Old Jun 26, 2016, 02:52 PM
Rogrc is offline
Find More Posts by Rogrc
Rogrc's Avatar
United States, MI, Newaygo
Joined May 2015
Question
How to mix throttle with elevons on DX8
I have done a search to find the answer and struck out.
I have built a couple of wings and they all seem to have the same problem. The more throttle you give the higher they climb. I can cut the throttle and glide stay nice and level for quite some time. Therefore I don't really want to make adjustments on the elavon mechanically.
I'm looking for a way to do a throttle mix so when I give it more than 50 to 60% throttle my elavon will drop down to counter act the up thrust.
I figured I can't be the only wing guy out here with this problem.
Thank you for taking a look at this post and help sort out the problem
ROG
Rogrc is offline Find More Posts by Rogrc
Old Jun 26, 2016, 09:44 PM
FD Pilot is offline
Find More Posts by FD Pilot
FD Pilot's Avatar
Phoenix, AZ
Joined Nov 2006
Try this
http://www.rcgroups.com/forums/showp...&postcount=311
FD Pilot is offline Find More Posts by FD Pilot
Old Jun 26, 2016, 09:57 PM
Rogrc is offline
Rogrc's Avatar
Joined May 2015
Thank you for your reply FD pilot
That is exactly what I'm looking to do I just don't know how to set it up
Old Jun 27, 2016, 09:46 AM
FD Pilot is offline
FD Pilot's Avatar
Phoenix, AZ
Joined Nov 2006
Rogrc,
Go into you the "Flight Modes" chapter of the manual, pretty easy. Basically you turn-on the flight modes option, select the mode switch you would like to use, re-trim for each flight mode....done.
Old Jun 29, 2016, 10:16 AM
T B N is offline
Find More Posts by T B N
Joined Jun 2015
I use the flaps section in my dx6 for that. Each flap setting has a matching elevator compensation settings. I don't put in any numbers for the flaps themselves, just the elevator. This gives me 3 handy trimsettings on one switch.
T B N is offline Find More Posts by T B N
Discussion V-Tail on Elevon mixing? CalvaryStudy Parkflyers 4 Jan 12, 2016 01:52 PM
Question Spektrum DX6: How do I mix throttle to elevator on Vtail plane with 2 elevators? Bird09 Radios 4 Nov 02, 2015 07:13 AM
Question How to mix throttle with elevons on DX6i to get rid of pull to left and up kctrading Radios 2 Apr 04, 2010 11:38 AM
Help! How to mix throttle with elevons on DX7 to neutralize left pull! kctrading Radios 3 Mar 19, 2010 12:10 AM
Discussion How do I turn on elevon mixing on my remote?? jdlightening Radios 1 Feb 24, 2008 05:33 PM
