Old Nov 15, 2012, 05:58 AM
Joined Sep 2010
Question
battery problem
Hi there i have a 5200 3 cell turnigy near new but when charging it keeps saying low voltage
does anyone no what this means and if the battery is broken
darynxbcoupe is offline Find More Posts by darynxbcoupe
Old Nov 15, 2012, 08:02 AM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
It means it was discharged too much and is below what the charger feels is safe for a 3s battery.
You can probably fix it, but you have to be VERY careful while doing it.
To fix, set your charger to nimh mode and plug in just the power leads from the battery to the charger (not the balance plug). Charge it like this for about 30 seconds, then try the 3s lipo setting again (with the balance plug). Keep doing this in 30 second attempts until it will charge in lipo mode.
To stop it from happening again, don't discharge it so much. Check your LVC settings if you're relying on that, or shorten the run by a minute or two. If you're putting in more than 4200mah, it's probably over discharged. A safe rule of thumb is to always leave 20% of the pack's capacity in the pack and never fully discharge it.
wparsons is offline Find More Posts by wparsons
Old Nov 15, 2012, 08:39 AM
Joined Sep 2010
thankyou will give it a try since it is only few weeks old
Old Nov 15, 2012, 07:46 PM
Joined Sep 2010
just charged on nimh for 30 seconds and then back to lipo and it worked straight away thanks heaps Wparsons
Old Nov 15, 2012, 10:19 PM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
No prob!
Old Nov 16, 2012, 10:14 PM
Joined Nov 2012
Dang that is some trick stuff. I will have to remember that for the future. I have never discharged a pack that low but if that ever happens I know what I will do.
homedefender83 is offline Find More Posts by homedefender83
Old Nov 17, 2012, 05:15 AM
Did you check the FAQ already?
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Please take note of this. Find out if your car has LVC (Low Voltage Cutoff) and check it's settings. If it doesn't have LVC at all, get a seperate "Lipo Saver/Monitor" to alert you to low discharge of the car battery, or a new ESC with LVC. But that will cost you more naturally.
SoloProFan is offline Find More Posts by SoloProFan
Old Nov 17, 2012, 10:56 AM
Malaysia, Federal Territory of Kuala Lumpur, Kuala Lumpur
Joined Jun 2012
my trx esc lvd cut off at 3.6-3.7..never have to worry of over discharge..
leonggyooi is offline Find More Posts by leonggyooi
Discussion HK TR6A V2 battery voltage problem mike_o Radios 1 Apr 26, 2012 02:33 PM
Help! Problem finding batteries for my Joker Aerial Photograph Helicopter Justin Jackson Aerial Photography 1 Apr 06, 2012 01:41 PM
Question Syma S111G Motor or Battery Problem? msd58 Coaxial Helicopters 6 Apr 05, 2012 10:31 AM
Discussion battery or ESC problem? Joe Casey Batteries and Chargers 12 Feb 28, 2012 05:43 PM
