Old Jun 09, 2012, 11:17 AM
ZippoGeek
zippogeek's Avatar
United States, NY, Buffalo
Joined Dec 2002
Help!
Kyosho F-16: what am I doing wrong?
I've had three flights on my Kyosho F-16 (55mm). I'm running a Thunder Power 1350, which is the battery indicated by Kyosho.
My problem: this jet nose-dives like a lawn dart! The only way I can get it to fly level is to maintain constant up elevator through the entire flight. Very stressful...
Before the maiden flight, I balanced the plane on a CG Machine with AUW. When I got to the field, however, it exhibited this nose-down behavior. After moving the battery back as far as possible towards the CG, she's still nosediving. Moving it back barely made a difference; it defies logic.
My next step is to add a ton of up-trim, which is completely bass ackwards.
Advice anyone? Thanks in advance...
Jason
zippogeek is offline Find More Posts by zippogeek
Old Jun 09, 2012, 03:59 PM
ZippoGeek
zippogeek's Avatar
Joined Dec 2002
bump - thx!
Old Jun 09, 2012, 05:02 PM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
You could read this: http://www.rcgroups.com/forums/showthread.php?t=866346
Might have missed something. BTW, pretty old isn't it?
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Jun 09, 2012, 05:12 PM
Joined Feb 2007
Anything misaligned?....stab, wing incidence? You say you checked your CG but if all of your surfaces are neutral or trimmed positive, your CG may be to far forward. Defiantely look/search into the older thread on this model.
toughitaliankid is offline Find More Posts by toughitaliankid
Old Jun 09, 2012, 05:49 PM
ZippoGeek
zippogeek's Avatar
Joined Dec 2002
Just went out for two flights. A combination of up elevator and squeezing the battery back even further made it work. But it's definitely too draggy on the tail now.
I'm going to find that thread. Thanks.
Discussion outdoor 3D flying - what am I doing wrong? sfluck 3D Flying 15 May 26, 2012 03:38 PM
Discussion Version 4.0 What am I doing wrong? Hopefully Fixed! AeroVideoUS Hoverfly Technologies 58 Apr 29, 2012 12:03 PM
Discussion What am I doing wrong while assembling this RTF sahil80 Beginner Training Area (Aircraft-Electric) 23 Apr 14, 2012 05:08 AM
Discussion what am i doing wrong?? tsilvers Foamies (Kits) 13 Jan 03, 2012 07:12 AM
Discussion Hyperion red power connector: what am I doing wrong? der Oberflügel Batteries and Chargers 9 Dec 28, 2011 11:57 AM
