Old Oct 18, 2014, 02:12 PM
scole is offline
Find More Posts by scole
Joined Feb 2014
4 blade to 2 blade
I landed hard today with my 980 razorback, broke one blade off, can I cut the other one off and make a 2 blade out of it? or will it not be the correct pitch or whatever else could go wrong?
scole is offline Find More Posts by scole
Old Oct 18, 2014, 04:02 PM
cmdl is offline
Find More Posts by cmdl
Y=C+I+G
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
you could. just make sure you balance it. note that it will have reduced power due to the missing blades. if you're ok with that you can have longer flights (due to lower power consumption) if you use the same throttle management as before.
cmdl is offline Find More Posts by cmdl
Old Oct 18, 2014, 04:44 PM
scole is offline
Joined Feb 2014
fms said they would offer a 2 blade option for these planes to increase flight time and speed, I asked diamond hobby about this they said the factory decided not to go ahead with the two blade option since guys were reporting 114 mph speeds with the 4 blade.
Discussion 2 blade vs 4 blade prop - More braking? IatricSB Combat 6 Aug 03, 2014 08:31 PM
Question Prop blades 2,3 or 4 blade? and why??? Mike-A Scale Boats 4 Jan 27, 2014 01:30 PM
Sold SOLD - 2 1/2 Blade mCXs, RTF,4 batt.,blades, 2 charges, glo blades, xtra parts Old Blade Man Aircraft - Electric - Helis (FS/W) 3 Jan 13, 2012 07:30 AM
Sold (2) Spinners 4.5 2 blade & 5" 3 blade ibcinyourc.com Aircraft - Fuel - Engines and Accessories (FS/W) 0 Nov 21, 2011 07:41 AM
