Old Jan 21, 2014, 07:14 PM
brakar is offline
Find More Posts by brakar
brakar's Avatar
Asker, Oslo, Norway
Joined Feb 2009
Gallery
Show us your UAV
This thread is started by inspiration from the FPV foum, where they have a thread where they post info about their FPV birds.
The general idea is each post should show as much info as possible about your spesific UAV configuration, making it easy for others to make/purchase a similar configuration.
Regard it as a gallery-thread, not a thread for discussions.
brakar is offline Find More Posts by brakar
Old Jan 23, 2014, 06:33 AM
SuperCamel is offline
Find More Posts by SuperCamel
Joined Apr 2013
Bixler 2 & Arduino Due UAV (in development)
more info www.camelsoftware.com/firetail
That's the general layout inside.
The Due & protoshield & lots of hot glue. The glue on the wires is for strain relief and to prevent wires from vibrating.
D2826-6 2200kv motor with stock prop.
To fit the Due under the wings, the stupid clear tubes plus some of the foam has to be removed.
Complete build! I've seen some hideous FPV builds with cameras and junk hanging off everywhere, interrupting the smooth aerodynamic curves. One goal of this build was to keep the plane looking clean. Notice unusual looking spot just aft of the canopy? That's the ESC. It's overrated for the job and it doesn't get hot at all. So I embedded it in foam to keep the surface as smooth as possible.
Ready for a test flight this weekend!
SuperCamel is offline Find More Posts by SuperCamel
Old Jan 23, 2014, 02:30 PM
brakar is offline
brakar's Avatar
Asker, Oslo, Norway
Joined Feb 2009
Skywalker with Paparazzi Lisas/M
This si my old proven Skywalker which have been flown with a few different autopilots on board, last with Paparazzi's. The Skywalker I think is version 5, from Bevrc. Motor, esc, servos was from the same vendor, probably a combo package:
1* AX2814 kv980 motor
1* 40A reliable ESC
1* 9060 prop
Description:
- Autopilot: Lisa/M v2.0: http://wiki.paparazziuav.org/wiki/Lisa/M_v20 (from Transition Robotics Inc.)
- Gps: Ubox LEA6 (3DR)
- Wireless modules: (3DR)
Description:
Small detail; a usb-connector for easy access to the autopilot is embedded into the fuselage. There is also one wire from the autopilot which goes to a chdk enabled Canon camera, for shooting photos at distance based intervals.
Description:
The paparazzi GCS might look like this, (standard layout).
Description:
Paparazzi uses Airframe-files to store most of the information needed for a specific airframe/autopilot/sensors/navigation routines/modules/etc. -configuration.
My airframe-file currently look like this: (renamed from *.xml to *.txt)
my_lisa_m2_test7
Old Jan 26, 2014, 03:12 AM
Artful Owl is offline
Find More Posts by Artful Owl
Artful Owl's Avatar
New Zealand, Canterbury, Christchurch
Joined Dec 2011
Sky Hunter RPV
Description: Sky Hunter Name: 2013-12-20 17.36.56.jpg
Description: Autopilot
Video of this Sky Hunter @ 440Haste
Artful Owl is offline Find More Posts by Artful Owl
Old Jan 30, 2014, 04:57 AM
Artful Owl's Avatar
Joined Dec 2011
Where are all the other UAV at? I want to see some pics man
Old Jan 30, 2014, 11:29 PM
HELModels is offline
Find More Posts by HELModels
HELModels's Avatar
Joined Aug 2003
Here's mine. I designed it and didn't consider FPV, so until that stuff shrinks some more I can only fly it with GPS, Ardupilot and no telemetry. The wing has been replaced with a bigger span and different planform, but basically the same.
HELModels is offline Find More Posts by HELModels
Old Feb 21, 2014, 05:21 PM
brakar is offline
brakar's Avatar
Asker, Oslo, Norway
Joined Feb 2009
bump...
Old Feb 22, 2014, 07:54 AM
TNug is offline
Find More Posts by TNug
Waypoint Collector
TNug's Avatar
United States, NC, Raleigh
Joined Feb 2012
Phantom FX-61
Outside:
Inside:
Best flight: 114km
Details here
TNug is offline Find More Posts by TNug
Old Mar 01, 2014, 11:00 AM
Tom Harper is online now
Find More Posts by Tom Harper
Lift is cheap - Drag sucks
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Conduit
This model was built around the wiring harness to avoid the rats nest - hence the name Conduit.
Area 5.2 sq ft
Chord 11 inches
Span 66 inches
AR 5.9:1
AUW 82 oz
LIPO 4000mah
Motor Microdan 2510 1300KV
Camera Canon A650
Guidance - Attopilot V1.8
Usual survey flight 6 miles ~ 15 minutes air time (100% safety factor)
Tom Harper is online now Find More Posts by Tom Harper
Old Sep 25, 2015, 05:24 PM
brakar is offline
brakar's Avatar
Asker, Oslo, Norway
Joined Feb 2009
I came to think about this old thread again, and would think there is still more to be shown
What have you guys been up to lately?
Old Sep 29, 2015, 12:19 PM
aeroanalysis is offline
Find More Posts by aeroanalysis
United States, VA, Falls Church
Joined Dec 2003
Here's ours. 620 lb GTOW. 14 day flight capable. First flight Feb 2015. Piccolo autopilot.
aeroanalysis is offline Find More Posts by aeroanalysis
Old Sep 29, 2015, 12:32 PM
TNug is offline
Waypoint Collector
TNug's Avatar
Joined Feb 2012
Nice! When can I buy one from HobbyKing?
Old Sep 29, 2015, 12:42 PM
TNug is offline
Waypoint Collector
TNug's Avatar
Joined Feb 2012
Seriously, that's a very clean airframe. Any more details to share? Control and telemetry details? Rudder elevator only? Auto thermalling? What is the mission?
Old Sep 29, 2015, 01:32 PM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Why all that dihedral?
Zero dihedral is more efficient.
Since you have an autopilot low dihedral with ailerons is actually more stable especially in windy conditions. Being an aerospace engineer myself I really donít understand that design.
RC Man is offline Find More Posts by RC Man
Old Sep 29, 2015, 11:01 PM
bmw330i is offline
Find More Posts by bmw330i
David1
bmw330i's Avatar
USA
Joined Mar 2007
You made me go look at the best nature can do, the Albatross...like you said, little to know dihedral in the photos I saw. Interesting because the guys building that big bird are no dummies so I am curious also now.
bmw330i is offline Find More Posts by bmw330i
Yippee! Show us your micro slopers! Rusty Mustard Slope 138 Jun 29, 2016 01:42 AM
Discussion Show us your Micro Quad carry case QuadBert Mini Multirotors 84 Jun 10, 2016 10:56 PM
Discussion Show us your scratch build PVC multirotor. Gordosoar Scratchbuilt Multirotors 2671 Aug 23, 2015 07:01 PM
Discussion Show us your Stash! Predreadnut Dock Talk 26 Aug 07, 2014 12:13 AM
Gallery Show Us Your Sleek Onroad Rides! SoloProFan On-road Cars 4 Jan 16, 2014 10:47 AM
