Old Feb 21, 2013, 10:29 PM
oildude is offline
Find More Posts by oildude
Joined Feb 2013
V shape multicopter?
I am going to build my first rc ever and want to do a muticopter.
My first idea was to just build a Y or T frame but I have been thinking of a V frame with a center bay for the controller and battery.
I would either suspend the mount from the tail or V and extend it to the CG or suspend it from the mid point of the booms at the CG .
I would prefer to hang the controllers from the V anyone think this is a bad idea?
If this has been talked about I'm sorry I'm new here and to RC.
my idea v
motor-------motor
-------\-con-/
------motor
oildude is offline Find More Posts by oildude
Old Feb 21, 2013, 11:59 PM
Senator315 is offline
Find More Posts by Senator315
iMultirotors
Senator315's Avatar
Australia, NSW, Shellharbour
Joined Aug 2012
Will work just fine.
You'll need a servo controlled yaw mechanism for the rear motor. Other than that, you wont have any issues.
I love building new original designs and I like this one, it's clean and simple.
Senator315 is offline Find More Posts by Senator315
Old Feb 22, 2013, 04:27 AM
Blackrat is offline
Find More Posts by Blackrat
Registered Loon
Blackrat's Avatar
South Africa, WC, Knysna
Joined May 2006
the arms will be very long and the front 'junction' will be your weakpoint ... imo a T or Y is better
Blackrat is offline Find More Posts by Blackrat
Old Feb 22, 2013, 07:07 AM
Granted is online now
Find More Posts by Granted
serial scratchbuilder
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
Build an inverted "A", same basic layout but stronger.
Granted is online now Find More Posts by Granted
Old Feb 22, 2013, 09:04 AM
signguy is offline
Find More Posts by signguy
signguy's Avatar
Swansea, Massachusetts
Joined Dec 2004
Why not build a proven design first, then take what you learn from that to make your v frame. I don't want to rain on your parade, but...... I have a huge thread, started a long time ago... build a tricopter... first timers had a hard time getting their tri's to fly even following a proven simple design.
The layout of your V frame will work, but the motor at the apex will have a lot of arm in its way, producing less thrust. Frame stiffness may also be a problem. If you are using a FC with autolevel (just about everyone now) you'll need to place it at the cg for autolevel to work correctly.
Believe me.... I would love to see you build a V...Think it would be very cool to see it flown single motor first, like one of the earliest tricopters out there by one of the rcg members dave somthing.... don't remember his last name..
If you have any questions feel free to pm me. I have a pretty good grasp on multiwii, both homebuilt controllers and some mfg boards.
what area are you located?
BobD
signguy is offline Find More Posts by signguy
Old Feb 22, 2013, 12:45 PM
Mortimer is offline
Find More Posts by Mortimer
Mortimer's Avatar
Joined Apr 2010
You should start out with a conventional design and break new ground later.
Mortimer is offline Find More Posts by Mortimer
Old Feb 22, 2013, 02:18 PM
oildude is offline
Joined Feb 2013
Awesome response! Yes first RC ever! Yes I fully understand baby steps I'm just not that kind of guy! I just finished my last spare time project "solar power ice fishing house " with with 15 hours of 12v 22amp ave. 1000amp"10sec cap" peak output with 8hrs charge on a cloudy day in Minnesota in January! Anyone want to buy a used gas generator?
I was looking in to a kit at first but I have never been happy with a kit of any
kind. Also not looking to have a wooden frame. Having lots of aluminum left from building panels last summer I figure why not weld up my own frame!
Also I do see your point of the frame blocking the thrust? Could this be overcome with a longer prop? Blowing you own sail has no gain!
Old Feb 22, 2013, 02:32 PM
kenbad is offline
Find More Posts by kenbad
kenbad's Avatar
Joined Dec 2011
+1
But I do think you have a neat idea, and you can always transfer the compononents from you first build to this "V" config once you know what you are doing if you are on a limited buget
Patience is a huge factor in this hobby..
Quick question, is the apex of the "v" the front or the back?? I'm guessing the front..
kenbad is offline Find More Posts by kenbad
Old Feb 22, 2013, 02:38 PM
oildude is offline
Joined Feb 2013
Yes it would be the front but both would work I think. It could fly either way if you spin the control board 180 degree .
Old Feb 22, 2013, 02:52 PM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Go for it. May just work.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Feb 22, 2013, 04:30 PM
oildude is offline
Joined Feb 2013
I just did some math on the t6 aluminum weight. With a 20in. Span from rotor to rotor the full welded frame would be around 700gr with mounting pads. not sure how much electronics+ servo + wire + motors weigh. 700gr/1.6lb to heavy?
Old Feb 22, 2013, 05:23 PM
iMultirotors
Senator315's Avatar
Joined Aug 2012
700g is pretty heavy for a 500mm tri. I just built a 930mm octo and the frame weighs 460g using 16mm aluminium tube.
What size Aluminium are you using? You need to get the weight down to at least half that or it wont be very responsive and the flight time will suffer.
Don't worry too much about the thrust being blocked. Props don't just make thrust, they also create lift by creating a low pressure above the props which sucks the props upwards.
If you have a look at the video here (pics at the end of the clip) of this quad I built, you'll see that the front prop not only goes over the frame, but also over the FC, and I don't notice any loss of thrust from it.
The other thing you'll notice is that the FC is all the way up front, far from the CG. Again, this doesn't affect it's flight in acro or in self level mode what so ever.
I say, go ahead and build it, just make it lighter.
Old Feb 22, 2013, 05:55 PM
giek2000 is offline
Find More Posts by giek2000
Joined Nov 2008
Reminds me of this
giek2000 is offline Find More Posts by giek2000
Old Feb 22, 2013, 07:52 PM
oildude is offline
Joined Feb 2013
Nice but it still has a tail!
If I use 1/8x3/4 90 and 1in strap welded 4in out from the apex, double box the apex I could cut the weight closer to 500gr. I may have to have tension wire to reduce booms twisting.?
Old Feb 24, 2013, 05:15 AM
kenbad is offline
kenbad's Avatar
Joined Dec 2011
so how would you deal with the reversed motor assigments??
The kk2 tri layouts expect two motors in the front and one in the back,
I get turning the kk2 around but it still uses a specific layout,
typical front
m1 m2
x x
x x
x x
x x
x
m3
your front
M1 and m2 effect roll, period, and m1m2 and m3 effect pitch
you can't just turn the KK2 180 deg, it espects a specific motor layout relative to the board, especially on a tri
leave front of the kk2 facing the m1 m2 motors as they would be on a standard tri and reverse pitch and roll on your tx...because you are just flying a tri backwards witch cam be done and from what I have read elsewhere actually carves turns better e believe someone else here prefers to fly tri's backwards
Discussion V-shaped okto multicopter kjella Multirotor Talk 7 Jun 23, 2014 01:37 PM
Question Is this Lawmate tx & v-dipole antenna multicopter mounting configuration ok? Mactadpole FPV Talk 4 Jul 12, 2011 09:49 PM
Question Is this Lawmate tx & v-dipole antenna multicopter mounting configuration ok? Mactadpole Multirotor Talk 5 Mar 07, 2011 06:13 PM
Idea Alternative frame shapes of multicopters alll Multirotor Talk 27 Nov 16, 2010 03:07 PM
Delta with V shaped Canard. Elevon mixing ? Flyfan Scratchbuilt Indoor and Micro Models 30 Aug 09, 2002 10:31 PM
