Old Jan 01, 2015, 07:48 PM
tlh101 is offline
Find More Posts by tlh101
FICKLE FLYER
tlh101's Avatar
United States, NM, Elephant Butte
Joined Dec 2002
Bridi-G/P Cosmic Wind
OK, it's not really a "Giant" but technically, it is "giant scale", as it's 27%.
I had a Testors plastic RTF c/l model of the Little Toni, when I was a kid, and always had a soft spot for them. Then right after I got back into R/C, about 15 or so years ago, I saw one of the Bridi models done as a the "Little Toni" and knew I had to have one someday.
It's an epoxy glass fuse, foam wing and tail, kit. I have been working on this about a week or so. So far I have worked out the motor mount, sheeted all the flying surfaces, and hinged & shaped the elevators. I plan to use either 6s, with about a 15x12 prop, or possibly 8s w/ a smaller prop.
After I get most of the airframe built, and can determine where the battery should be, I will cut a hatch in the top of the fuse.
Not going to be a detailed build thread, but I will post pics of progress as I go along. feel free to ask any questions or contribute to the thread.
tlh101 is offline Find More Posts by tlh101
Old Jan 04, 2015, 09:24 AM
tlh101 is offline
FICKLE FLYER
tlh101's Avatar
Joined Dec 2002
Wing is nearly done. Just taped together now to check the joint angle. All the ailerons are shaped and hinged. Decided to use the torque rod control, because I didn't want the controls hanging under the wings. I will use a separate servo on each aileron. I will separate the halves to finish shaping the L/E and tips. Wind is howling today, so will be a good day to sand outdoors.
Old Jan 08, 2015, 04:55 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
cool build! ive always wanted one of these. looking forward to your build!
corsair nut is online now Find More Posts by corsair nut
Old Jan 14, 2015, 09:49 PM
tlh101 is offline
FICKLE FLYER
tlh101's Avatar
Joined Dec 2002
Moving right along.
Old Mar 14, 2015, 12:12 AM
David2011 is offline
Find More Posts by David2011
United States, NM, Hobbs
Joined Oct 2011
Keep it coming. People are watching even if they don't post.
David
David2011 is offline Find More Posts by David2011
Old Mar 14, 2015, 03:18 PM
tlh101 is offline
FICKLE FLYER
tlh101's Avatar
Joined Dec 2002
Still going, but progress has been slow. Got the battery hatch cut, and the servo tray and pushrods worked out. I have also done the belly fairing and tail surface fillets.
I also came across 1/4 scale plastic corrugations from Park Flyer Plastics, that perfect for the correct look on the flying surfaces. That's one of the things was holding me up. I could not decided how, or if I even wanted to do the corrugated surfaces. From scratch, they would have been extremely hard to cover with glass or film. These are perfect and only need paint.
Old Mar 16, 2015, 09:47 PM
tlh101 is offline
FICKLE FLYER
tlh101's Avatar
Joined Dec 2002
Rudder
Old Jun 27, 2015, 06:19 PM
tlh101 is offline
FICKLE FLYER
tlh101's Avatar
Joined Dec 2002
OK, life's been in the way here for a few months, but the build has gotten back on track. Started glassing the wings today. Hope to glass the top tomorrow, and maybe the stab and fin as well.
Then all the finish work will start.
Old Jun 29, 2015, 12:09 PM
wilmracer is offline
Find More Posts by wilmracer
United States, VA, Herndon
Joined May 2007
Glad to see you're back on this one! Looking good!
wilmracer is offline Find More Posts by wilmracer
Sold Cosmic wind OneLove86 Aircraft - Electric - Airplanes (FS/W) 10 Dec 04, 2014 03:31 PM
Sold NIB Electrifly Cosmic Wind (White) A phoneguy Aircraft - Electric - Airplanes (FS/W) 0 Nov 16, 2014 06:15 PM
Discussion C/G Cosmic wind jbonice Control Line 6 Oct 17, 2014 08:07 PM
For Sale cosmic wind white fvega Aircraft - Electric - Airplanes (FS/W) 2 Oct 01, 2014 08:14 PM
Sold Bridi "Cosmic Wind" 62" wingspan (built) OriginalBilly Aircraft - Fuel - Airplanes (FS/W) 4 Mar 01, 2014 03:51 PM
