Old Nov 19, 2014, 08:52 PM
Joined Nov 2014
need 5.8 boosting tricks.
Hello i am new here and in the world of quadcopters.I am very interested in Fpv so i just ordered a RTF8 kit for walkera x350 pro(quad+ilook plus/mush antena+f12e) and i would like to know more about the possibility to boost the signal of 5.8 ghz...Can you guys,provide me some links to get tricks and stuff to break the barrier of 1000m range?thanks a lot.
boulaybill is offline Find More Posts by boulaybill
Old Nov 19, 2014, 09:25 PM
Philippines, Calabarzon, San Pedro
Joined Jul 2012
Look up how to make either a patch or helical antenna. This is the one i made. Raised my range from 1km to 2km.
http://www.rcgroups.com/forums/showthread.php?t=2049958
Hajile is offline Find More Posts by Hajile
Old Nov 20, 2014, 05:46 PM
The Netherlands, UT, Utrecht
Joined Dec 2012
I have flown to 1600m with clovers and 600mW without a glitch. I don't dare to go further without rth. A crosshair is a very good antenna, but difficult to make. I've build one and it works kinda. Try it yourself, or buy one you won't regret it.
DaKluit is online now Find More Posts by DaKluit
Old Nov 20, 2014, 07:26 PM
A man with too many toys
United States
Joined Feb 2001
It’s all about antennas and antenna location. I get more than 1500m all the time with just a part of Blue Beam antennas and 500mw. The transmitter antenna needs to be on the bottom with a clear view of the receiver antenna. Carbon fiber parts are notorious for blocking the signal.
If you want more than 1500m then you might need a spherical antenna on the receiver. That won’t be of any use without having a good antenna location on your quad.
RC Man is online now Find More Posts by RC Man
Old Nov 21, 2014, 11:45 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Helical antennas are the cheapest range boost you can have. You can make your own or buy them. They're really cheap, so you might just buy them unless you are into antenna building. Just don't buy a super cheap one as they are often made incorrectly.
A crossahir is awesome. A bit pricey, but awesome.
Also, heed RC Man's advice about antenna location.
-Alex
IBCrazy is online now Find More Posts by IBCrazy
Old Nov 23, 2014, 07:46 AM
Joined Nov 2014
ok thank you guys,i will buy a crosshair,i think.
Old Nov 23, 2014, 07:47 AM
Joined Nov 2014
when you talk about 500-600 mw,what do it means?
Old Nov 23, 2014, 08:00 AM
Joined Nov 2014
http://www.ebay.com/itm/5-8g-L-helic...-/131226752990
sounds good?what is right and left handed means?
Old Nov 24, 2014, 05:44 AM
What place .... is this ???
Australia, SA, Adelaide
Joined Oct 2011
That's the handedness of the Circular Polarisation, if you imagine it rotates depending of the antenna from which it is transmitted, a Left Hand Circular Polarised (LHCP) antenna rotates the signal to the left and Right Handed Circular Polarised (RHCP) antenna rotates the signal to the left, they do not bear mixing. LHCP plays with LHCP and RHCP with RHCP, should not mix them. Down the track you may wish to consider an antenna tracker, here is a simple one and the payoff here is there is no gear on the aircraft to run the tracker.
Ilove2flyFPV Antenna Tracker at Sellicks Beach (13 min 8 sec)
Heppy Ket is online now Find More Posts by Heppy Ket
Old Nov 25, 2014, 02:30 PM
Performance & Quality
Spec UAV's Avatar
United States, OH, Akron
Joined Apr 2014
A little curious as to what you mean by "boosting" the signal of 5.8. If you're talking power output boosting, none is required. Like all the others have been suggesting, it's all about the antennas.
A cloverleaf or skew planar on quad and a 5 turn helical on ground station will get you 3km + easily with a 600mw tx. You'll run into battery life issues for the return flight home on that quad long before you run into video range issues.
Spec UAV is offline Find More Posts by Spec UAV
Site Sponsor
Old Nov 29, 2014, 04:09 PM
Joined Nov 2014
thanks mister!i just bought 2 clover leaf antennas on ebay,i will try it soon.thanks a lot again.
Old Nov 30, 2014, 12:21 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
That one is really poorly made. You can tell by the feed method. Start looking in the $30 range for helicals worth buying.
-Alex
Help! My dx9/mx-20 increases 5.8 ghz noisefloor - need help eliminating wizprod FPV Equipment 1 Nov 11, 2014 05:38 PM
Wanted Need helical for 5.8 and 2.4 MIKEYOUR FPV Equipment (FS/W) 0 Nov 06, 2014 03:23 AM
Sold 9*5 props, 6*5.5 props, 8*8 props abgolden Aircraft - General - Miscellaneous (FS/W) 0 Oct 14, 2014 12:02 AM
Discussion Need radio for 1m slope soarers and rocket Boost Gliders majordude Radios 2 Nov 19, 2013 04:53 PM
8 cells on 12v ... need a boost rcairflyer Batteries and Chargers 1 Jan 29, 2003 09:55 AM
