Old Nov 18, 2014, 09:48 AM
Canada, ON, Halton Hills
Joined Nov 2004
EFlite Taylorcraft
Does anyone have a suggestion as to which floats and hardware will make an easy fit for this aircraft?
Thanks Andy.
Andya1 is offline Find More Posts by Andya1
Old Nov 19, 2014, 05:04 PM
Balsa just crashes better
Cub Fan's Avatar
Bradenton, FL
Joined Nov 2004
foam floats
I used the foam floats from the Horizon foam Super Cub on my Taylor Craft. I used the original wheel mount and used a piece of music wire with a piece of K&S tubing to fit the original axle size and wheel collars to keep it centered.
For the rear I glued a piece of plywood inside the fuse and bent a set music wire struts . It worked great and has for the last three summers
I think there was a lot of info in the Taylor Craft thread about adding floats
Jay
Cub Fan is offline Find More Posts by Cub Fan
Old Nov 19, 2014, 06:18 PM
Joined Nov 2004
Thank you Jay
Sold Eflite Taylorcraft @ Horizon Indoor Fest pohlmeyr Aircraft - Electric - Airplanes (FS/W) 2 Nov 07, 2014 08:51 PM
Wanted Eflite Taylorcraft phil p Aircraft - Electric - Airplanes (FS/W) 6 Jan 20, 2014 07:00 AM
Sold Eflite Taylorcraft NIB cowl and wing struts flyte lyne Aircraft - Electric - Airplanes (FS/W) 0 Nov 11, 2013 10:49 AM
Sold Eflite taylorcraft. - BIND AND FLY storm57 Aircraft - Electric - Airplanes (FS/W) 2 Sep 29, 2013 01:32 AM
For Sale Eflite Taylorcraft w/ Eflite 450 Outrunner, ESC & Servos abercrsoc Aircraft - Electric - Airplanes (FS/W) 1 Mar 27, 2010 10:06 PM
