting a start in the wing. Should move a lot faster.
Old Jan 22, 2015, 08:18 PM
Tsunami33's Avatar
Joined Jan 2009
Anyone know of scale Piper wheels (hubs) that's between 45 - 50mm?
Old Jan 22, 2015, 08:19 PM
Tsunami33's Avatar
Joined Jan 2009
Anyone know of scale Piper wheels (hubs) that's between 45 - 50mm? The kit calls for vacuum formed wheels which is great for weight and looks. I just prefer foam.
Old Jan 24, 2015, 04:21 AM
Tsunami33's Avatar
Joined Jan 2009
Got on with the leading edge ribs and LE itself with epoxy. Made a mistake not looking at the spar alignment. One side is a little warped....
Old Jan 26, 2015, 08:16 PM
Tsunami33's Avatar
Joined Jan 2009
Can I get some input on covering materials? What's light but not too transparent for a kit this size? It's about 1m in wing span. I don't want to use monokote. Reading another thread, econokote sounds like the way to go.
I initially thought of tissue. There's polyspan? Silk sounds like overkill. And don't knoew enough about Oracover, Coverite, etc. and not about to waste time with doculam although I have some on order because there's painting required.
Some advice would be appreciated.
Old Jan 26, 2015, 08:19 PM
Tsunami33's Avatar
Joined Jan 2009
Here's the framed up progress. Still have a long way to go. Been distracted with another build.... A GWS Spitfire.
Old Jan 27, 2015, 09:24 AM
LesUyeda is offline
Find More Posts by LesUyeda
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
I never had any laser cut parts in my Pilot models, and this is only one of the many that I did build.
Les
Can't figure out how to delete the extra picture.
LesUyeda is offline Find More Posts by LesUyeda
Old Jan 27, 2015, 10:51 AM
glewis is offline
Find More Posts by glewis
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
I prefer Ultracote Parklite. It is a bit heavier than Solite, but is more translucent and doesn't require constant re-shrinking the way Solite does. It is a little thicker and stronger/more puncture resistant and it comes in a lot more color choices than Solite.
Glenn
glewis is offline Find More Posts by glewis
Old Jun 09, 2015, 10:02 AM
florigami is offline
Find More Posts by florigami
norwegian coast flyer
Norway, Rogaland, Haugesund
Joined Dec 2014
I found the plans on outerzone and I'm planning to scratch build it. is there any good reason to buy the kit?
florigami is offline Find More Posts by florigami
Wanted Pilot /OK model 1/3.7 scale CHRISTEN EAGLE II grover Aircraft - Electric - Airplanes (FS/W) 5 Mar 02, 2015 05:33 PM
Sold NIB OK Models Pilot PA-18 Super Cub sj3cub Aircraft - Fuel - Airplanes (FS/W) 2 Oct 17, 2014 11:54 AM
Sold Vintage Pilot OK Model Co Piper Cherokee Kit hobbyfun100 Aircraft - Fuel - Airplanes (FS/W) 3 Sep 29, 2014 02:00 AM
Sold Vintage Pilot OK Model Co Piper Cherokee Kit hobbyfun100 Aircraft - Electric - Airplanes (FS/W) 1 Sep 29, 2014 01:56 AM
Sold OK Models/Pilot PA-18 Super Cub Kit NIB $200 shipped USPS ground CONUS be69ar Aircraft - Electric - Airplanes (FS/W) 0 Dec 27, 2010 02:13 PM
