Old Aug 05, 2014, 11:11 AM
Aviation Maintenance Manager
carrera mike's Avatar
United States, VA, Chesapeake
Joined Dec 2012
Originally Posted by jhspring View Post
Hey Mike,
Been better, the chemo is really sapping my energy, so a lot less time building and flying than I would like. Of course, it seems to be working, which is a big plus.
The Zero is my goto plane, it is so forgiving and fun and I get about 10 min on a 4S 3300. Except for the bad habit of nosing over in grass, it is really just a big trainer. My second favorite has become my Dynam 262, but it is a real amp hog, barely 4.5 min on a 4S 6000.
Most of my time/money/energy has been going towards a bird survey project using an FPV plane with a still camera to monitor nesting and population census. Very cool that I get to play with r/c and call it university research. Best of all worlds
Regards,
Jeff
Jeff, Sorry to hear that youare undergoing Chemo. Hope flying takes your mind and body into another trance and forget your worries.
I love the Zero. until now it is stil my favorite one to fly. Hows the Dynam 262? Good flyer?
carrera mike is offline Find More Posts by carrera mike
Old Aug 05, 2014, 09:55 PM
Oh no, not again!
jhspring's Avatar
United States, LA, Carencro
Joined Dec 2005
Thanks Mike,
The whole chemo thing isn't the most pleasant, but I am encouraged by the results. It's an experimental protocol, my cancer is recalcitrant to the standard treatments.
I got out for an afternoon last week, only 92F and 70% RH, practically cool for July in Louisiana. I always go with a crowd -Saburo Sakai in the Zero, Eric Hartmann in the 262 and Pierre Clostermann in the PZ Spit. :-) The 262 needs a couple of minor mods. The long flexible pushrods and and small area make for sloppy elevator control, so rudder and elevator servos are moved to the tail. Landing gear, esp nose gear are a bit bendy for grass, so replacement HK oleos. It sounds really cool, and is as easy to fly as the Zero. No real vices, and there is that unmistakable shark-like silhouette in the sky. Throttle management is mandatory, I can run the battery flat in 3 min if I push it, something like 108A at WOT with the stock fans.
I had a wonderful afternoon. Saburo was totally on his game in the Zero, even to making a perfect 3-pointer on his second flight. Hartmann was great too, even managed to handle a double flame-out without airframe damage. (somebody forgot to check the charge on the lipo). Clostermann was good too and the Spit may be the most graceful plane ever built. So, yah, I went home with an ear-to-ear grin, had a wonderful day, no damage to my planes.
Life is good and a simple day of flying brings a lot of joy.
Regards,
Jeff
jhspring is offline Find More Posts by jhspring
Old Aug 06, 2014, 08:03 AM
Reverend's Avatar
Innsbruck, Austria
Joined Oct 2003
@Jeff: Although I do not know you, I have had friends in a similar position. You have my respect for your positiv attitude although I am sure it is not easy. Best wishes from Austria.
Managed to put some work into my Zero too. Technically its finished except the elevators that still need to be fitted.
I finished the weathering too, put on the decals and clear coated the whole plane in a semi gloss finish which I am very happy with. Looks a lot better than the matt clear coat the plane came in.
Well, running out of excuses to not maiden her...
Reverend is offline Find More Posts by Reverend
Old Aug 06, 2014, 08:33 AM
Oh no, not again!
jhspring's Avatar
Joined Dec 2005
Thanks for the good wishes, Reverend. Your Zero looks lovely.
I meant to mention that with the FMS Zero, I moved the lipo back and added 1.5 oz (~40g) to the tail to help with noseovers on grass. The Zero flies much better with the c/g aft of the factory recommendations.
Regards,
Jeff
Old Aug 06, 2014, 10:35 AM
Joined Dec 2012
Thanks Mike,
Regards,
Jeff
Jeff thats awesome how u described ur flu boys how they did their best for all the sorties u ordered them to do 👍. I hope to fly this weekend and get the same results. 🍻
Old Aug 28, 2014, 10:48 AM
Joined Dec 2012
I have a used Robart set for this plane if anyone is interested, PM me. Its the 630 RSE(90 deg) Electric and the 671 Left and Right Robo Struts.
The springs for this set have been cut to work with with this plane, 19-24LB plane, Absorbs shocks good. This set will come with all the the connectors and the OEM wheels and axle for the ESM Zero.
Here's a video of their drop checks
Robarts Electrics 631 RSE and 671 Robostruts (0 min 54 sec)
Old Sep 02, 2014, 03:40 PM
A4Framie
alfiev's Avatar
New Zealand, Marlborough, Woodbourne
Joined Nov 2011
Originally Posted by CoarseAir View Post
Has anyone had any luck with the factory air retracts?
I got a set with my Corsair, but not sure whether to even try them.
Well.... you are talking about the air retracts of course, I have the ESM electric retracts and can only comment on them. I am on to my second set, the first set failed on a heavy landing, the drive screw snapped (that's the main one that is driven by the motor and moves the threaded nut fore and aft, engaging with the trunnion and moving the gear).
When I say, a heavy landing, it wasn't actually all that bad, just not copy-book.
Why did I buy a second set of ESM gear if it doesn't seem up to it? Well.... it was the only gear available in my country. If I have another similiar failure I will bite the bullet and order something way more expensive from the USA. It will incur import duties!!!)
So... if the ESM air retracts are of similiar quality to the electrics, I'd say they are not up to the job for a 20 lb model. (yes, the Corsair is a heavy build and requires a lot of added weight in the nose to balance CoG)
Alf
alfiev is offline Find More Posts by alfiev
Old Sep 20, 2014, 07:08 PM
Reverend's Avatar
Innsbruck, Austria
Joined Oct 2003
Flights number ten - thirteen today. Love this plane more and more. Stock retracts are holding up fine.
Switched the kolm for a Saito boxer. The powerfull Kolm is going into tug duty.
Planet Hobby (ESM) Zero (3 min 38 sec)
Old Sep 23, 2014, 08:50 AM
Oh no, not again!
jhspring's Avatar
Joined Dec 2005
Reverend, beautiful flying of a very nicely detailed model. I have to say that is the most spectacular flying field I have ever seen. Living down here in the swamps, I am totally jealous. Been nearly four decades since I was in Innsbruck and I still remember being overwhelmed by the sheer magnificence of the city and the setting.
Regards,
Jeff
Old Sep 23, 2014, 09:00 AM
Reverend's Avatar
Innsbruck, Austria
Joined Oct 2003
Regards,
Jeff
Jeff,
thanks for the kind words. I am very blessed to be able to live and fly here. The backdrop is brilliant as long as you are not flying a camo coloured warbird
Innsbruck will probably have changed a bit in 40 years, the mountains certainly have not. If you do ever return, let me know. I will have a foamie ready for you.
Rgds,
Philipp
Old Oct 27, 2014, 03:58 PM
RC Pilot!
lomcevac913's Avatar
United States, NC, Salisbury
Joined Sep 2011
Hey Rev, where did you find the documentation for all the panel lines you added to the wings?
lomcevac913 is offline Find More Posts by lomcevac913
Discussion Scratch build of the Zero arjundogra Scale Fuel Planes 18 Mar 14, 2014 10:30 AM
Build Log Spitfire Build / Zero Replacement ( Build More) 67econoline Slope 306 Nov 28, 2013 02:33 PM
Build Log Electrifying KMP/ESM's Hawker Typhoon (The Sloooww Build) Orvis Glow to Electric Conversions 252 Mar 21, 2013 07:33 AM
Wanted Pilot Quick Build Zero pics -Plastic Cowl etc checkprop Aircraft - Fuel - Airplanes (FS/W) 0 Jan 18, 2013 01:09 PM
Discussion TROY Build models -now selling ESM -low prices Ldm Fuel Warbirds 23 Aug 30, 2009 01:37 PM
