Old Mar 10, 2016, 02:07 PM
cmtewellingtonfs is offline
Find More Posts by cmtewellingtonfs
Joined Mar 2016
Build Log
Mirage 2000B for Turbine 22Lbs
Mirage 2000B with turbine Jetcentral Habbit 100KS
Length: 2150 mm
Wingspan: 1470 mm
Flight weight: 24 to 28 Lbs (with 2 Liters of fuel)
Built by Wellington Santos
cmtewellingtonfs is offline Find More Posts by cmtewellingtonfs
Old Mar 10, 2016, 02:53 PM
Joined Mar 2016
All structure was made by plywood and balsa that was cut on CNC machine.
Old Mar 11, 2016, 06:30 PM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Wow nice work...
Old Mar 14, 2016, 01:37 PM
Joined Mar 2016
Thanks!!
Old Mar 18, 2016, 02:12 AM
TTRotary is offline
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
Damned impressive build! It looks like you are using a 6 or 7% symmetrical airfoil?
Also, could you share how you formed the clear canopy from the glas-over-foam mold?
TTRotary is offline Find More Posts by TTRotary
Old Mar 18, 2016, 03:37 AM
HarryC is offline
Find More Posts by HarryC
UK
Joined Nov 2002
Very nice. Is this your own design?
HarryC is offline Find More Posts by HarryC
Old Mar 21, 2016, 10:19 AM
Joined Mar 2016
I used a 80% symmetrical airfoil, and the canopy i made using epoxy resin for protect the foam and after i use fiberglass to improve the resistance and endure the temperature.
Old Mar 21, 2016, 10:30 AM
Joined Mar 2016
Thanks Harry!
No, it is not, i used a project that is available in some forums, but i needed to make some changes.
Old Mar 21, 2016, 02:31 PM
TTRotary is offline
Joined Mar 2010
Great thanks. Did not know you could even put a foam buck in the oven - I figured you'd have a puddle of plastic (and major issues with my dear wife).
Old Mar 22, 2016, 04:05 AM
HarryC is offline
UK
Joined Nov 2002
Thanks Harry!
Can you point me to it, I would love to make one myself
Old Mar 25, 2016, 12:29 PM
Joined Mar 2016
Hi Harry
It was the site: http://www.baronerosso.it/forum/aero...ge-2000-a.html
Old Jul 03, 2016, 03:13 PM
TTRotary is offline
Joined Mar 2010
How is the project coming along? Maiden flight soon?
Old Jul 15, 2016, 07:18 PM
Joined Mar 2016
Unfortunately i'm not having time to finish it.
For Sale Nice Turbine Pipe up to 22lbs thrust txshan130 Aircraft - Fuel - Jets (FS/W) 1 Apr 09, 2015 08:00 AM
Sold FeiBao Velox composite Jet - 100% RTF -Jetcat P80SE turbine(22Lbs Thrust) x3dflyer Aircraft - Fuel - Jets (FS/W) 4 May 02, 2014 04:01 PM
Discussion Mirage 2000B Von W Pusher Prop Jet Models 2 Feb 06, 2014 11:40 AM
Wanted Airframe for 22lbs turbine Maydog Aircraft - Fuel - Jets (FS/W) 0 May 21, 2012 03:37 PM
Yippee! jet design contest 2nd entry-Dassault Mirage 2000b Bryce From Nice Electric Ducted Fan Jet Talk 16 Nov 24, 2005 11:10 AM
