Old Dec 27, 2012, 11:11 PM
Joined Dec 2012
Help!
esc for my hexa....
hi i newbie in multirotor
I want to build hexacopter, with frame ATG 650, FC KK2. I need help to choose the esc for this motor
http://www.hobbyking.com/hobbyking/s...00kv_250w.html
Specs:
Model: NTM Prop Drive Series 28-26A 1200kv
Kv: 1200RPM / v
Max current: 18A
Max Power: 200W @ 12v (3S) / 250W @ 15v (4S)
Shaft: 3mm
Weight: 57.6g
ESC: 20A
Cell count: 3s ~ 4s Lipoly
Bolt holes: 16mm & 19mm
Bolt thread: M3
Connection: 3.5mm Bullet-connector
because I was afraid of select esc .. anyone can help me pick out a suitable esc to the motor ...?
I want HobbyKing esc on sale
sorry my english is bad and I'm sorry if this question seems stupid
regards
fajaranakku is offline Find More Posts by fajaranakku
Old Dec 28, 2012, 01:11 AM
New Zealand, Canterbury, Christchurch
Joined Dec 2012
It's an 18A motor, so choose an ESC more than 18A, a 20A ESC would be fine, preferably one that can be flashed with the SimonK firmware
Any of the below would work
http://www.hobbyking.com/hobbyking/s...C_3A_UBEC.html
http://www.hobbyking.com/hobbyking/s...e_Series_.html
WendoNZ is offline Find More Posts by WendoNZ
Old Dec 28, 2012, 07:30 AM
Denmark, Central Denmark Region, Karup
Joined Aug 2012
I used turnigy plush 30a escs, for that exact motor. Is worked fine, plus then you are suited if someday you want more powerfull motors.... They dont cost much the Plush 30a
vartaz is offline Find More Posts by vartaz
Old Dec 28, 2012, 02:55 PM
Joined Dec 2012
The downside with the plush's is that they aren't based on Atmel chips anymore so you need a different flasher and process to flash them with another firmware. Still possible to do but the flasher costs way more than the basic atmel one
Old Dec 29, 2012, 07:06 PM
Joined Aug 2012
The stock firmware if you have program card is really OK, not simonK but its working quite good...
Old Dec 30, 2012, 12:14 AM
Emress
sirbow2's Avatar
United States, SD, Rapid City
Joined Nov 2011
F-30A or F-20A. F-30A would be better because 20A is a bit close
sirbow2 is offline Find More Posts by sirbow2
Old Dec 30, 2012, 03:01 AM
Joined Dec 2012
hi guys...
thank you for replay my question
This esc might fit? or there are other options...
http://www.hobbyking.com/hobbyking/s...ontroller.html
note: I would like esc a plug and play
regards
Fajar
Old Dec 30, 2012, 03:56 AM
Joined Dec 2012
No ESC is plug and play, you either need to program it to set it up, or flash a new firmware on it. Without programming them you may find they cut out when you rbattery gets low and cause a crash
Old Dec 30, 2012, 04:08 AM
Joined Dec 2012
hahaha ... yes you're right.
ok .. what about esc that I gave the link above ....? whether it fits with the motor ?
Old Dec 30, 2012, 04:25 AM
Joined Dec 2012
Yup, it's be fine
Old Dec 30, 2012, 04:41 AM
Joined Dec 2012
Originally Posted by WendoNZ View Post
Yup, it's be fine
WendoNZ thanks ...
the frame ATG 650, FC KK2, motor and esc .. we discussed whether I'll be able to bring hexa GoPro camera or a class ...?
I expect I'll be able to fly hexa softly and slowly to take pictures and video
Old Dec 30, 2012, 09:39 AM
Emress
sirbow2's Avatar
Joined Nov 2011
for that youre gonna have to flash it with simonK you might as well get the F-30A then. the blueseries still can be flashed, but the F-30A is a bit better.
Old Dec 30, 2012, 11:59 AM
Joined Dec 2012
F-30A ? you have a link that I can see?
regards
Old Dec 30, 2012, 01:27 PM
Joined Dec 2012
It was supposed to be in one of the links in my first post but apparently I copy/paste failed
The F30 is easier to flash as the pads are all lined up if memory serves, however the easiest way to flash ESC's without soldering is with something like this
http://www.hobbyking.com/hobbyking/s...hing_Tool.html
you still need an AVRisp though
Old Dec 30, 2012, 10:36 PM
Joined Dec 2012
I have studied the flash turned out ..... hopefully quickly understand, because I'm not an electronic knowledge base
if flash esc is a simple and easy job? or make a headache? hahaha
Discussion Opinions on my Semi-Pro Hexa Build for AP benthoms Multirotor Talk 2 Sep 17, 2012 11:23 AM
Discussion Please suggest me a good motor from here for my hexa joy4u Multirotor Talk 2 May 04, 2012 04:03 AM
Discussion Please help me decide the right motor and prop for my hexa for greater flight times joy4u Multirotor Talk 2 May 02, 2012 11:34 AM
For Sale trade my flyduspider hexa for fpv goggles or long range system imdone FPV Equipment (FS/W) 0 Mar 17, 2012 12:34 AM
Wanted I don't want a CC board..I would like a great gimbal cam mount for my DW Hexa cryhavoc38 Aircraft - Electric - Multirotor (FS/W) 2 Mar 14, 2012 01:20 PM
