Old Jun 30, 2014, 04:26 PM
Neil_SC is online now
Find More Posts by Neil_SC
Joined May 2004
3.27
Neil_SC is online now Find More Posts by Neil_SC
Old Jun 30, 2014, 04:40 PM
Darrellmims is offline
Find More Posts by Darrellmims
United States, AL, Clanton
Joined Apr 2013
I got to 1848 watts and a temp of 140* and 76 amps using a 20/8 . I think I need to go up to a 20/10 and get the results .
It seemed that it would stay around 1400-1600 watts when flying some aerobatics . And I switched to 3.27 also .
Darrellmims is offline Find More Posts by Darrellmims
Old Jul 04, 2014, 11:30 PM
outofsight is offline
Find More Posts by outofsight
That sure does get small quick
United States, NE, Kearney
Joined Jun 2004
I changed the timing to low and the pwm to 12 and changed to the 3.27 firmware as well am going to try it out with a 19x10 APC and 20-8 xoar and a 20-10 xoar also used a soda bottle to cool the motor. The vid of joe smith on the 3dhs site makes it look killer but maybe it's the high def resolution....hope it wakes up on my re maiden tomorrow otherwise I am going gas.
outofsight is offline Find More Posts by outofsight
Old Jul 04, 2014, 11:50 PM
Joined May 2004
I was getting 2450W at 105A with an APC 20.5x12W. Got about 16lb of thrust. Max temp was about 158F with sufficient cooling.
Old Jul 04, 2014, 11:51 PM
Joined May 2004
Joe's running a 21x10. I just don't know why anyone would run a 20x10.
Old Jul 05, 2014, 12:14 AM
jason360 is offline
Find More Posts by jason360
jason360's Avatar
Joined Oct 2007
Hey Guys,
I have a cure to all your problems. I sold my CC Edge 100 ESC and went with the hobbywing flyfun 100amp HV ESC and it worked perfect with the 28 pole Hacker A60 right out of the box! I had lots of problems with my old CC Edge with my A60-6XS not delivering full power even with the firmware update.
Link to esc: http://www.hobbywing.com/product_show.asp?id=195
Vid with my new hobbywing esc:
3DHS 74" Edge 540 - Hacker A60-7S (1 min 49 sec)
jason360 is offline Find More Posts by jason360
Old Oct 10, 2014, 12:33 AM
carrera0to60 is offline
Find More Posts by carrera0to60
United States, AZ, Gilbert
Joined May 2005
I wanted to add my .02$. I read on here and FG that a ZTW Gecko ESC would also work to run the A60. No luck for me. It'll get to about 3/4 throttle and then lose sync which sounds like a loud knocking sound throughout the airframe. I tried messing with the settings and had no luck. I got it to run good enough to fly a couple times on a CC Talon 90 but I had to change the PWM setting to "outrunner mode" Castle phone support told me not to run that setting but its the only way it'll work.
A60-6xs
CC Talon 90 (must use outrunner mode)
ZTW Gecko ( doesn't work)
CC Ice 100 ( bought on ebay and will test next week)
Glacier 45C 5000
carrera0to60 is offline Find More Posts by carrera0to60
Old Oct 10, 2014, 12:53 AM
Joined May 2004
A60-6xs
Glacier 45C 5000
From what I understand, the Talon is no better than the Edge as far as compatibility with the 28-pole Hackers. But I think I've read that the very latest firmware released late this summer/fall is finally compatible with these motors. I would check out the thread below for all your high-powered electric setup questions. Aeroplayin is a wizard on that thread. He and others on the thread have lots of experience with the 28-pole Hackers (like the A60-5S, 7S, 8S, as well as the 6XS).
Power Systems for Extreme Flight Fanatics!
http://www.rcgroups.com/forums/showthread.php?t=1533887
Wanted Hacker A60-6xs JoeR Aircraft - Electric - Power Systems (FS/W) 1 Jul 29, 2013 10:29 PM
Found Hacker A60-6XS XtremeWingRC Aircraft - Electric - Power Systems (FS/W) 2 Jul 02, 2013 05:59 PM
Sold Hacker A60-6XS and Castle ICE 100 rgandee Aircraft - Electric - Power Systems (FS/W) 1 Jan 15, 2013 06:22 AM
Discussion Hacker A60 6XS 28 V2......ESC choice? JEFFRO503 Power Systems 2 Jun 21, 2012 12:22 AM
Discussion Hacker A60-6XS V2, is a 12s lipo okay? benaresenferno Power Systems 0 Jun 25, 2011 09:33 PM
